Wheel Cleaners?
Old Jul 11, 2003 | 07:29 AM
yanotkaj's Avatar
yanotkaj
Default Wheel Cleaners?
What do you use to clean your wheels?
Old Jul 11, 2003 | 08:57 AM
s9am_me's Avatar
s9am_me
www.wheelwax.com
kinda expensive but works really really good. Less brake dust build up and easier to clean
Old Jul 11, 2003 | 12:44 PM
elbee's Avatar
elbee
P21S or Griot's.
Old Jul 11, 2003 | 04:46 PM
bhobson333's Avatar
bhobson333
Default Re: Wheel Cleaners?
I have found that Meguiars "Hot Rims" All Wheel Cleaner works well. I compared all the "easy" wheel cleaners in Pep Boys and this one was the only one that said "apply to wet wheels". All the others said "apply to dry wheels". I ask you: when you're washing your car, are your wheels dry?????
I spray it on wet wheels, wait 15-20 seconds & spray off with high-pressure. It does a real good job of removing the worst of it, but I always go back and wipe down the wheels with a soap-and-water rag. This is for two reasons, first to get the details and second to get the possibly corrosive wheel cleaner off those clear-coated wheels! (It smells like lye.)
Old Jul 11, 2003 | 05:01 PM
n8vz's Avatar
n8vz
i use simple green. and it's not toxic and does a great job at removing all that brake dust
Old Jul 11, 2003 | 05:32 PM
BlueDragonZ's Avatar
BlueDragonZ
Thumbs up
I've been using the Orange Cleaner which surprisingly worked better than other cleaner that I've used in the past. I don't even have to scrub any more. It sprays right off.
Old Jul 13, 2003 | 08:14 PM
CelticPride2's Avatar
CelticPride2
I've gotta agree with n8vz on using Simple Green. I tried it for the first time a couple weeks ago and it works like a charm! I usually give each spoke of my wheels 2 spray-bottle shots before I run it through the local carwash (touchless carwash, of course). The water from the carwash rinses it all off, and I can usually knock whatever loose dirt is left with a cotton towel.
--CP2
Super Black Enthusiast, 5-speed auto...tunes by iPod
Old Jul 14, 2003 | 02:38 PM
Ozz's Avatar
Ozz
I have to agree. I used this cleaner for the first time this past weekend. I was amazed at how easily it worked. I did the wheels after spraying down the whole car with a prerinse. Then washed the whole car. After that I just lightly went over the wheels once again with the general wash water to make sure any chemical residue was washed off. Saves a lot of work. Truly a spray and rinse solution.
Old Jul 15, 2003 | 07:51 PM
johnsZ's Avatar
johnsZ
Talking wheels
simple green- by the gallon at home depot
Old Jul 16, 2003 | 09:00 AM
teh215's Avatar
teh215
I have been using Hot Rims for years now. I spray it mostly behind the spokes where is it harder to get and it does a great job.
Old Jul 17, 2003 | 02:28 PM
UofK350Z's Avatar
UofK350Z
I use Mothers Wheel Mist. Its in a yellow spray bottle (I think thats what its called) Works well and is fairly inexpensive.
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
