NEW!!!! Daily Specials at Detailed Image
Today's Daily special (November 1, 2017) is Lake Country DA Buffer Adapter 5/8" x 11.
Regular Price is $4.99. Today's price is $3.44!
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
- Use rotary backing plates on your DA buffer!
- Compatible with virtually any DA Buffer
- Simple and easy to use
Today's Daily special (November 2, 2017) is Chemical Guys Heavy Duty Water Spot Remover.
Regular Price for 16 oz is $24.99. Today's price is $13.99!
- Easily remove light to medium watermarks and mineral deposits from your paint, chrome and glass
- We recommend using a foam applicator pad along with some elbow grease for application
- Faster than the traditional polishing process
Today's Daily special (November 3, 2017) is Lake Country Hydro Tech Cyan Light Cutting & Polishing Pad.
Regular Price for 6.5" is $11.99. Today's price is $7.08!
Regular Price for 5.5" is $9.99. Today's price is $6.05!
Regular Price for 4" is $5.99. Today's price is $3.66!
Regular Price for 3" is $3.99. Today's price is $2.41!
Regular Price for 2" is $3.99. Today's price is $2.36!
- Powerful cutting action but the ability to finish down haze free
- Hydro Tech foam keeps more polish on the surface of the pad for longer work time
- Experience less dusting than traditional foam pads due to less product build up
- Lake Country Snappy Clean Pad Cleaner help clean these pads
- Works great with the Meguiar's Ultra-Cut Compound M105 and the Menzerna Super Intensive Polish SI 1500 (PO83)
Today's Daily special (November 6, 2017) is DI Accessories Universal Replacement Flip Top Caps.
Regular Price is $0.99. Today's price is $0.53!
- Universal top that fits the majority of 16oz, 32oz, 500ml and 1000ml bottles
- Spout helps control how much you pour out
- Helps conserve product and save you money
- Keep a few around the garage in case you break a cap
- Not: These caps do not work with the Meguiar's bottles
Today's Daily special (November 7, 2017) is DI Microfiber Wax Removal Two Colored Towel.
Regular Price for 16" x 16" is $7.99. Today's price is $5.63!
- Ultra thick microfiber towel that specializes in removing excess wax
- Can also be used on plastics, glass, and so much more
- Two different color sides and soft silk edging
- We always recommend washing your microfiber products before first use (i.e. CG Microfiber Wash)
Today's Daily special (November 8, 2017) is Stoner Trim Shine Vinyl & Plastic Coating.
Regular Price for 12 oz is $5.99. Today's price is $4.18!
- Restores and UV protects vinyl, plastic and rubber using a clear, colorless, non-greasy formula
- Works great on faded trim, bumpers, in the engine bay, running boards, rubber moldings, AC vents and more
Today's Daily special (November 9, 2017) is 303 Spot Cleaner.
Regular Price for 16 oz is $6.99. Today's price is $4.72!
- A great pre-diluted all purpose cleaner for carpets, upholstery, vinyl, rubber, leather, plastic and much more
- Safely removes oil, grease, ink, coffee, tea, wine, juice, blood, and tons more
- Cleaning action increases when agitated with a Carpet Scrub Brush
- Formally known as the 303 Cleaner & Spot Remover
- The 303 Spot Clear is the diluted and ready to use version of the 303 Multi-Surface Cleaner.
Today's Daily special (November 10, 2017) is 3M Automotive Performance Masking Tape.
Regular Price for 18 mm is $3.99. Today's price is $3.01!
Regular Price for 36 mm is $5.99. Today's price is $5.16!
- Properly protect paint, trim, emblems, lights, adjacent panels and more when using a buffer
- Very high quality tape, perfect for auto detailing
- Instantly sticks on surfaces and releases without any residue left behind
- Ensures you don't get the dreaded white stain on your trim
Today's Daily special (November 13, 2017) is Lake Country Microfiber Polishing Pad.
Regular Price for 3.25" is $8.99. Today's price is $5.65!
Regular Price for 5.25" is $10.99. Today's price is $7.43!
Regular Price for 6.25" is $11.99. Today's price is $8.10!
- Remove light to medium imperfections with ease
- A great compliment to Lake Country Microfiber Cutting Pads
- Foam backed and 11mm thick design
- Unique microfiber material mats down less reducing surface temperature
- Finishes down extremely well!
Today's Daily special (November 14, 2017) is CarPro Gloss Pad.
Regular Price for 5.5" is $8.99. Today's price is $7.19!
Regular Price for 6.5" is $9.99. Today's price is $7.99!
- Safely removes swirls, oxidation, etc.
- Made of high quality open cell polyurethane foam
- 1 1/4" inches thick with a bevel profile
- Creates an optically clear and glossy surface
Today's Daily special (November 15, 2017) is Lake Country Tire Dressing Applicator.
Regular Price is $2.99. Today's price is $1.85!
- A perfect applicator pad to apply your favorite tire dressing
- Firm foam design that will not shred like cheaper tire dressing applicator pads
- Works excellent with Poorboy's Bold 'n Bright water based tire dressing
Today's Daily special (November 16, 2017) is Gyeon Microfiber Suede.
Regular Price for 4" x 4" 10 Pack is $9.99. Today's price is $7.24!
- Apply a nice thin coating layer with ease
- Ultra soft and extremely low nap
- Pair with the Gyeon Applicator Foam Block
Today's Daily special (November 17, 2017) is Meguiar's Soft Buff DA Foam Cutting Disc.
Regular Price for 5" is $10.99. Today's price is $7.62!
Regular Price for 6" is $12.99. Today's price is $9.00!
- Great foam cutting disc that removes medium to heavy imperfections with ease!
- Low operating temperature and less haze left behind
- Thin 17.5mm disc design
- Works great on the MT300 or any other DA Polisher
- Perfect fit on the Soft Buff DA Backing Plate
Today's Daily special (November 20, 2017) is DI Accessories Poster Calendar.
Regular Price for 2018 is $3.99. Today's price is $2.07!
- Show off your DI pride!
- Printed on 100 lb. gloss book (C2S) with an aqueous coating
- Measures 13" x 19"
Today's Daily special (November 21, 2017) is DI Accessories Speedy Super Foamer.
Regular Price is $84.99. Today's price is $50.59!
- Spray a thick layer of suds all over your exterior with ease
- Wash faster and more effectively
- Can be used with most pressure washers from 700 - 3000 PSI with a standard pressure fitting
Today's Daily special (November 22, 2017) is Detail Guardz Tire Jam Eliminator 4 Pack.
Regular Price is $29.99. Today's price is $18.24!
- Helps stop tire jamming of cords and hoses
- Made of high quality heavy duty polypropylene
- Simply slide behind the tire to install
Today's Daily special (November 24, 2017) is Tuf Shine Tire Shine Kit.
Regular Price is $39.99. Today's price is $26.73!
- The first ever semi-permanent tire dressing that looks amazing and truly lasts
- One coat dark matte finish, two or more coats is extra glossy
- Contains no oils or silicone's that can harm the tire
- Will not sling off, dries to the touch in minutes, no oily feel
- Formerly known as the "Tuf Shine Tire Appearance Kit"
Today's Daily special (November 27, 2017) is Meguiar's Ultra Polishing Wax D166.
Regular Price for 16 oz is $17.99. Today's price is $12.22!
Regular Price for 128 oz is $69.99. Today's price is $48.17!
- Remove light to moderate imperfections while protecting the paint!
- Save time and money by combining detailing steps
- Remove light scratches, swirls, and oxidation with ease
- Leaves behind a durable layer of synthetic polymers, silicones and carnauba wax
Today's Daily special (November 28, 2017) is Lake Country CCS Orange Light Cutting Pad.
Regular Price for 6.5" is $9.99. Today's price is $6.11!
Regular Price for 5.5" is $7.99. Today's price is $4.72!
Regular Price for 3" is $4.99. Today's price is $3.23!
- Great pad for applying your favorite polish
- CCS dimple technology reduces friction and heat
- We recommend caring for your pads with Snappy Clean Pad Cleaner
- For best results, follow up with the CCS White Polishing Pad and your favorite finishing polish
- Helps work in medium to heavy cutting polishes
Today's Daily special (November 29, 2017) is Chemical Guys Lightning Fast Carpet Stain Extractor.
Regular Price for 16 oz is $8.99. Today's price is $6.36!
Regular Price for 128 oz is $34.99. Today's price is $27.46!
- Cleans interior surfaces quickly and easily!
- Removes stains from coffee, mud, dirt, juice, wine, etc.
- Cleans fabrics, door panels, etc. and leaves behind a fresh scent
- Use as stand-alone cleaner or as pre-treatment for carpet extractor
