NEW!!!! Daily Specials at Detailed Image
Old Aug 31, 2017 | 05:23 AM
  #2061
Detailed Image's Avatar
Detailed Image
Detailed Image
Today's Daily special (August 31, 2017) is Lake Country Yellow Cutting Pad.
Regular Price for 6.5" is $9.99. Today's price is $6.20!
Regular Price for 5.5" is $7.99. Today's price is $4.92!
Regular Price for 4" is $4.99. Today's price is $3.38!
Regular Price for 3" is $3.99. Today's price is $2.76!
  • The most aggressive foam cutting pad, designed to remove the deepest swirls and scratches
  • Medium to heavy cutting polishes work great with a yellow cutting pad
  • We recommend caring for your pads with Lake Country Snappy Clean Pad Cleaner
  • You need to follow up with a lighter pad and polish combo afterward to remove haze on the surface
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Old Sep 1, 2017 | 04:17 AM
  #2062
Detailed Image
Detailed Image
Today's Daily special (September 1, 2017) is Lake Country Force Grey Heavy Cutting Pad.
Regular Price for 5.5" is $8.99. Today's price is $6.10!
Regular Price for 6.5" is $10.99. Today's price is $7.35!
Regular Price for 3.5" is $4.99. Today's price is $3.49!
Regular Price for 2" is $6.99. Today's price is $3.95!
Regular Price for 1" is $6.99. Today's price is $3.91!
  • Strong cutting foam pad designed to remove swirls and ultra fine scratches
  • Hybrid foam technology keeps the polish on the surface of the pad
  • 1.25" thick pad is very user friendly
  • We recommend following up with a lighter pad and polish combo
  • We recommend cleaning your pads with Lake Country Snappy Clean Boost Pad Cleaner
Old Sep 5, 2017 | 03:14 AM
  #2063
Detailed Image
Detailed Image
Today's Daily special (September 5, 2017) is DI Microfiber Ultra Plush Two Sided Towel.
Regular Price for 16" x 16" is $5.99. Today's price is $4.38!
  • Our most popular towel for applying quick detailers, plush on one side and medium nap on the other
  • Works excellent as an interior duster towel which you can easily store in your glove compartment
  • Perfect for giving those final wipe downs after removing a sealant or wax
  • We always recommend washing your microfiber products before the first use (ie DI Microfiber Micro-Restore Microfiber Detergent Concentrate)
  • 530 GSM
Old Sep 6, 2017 | 04:50 AM
  #2064
Detailed Image
Detailed Image
Today's Daily special (September 6, 2017) is DI Accessories Precision Dressing Applicator.
Regular Price is $6.99. Today's price is $4.65!
  • Easy to hold app that makes applying dressings fast and easy!
  • Six sided shape helps you reach even the toughest of areas
  • Lightweight, yet durable design
  • Rinses clean and lasts for multiple applications
Old Sep 7, 2017 | 04:57 AM
  #2065
Detailed Image
Detailed Image
Today's Daily special (September 7, 2017) is DI Microfiber Glass Polishing Towel (Blue).
Regular Price for 16" x 16" is $5.99. Today's price is $3.24!
  • The ideal solution for achieving that streak free finish when caring for glass
  • Use a slow wiping motion, while applying some pressure to the glass polishing towel
  • The low, ultra thin nap ensures that there is no lint left behind on glass
  • Ideally, use a separate towel to apply your favorite glass cleaner and initially wipe dry
  • Always wash your microfiber products prior to first use and remove tags to ensure paint safe
  • 240 GSM
Old Sep 8, 2017 | 05:52 AM
  #2066
Detailed Image
Detailed Image
Today's Daily special (September 8, 2017) is Lake Country HDO Red Waxing Pad.
Regular Price for 5.5" is $13.99. Today's price is $9.16!
Regular Price for 6.5" is $15.99. Today's price is $10.51!
Regular Price for 3.5" is $8.99. Today's price is $6.07!
  • The softest of the LC HD Pads, allows you to apply waxes, sealants and all-in-one (AIO) products!
  • Pair with your favorite wax, sealant, cleaner wax, AIO, etc.
  • Runs 10% cooler than traditional Lake Country pads
  • Perfectly balanced, cushioned, and features thinner foam
Old Sep 11, 2017 | 03:28 AM
  #2067
Detailed Image
Detailed Image
Today's Daily special (September 11, 2017) is DI Brushes ATLASTA Soft Tip Brush.
Regular Price is $14.99. Today's price is $9.62!
  • Versatile brush can be used on your interior or exterior surfaces!
  • Packed with soft filament bristles that hold their shape
  • 9.75" long with a weight of 4.3 oz
  • Amazing brush for wheels!
Old Sep 12, 2017 | 05:36 AM
  #2068
Detailed Image
Detailed Image
Today's Daily special (September 12, 2017) is Tuf Shine Scrub-All No Scratch Sponge.
Regular Price is $1.99. Today's price is $1.54!
  • Quickly and safely remove bug smear, road grime, tar and more!
  • A durable and reusable sponge that will last
  • Extra strong and very gentle
Old Sep 14, 2017 | 04:08 AM
  #2069
Detailed Image
Detailed Image
Today's Daily special (September 14, 2017) is DI Accessories Speedy Stone Pet Hair Remover.
Regular Price is $6.99. Today's price is $4.38!
  • Easily remove pet hair from interior carpets and upholstery
  • Pours attract pet hair and remove them from the surface
  • Rounded shape makes this stone easy to hold
  • Also works great around the house!
Old Sep 15, 2017 | 04:05 AM
  #2070
Detailed Image
Detailed Image
Today's Daily special (September 15, 2017) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6.5" is $11.99. Today's price is $7.57!
Regular Price for 5" is $9.99. Today's price is $6.15!
Regular Price for 4" is $5.99. Today's price is $4.40!
  • Our most cutting pad option, however, due to the wool strands, not as much heat is generated
  • Works best on high powered buffers, for fast, effective paint correction
  • Commonly used with a medium or heavy cut compound to remove deep imperfections and wet sanding marks
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old Sep 18, 2017 | 04:24 AM
  #2071
Detailed Image
Detailed Image
Today's Daily special (September 18, 2017) is Lake Country DA Buffer Adapter 5/8" x 11.
Regular Price is $4.99. Today's price is $3.36!
  • Use rotary backing plates on your DA buffer!
  • Compatible with virtually any DA Buffer
  • Simple and easy to use
Old Sep 19, 2017 | 04:58 AM
  #2072
Detailed Image
Detailed Image
Today's Daily special (September 19, 2017) is Leatherique Prestine Clean.
Regular Price for 16 oz is $24.99. Today's price is $18.60!
Regular Price for 32 oz is $34.99. Today's price is $26.20!
Regular Price for 8 oz is $15.99. Today's price is $11.03!
  • A premium leather cleaner with light conditioners, perfect for cleaning and maintaining leather
  • Restores proteins that are naturally found in leather for a soft and supple feel
  • Completely matte finish that has no greasy or oily residue
  • Apply to your leather and let sit for 15 - 30 minutes, wipe with a warm damp towel and wipe dry with a second towel
  • For maximum results, Prestine Clean is best used after Leatherique Rejuvenator Oil
Old Sep 20, 2017 | 04:11 AM
  #2073
Detailed Image
Detailed Image
Today's Daily special (September 20, 2017) is DI Brushes Foam Brush.
Regular Price for 2" is $1.49. Today's price is $0.69!
  • Highest quality foam brush made proudly in the USA
  • Helps spread any detailing product uniformly
  • Very soft and gentle yet durable and strong
Old Sep 21, 2017 | 06:00 AM
  #2074
Detailed Image
Detailed Image
Today's Daily special (September 21, 2017) is Chemical Guys Extreme Top Coat Sealant.
Regular Price for 16 oz is $29.99. Today's price is $17.19!
  • Acts like a glaze, protects like a sealant!
  • Fills in minor imperfections, increasing depth
  • Protects the paint from harmful environmental contamination
  • Easy to apply
Old Sep 22, 2017 | 04:17 AM
  #2075
Detailed Image
Detailed Image
Today's Daily special (September 22, 2017) is Meguiar's All Purpose Cleaner D101.
Regular Price for 128 oz is $14.99. Today's price is $10.98!
Regular Price for 5 Gallon is $59.99. Today's price is $46.46!
  • Perfect for carpet, upholstery, vinyl and leather surfaces
  • Concentrated formula works effectively at a 10:1 dilution ratio
  • Agitate stubborn stains with a medium bristled brush for maximum results
  • Exceptional value for detailers and enthusiasts
  • Dilute and dispense using a 22 oz trigger spray bottle
Old Sep 25, 2017 | 03:09 AM
  #2076
Detailed Image
Detailed Image
Today's Daily special (September 25, 2017) is DI Accessories 1 Gallon Flip Top Cap.
Regular Price for Fine Spout is $0.99. Today's price is $0.46!
Regular Price for Large Spout is $1.49. Today's price is $0.68!
  • Flip top cap with two great spout sizes
  • Great for easy poring and dilution of larger solution bottles
  • Fit various Chemical Guys, Meguiar's, 303, Optimum and DI Accessories Empty 128oz bottles
Old Sep 26, 2017 | 05:28 AM
  #2077
Detailed Image
Detailed Image
Today's Daily special (September 26, 2017) is Meguiar's Generic Spray Bottle.
Regular Price for 32 oz is $2.99. Today's price is $2.20!
  • Dilute your favorite cleaning chemicals in this bottle
  • Chemical resistant bottle is OSHA compliant
  • Pick up this bottle and a DI Accessories Chemical Resistant Spray Trigger
  • Bottle is color coded and has a spot for you to label it accordingly
Old Sep 27, 2017 | 05:10 AM
  #2078
Detailed Image
Detailed Image
Today's Daily special (September 27, 2017) is DI Accessories Detailer Vinyl Die Cut Sticker.
Regular Price for Black is $2.99. Today's price is $1.62!
Regular Price for Silver is $2.99. Today's price is $1.62!
  • High quality vinyl die cut sticker in two great colors!
  • Measures 1.8" x 12"
  • Gloss vinyl lettering sticks to any flat surface
  • UV and water resistant
  • Also available in standard DI Accessories Detailer Sticker
Old Sep 28, 2017 | 04:08 AM
  #2079
Detailed Image
Detailed Image
Today's Daily special (September 28, 2017) is DI Accessories Reclosable Storage Bag.
Regular Price for 24" x 24" is $3.49. Today's price is $1.83!
  • Simple solution for storing microfiber towels!
  • The large 24" x 24" size offers flexibility to accommodate dozens of towels
  • Thick reclosable bags make it a durable long term solution to storage needs
Old Sep 29, 2017 | 04:03 AM
  #2080
Detailed Image
Detailed Image
Today's Daily special (September 29, 2017) is Jescar Color Lock Carnauba Wax.
Regular Price for 16 oz is $20.99. Today's price is $15.59!
  • Liquid wax that provides durable protection and an amazing level of gloss
  • Use by itself or use it after the Jescar Power Lock Polymer Sealant
  • Very easy to apply and remove
  • Rivals the classic look of other traditional carnauba paste waxes
