NEW!!!! Daily Specials at Detailed Image
Today's Daily special (July 27, 2009) is Menzerna PO85RD Polish.
Regular Price for 32 oz is $39.99. Today's price is $29.99!
Today's Daily special (July 28, 2009) is Optimum (OPT) Finish Polish.
Regular Price for 32 oz is $29.99. Today's price is $22.49!
Today's Daily special (July 29, 2009) is Dodo Juice Red Mist Tropical Protection Detailer.
Regular Price for 250 ml is $16.99. Today's price is $12.74!
Today's Daily special (July 30, 2009) is P21S Paintwork Cleanser.
Regular Price for 11.8 oz is $13.99. Today's price is $11.43!
Today's Daily special (July 31, 2009) is Gilmour Foamaster II Foam Gun.
Regular Price for 1/4 Gallon Tank is $59.99. Today's price is $44.99!
Today's Daily special (August 1, 2009) is Menzerna Top Inspection Spray.
Regular Price for 500 ml is $19.99. Today's price is $14.99!
Today's Daily special (August 2, 2009) is Lake Country Snappy Clean Pad Cleaner.
Regular Price is $1.49. Today's price is $1.12!
Today's Daily special (August 3, 2009) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.49!
Today's Daily special (August 4, 2009) is Chemical Guys Fine Grade Clay Bar.
Regular Price for 200 g is $21.99. Today's price is $17.18!
Today's Daily special (August 5, 2009) is Poorboy's World Super Swirl Remover 2 (SSR 2).
Regular Price for 16 oz is $15.99. Today's price is $11.99!
Today's Daily special (August 6, 2009) is DI Accessories Sheepskin Wash Mitt.
Regular Price is $9.99. Today's price is $7.49!
- Perfect wash medium to help minimize adding swirls and other imperfections to the paint
- The natural fibers help pull contamination away from the surface without grinding them in
- When done using, rinse any contamination using free flowing water than hang dry with leather hoop
- For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
Today's Daily special (August 7, 2009) is P21S Finish Restorer.
Regular Price for 75 ml is $9.99. Today's price is $8.27!
- Clean, restore and polish your wheels and metal trim in one easy step
- A little goes a long way, work a small amount of product into the metal with light pressure
- We recommend using a foam applicator pad for application
- Use a two sided metal polishing towel to remove excess product and to buff to desired finish
Today's Daily special (August 8, 2009) is Dodo Juice Born to be Mild Shampoo.
Regular Price for 250 ml is $16.99. Today's price is $14.67!
Regular Price for 500 ml is $32.99. Today's price is $27.84!
- One of the best shampoos we've tested in terms of lubricity and maximizing your coats of protection
- Highly concentrated formula means only a little bit of product is needed to achieve great results
- Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Today's Daily special (August 9, 2009) is Clear Kote Fine Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $18.74!
- Remove embedded surface contamination that does not come off during the washing process
- Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
- Helps you get the most out of any step you perform after using the clay bar
- Use with plenty of clay bar lubricant to minimize any micro-marring that may occur
- We recommend using Clear Kote Quik Shine as a clay bar lubricant and quick detailer
Today's Daily special (August 10, 2009) is Grit Guard Grit Guard Insert.
- A must have for any detailer, minimize adding imperfections during the wash phase
- Simply place the Grit Guard insert into the bottom of a bucket to trap dirt and contamination
- Gently glide your wash medium over the Grit Guard insert to release contamination
- Excellent results with the Lake Country Grout Sponge paired with a Grit Guard bucket insert
Clear Kote Quik Shine (QS).
Regular Price for 16 oz is $9.99. Today's price is $7.49!
Regular Price for 32 oz is $16.99. Today's price is $12.74!
- An amazing quick detailer that not only enhances the gloss and depth but also cleans the paint
- Ideal for removing a coating of light dusting on your paint or for boosting gloss after a wash
- Works great as a clay bar lubricant
- Use a plush microfiber towel to minimize adding imperfections and to prevent streaking
Today's Daily special (August 12, 2009) is Optimum (OPT) Hyper Compound.
Regular Price for 32 oz is $19.99. Today's price is $14.99!
- A great compound that offers long work times and can be used in the sun or shade
- Most commonly applied with a yellow cutting pad or purple foamed wool pad when using a buffer
- Popular amongst mobile detailers who may be polishing outside
Today's Daily special (August 13, 2009) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6.5" is $9.99. Today's price is $7.49!
- Our most cutting pad option, however, due to the wool strands, not as much heat is generated
- Works best on high powered buffers, for fast, effective paint correction
- Commonly used with a heavy cut compound to remove deep imperfections and wet sanding marks
- We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (August 14, 2009) is Chemical Guys Citrus Wash & Gloss.
Regular Price for 16 oz is $7.99. Today's price is $5.99!
Regular Price for 128 oz is $22.99. Today's price is $17.25!
- One of our best selling shampoos, lots of foam, great lubricity, strong cleaning power
- Can be used in high concentration to strip off previous coats of protection from a sealant or wax
- Can be used very diluted to maintain your coats of protection during regular maintenance washes
- Works great in a foam gun, such as the Gilmour Foamaster II
Today's Daily special (August 15, 2009) is Gilmour Flexogen 8 ply Hose.
Regular Price for 50 feet is $34.99. Today's price is $26.34!
