NEW!!!! Daily Specials at Detailed Image
Today's Daily special (August 16, 2009) is Dodo Juice Diamond White Hard Wax.
Regular Price for 250 ml is $69.99. Today's price is $54.72!
Regular Price for 30 ml is $13.99. Today's price is $10.55!
- The Dodo Juice Diamond White hard carnauba wax is designed to work exceptionally well on lighter colored vehicles
- Extremely easy to apply and remove, especially when applied in thin layers
- Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
- Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
- Apply with a foam applicator pad and remove with a plush microfiber towel
Today's Daily special (August 17, 2009) is Lake Country Black Finishing Pad.
Regular Price for 6.5" is $9.99. Today's price is $7.49!
- A finishing pad, designed to bring the paint to its maximum depth and gloss with a finishing polish
- Also can be used to apply a paint cleaner, glaze or sealant
- Menzerna PO85RD is one of the most popular polishes to use with a black finishing pad
- We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (August 18, 2009) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.49!
- Foam based formula that is ammonia free, making it safe on tinted windows
- Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more
- Best applied with an all purpose microfiber towel, then wiped clean with a dry microfiber towel
- For optimal results, give a final wipe down with the low nap, glass microfiber towel
- Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Today's Daily special (August 19, 2009) is Lake Country Ulti-Mit.
Regular Price is $15.99. Today's price is $11.99!
- A paint safe foam wash mitt that has two different surfaces to tackle various areas of your vehicle
- Holds large amounts of suds and water which helps minimize marring the paints finish
- Use the red cubed side to wash your paint, as it is the softer of the two sides
- Use the black side to clean stubborn contamination off of lower panels, tires, wheel wells and more
- Highly recommended to be used with a Grit Guard insert to easily release contamination
- Will outlast natural fiber mitts due to the durable foam design
Today's Daily special (August 20, 2009) is Optimum (OPT) Tire Shine.
Regular Price for 17 oz is $11.99. Today's price is $8.99!
Regular Price for 128 oz is $35.99. Today's price is $26.99!
- Water based tire dressing that applies easily and does not sling onto your paint
- Can be applied in multiple layers for a glossier look or buffed down to a matte finish
- We recommend using a Lake Country tire dressing applicator to apply Tire Shine
Today's Daily special (August 22, 2009) is Dodo Juice Sour Power Gloss Enhancing Shampoo.
Regular Price for 250 ml is $13.99. Today's price is $10.49!
- Perfect maintenance shampoo that enhances gloss and depth
- Lots of lubricity and slickness to help minimize adding imperfections
- Concentrated formula means only a little product is needed per wash
- Best used with a grout sponge or sheepskin wash mitt
Today's Daily special (August 24, 2009) is Chemical Guys M-Seal Pure Sealant.
Regular Price for 16 oz is $19.99. Today's price is $14.99!
- One of the best bang for the buck, pure sealants for under $20
- Easy to apply and remove when applied properly, which is as thin as possible
- M-Seal not only protects your paint, but leaves behind a great shine and sharp reflections
- Best applied with a foam applicator pad and removed with a microfiber towel
- When using a buffer, best applied with a blue fine finishing pad
Today's Daily special (August 25, 2009) is Poorboy's World Super Swirl Remover 2.5 (SSR 2.5).
Regular Price for 16 oz is $15.99. Today's price is $11.99!
- Designed to remove a majority of imperfections in the clear coat
- Removes moderate to deep swirls, oxidation, water spots, scratches and other imperfections
- Can be applied in either the shade or in the sun, making the polishes great for mobile detailers
- Poorboy's SSR 2.5 should be followed up with a finishing polish for maximum results
- Works best when applied with a quality buffer, such as a Porter Cable 7424 or Flex XC3401VRG
- When using a buffer, best applied with an orange light cutting pad
- For accurate product dispensing, we recommend using a 4oz dispenser bottle or 8oz yorker bottle
Today's Daily special (August 26, 2009) is Poorboy's World Spray & Wipe (S&W).
Regular Price for 16 oz is $8.99. Today's price is $6.74!
Regular Price for 32 oz is $14.99. Today's price is $11.24!
Regular Price for 128 oz is $32.99. Today's price is $26.10!
- Extremely versatile product that is a favorite amongst professional detailers
- Quick and easy waterless wash product for lightly contaminated vehicles
- Excellent clay bar lubricant, even diluted at a 1:1 ratio with distilled water
- Perfect product to keep in your glove compartment to clean up emergency bird bombs, sap, tar, etc.
- Best applied with a plush microfiber towel to minimize any micro-marring in the paint
- For maximum efficiency and convenient storage use in a 4oz pump spray bottle
Today's Daily special (August 27, 2009) is P21S Concours Carnauba Wax.
Regular Price for 6.2 oz is $31.99. Today's price is $26.05!
- Very easy to apply and remove carnauba wax that looks great on any color vehicle
- Includes an applicator pad that conveniently stores inside the top of the wax
- Unlike other waxes, P21S Concours Carnauba wax will not stain your trim
- Excess product should be removed with a quality microfiber towel
- P21S recommends prepping the surface with Paintwork Cleanser for best results
Today's Daily special (August 29, 2009) is Menzerna Final Polish II (FPII).
Regular Price for 16 oz is $18.99. Today's price is $14.42!
Regular Price for 32 oz is $29.99. Today's price is $22.49!
- A great finishing polish, designed to remove hazing, holograms and light surface imperfections
- Restores depth and gloss to the paints finish and is easy to work with
- Easy to remove when worked into the paint properly
- Recommended application is using a buffer with a white polishing pad
Today's Daily special (August 30, 2009) is Clear Kote Red Moose Machine Glaze.
Regular Price for 16 oz is $17.99. Today's price is $13.49!
- Enhance the gloss and depth of any color paint, while hiding minor imperfections
- We recommend applying a carnauba wax on top of Red Moose Glaze
- To avoid bonding issues, we do not recommend applying a sealant on top of Red Moose Glaze
- We recommend using a foam applicator pad along with some elbow grease for application
- Remove Red Moose Glaze with a quality microfiber towel
Today's Daily special (August 31, 2009) is 303 Aerospace Protectant.
Regular Price for 16 oz is $12.99. Today's price is $9.74!
Regular Price for 32 oz is $22.99. Today's price is $17.24!
Regular Price for 128 oz is $54.99. Today's price is $41.24!
- Strong UV protection on vinyl, rubber, leather and plastic
- Leaves behind a beautiful matte finish that is not greasy, shiny or oily
- Treated surfaces resist dust, soiling, staining and also repel water
- Most commonly used on interior dashboards, center consoles, door trim, and leather seats
- Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
- For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
Today's Daily special (September 1, 2009) is Poorboy's World Trim Restorer.
- Restores faded, neglected trim that has been over exposed to the elements
- Works best on rubber, vinyl and plastic trim
- Apply thicker for some gloss or buff dry to desired matte finish
- For maximum results, prep the surface you plan on restoring with a degreaser like Total Auto Wash
Today's Daily special (September 3, 2009) is Chemical Guys Fabric Clean.
Regular Price for 16 oz is $6.99. Today's price is $5.24!
- Powerful concentrated fabric cleaner and deodorizer that works wonders on carpet and upholstery
- Dilute down to an 8:1 ratio with distilled water, or use full strength for stubborn stains
- We recommend using a brush to agitate stubborn stains in fabric and carpets
- For easy dilution and usability, we recommend a 22 oz spray bottle
Today's Daily special (September 4, 2009) is Plexus Plastic Polish, Cleaner & Protectant.
Regular Price for 13 oz is $17.99. Today's price is $14.49!
- Clean, polish and protect all of your plastic surfaces, leaving behind anti-static properties
- Ideal for clear plastics, such as gauges, headlights, tail lights, clear bras and plastic windows
- For best application, apply to a plush microfiber towel, then gently wipe the plastic
Today's Daily special (September 5, 2009) is Chemical Guys Hose Free Eco Wash.
- Perfect for mobile detailers, enthusiasts without access to a hose or washing in a garage
- All you need is to fill up 2 buckets of water and you can wash your car, no water source needed
- Best applied with a plush microfiber towel, grout sponge or sheepskin wash mitt
- Environmentally friendly
Today's Daily special (September 6, 2009) is Poorboy's World Spray & Rinse.
Regular Price for 32 oz is $15.99. Today's price is $11.99!
- Powerful, acidic wheel cleaner designed to work best on alloy, clear coated wheels
- Dilute down to a 6:1 ratio for regular maintenance, use a stronger concentration as needed
- Works best when an E-Z Detail Brush is used in conjunction with PBW Spray & Rinse
- Protect your just cleaned wheels with Poorboy's World Wheel Sealant for easy maintenance
Today's Daily special (September 7, 2009) is Chemical Guys Wheel & Rim Citrus Cleaner.
- Citrus based wheel cleaner that is safe to use on virtually any wheel surface
- Concentrated solution makes this a great value as you can dilute it down 7:1 with water
- Works best when an E-Z Detail Brush is used in conjunction with Wheel & Rim Citrus Cleaner
Today's Daily special (September 8, 2009) is Chemical Guys Citrus Wash and Clear.
Regular Price for 128 oz is $24.99. Today's price is $19.00!
- One of our most versatile shampoos that can strip off previous coats of protection or maintain it
- A great sudsing shampoo makes it a hit in foam guns, great lubricity and powerful cleaners
- Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
