NEW!!!! Daily Specials at Detailed Image
Old Jan 9, 2010 | 06:47 AM
  #561
Detailed Image's Avatar
Detailed Image
Detailed Image
Today's Daily special (January 9, 2010) is DI Microfiber Ultra Plush Two Sided Towel.
Regular Price for 16" x 16" is $5.99. Today's price is $4.43!
  • Our most popular towel for applying quick detailers, plush on one side and medium nap on the other
  • Works excellent as an interior duster towel which you can easily store in your glove compartment
  • Perfect for giving those final wipe downs after removing a sealant or wax
  • Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent
Old Jan 10, 2010 | 08:11 AM
  #562
Detailed Image
Detailed Image
Today's Daily special (January 10, 2010) is Chemical Guys Silk Shine Dressing & Protectant.
Regular Price for 16 oz is $8.99. Today's price is $6.65!
  • Very versatile dressing that restores vinyl, rubber and tires to a beautiful low gloss finish
  • Properly protect your vinyl and rubber surfaces from UV fading with CG Silk Shine Dressing
  • To avoid over spray, we recommend misting Silk Shine Dressing into a microfiber towel to apply
  • We recommend using a 4oz pump spray bottle to apply a thin, even layer of dressing
Old Jan 12, 2010 | 07:42 AM
  #563
Detailed Image
Detailed Image
Today's Daily special (January 12, 2010) is Poorboy's World Wheel Sealant.
Regular Price for 8 oz is $17.99. Today's price is $12.77!
  • Minimize the amount of stubborn brake dust and road contamination built up on your wheels
  • Easily clean and maintain your wheels to a like new condition when protected with Wheel Sealant
  • One jar will last dozens of applications when applied correctly. The thinner the coat the better.
  • Cleans, restores, protects and enhances gloss all in one simple step.
  • Very easy to apply and remove. Once removed, the surface of your wheels is very slick.
  • Apply with a foam applicator pad and remove with a clean microfiber towel
Old Jan 14, 2010 | 08:00 AM
  #564
Detailed Image
Detailed Image
Today's Daily special (January 14, 2010) is Lake Country Hydro Tech Tangerine Ultra Fine Polishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.29!
Regular Price for 5.5 inch is $8.99. Today's price is $6.38!
Regular Price for 4 inch is $4.99. Today's price is $3.72!
  • Great polishing power with the ability to finish down haze and marring free
  • Hydro Tech foam keeps more polish on the surface of the pad for long work time
  • Experience less dusting than traditional foam pads due to less product buildup
  • Save time and improve your results!
Old Jan 15, 2010 | 06:14 AM
  #565
Detailed Image
Detailed Image
Today's Daily special (January 15, 2010) is Poorboy's World Leather Stuff.
Regular Price for 16 oz is $17.99. Today's price is $13.40!
  • An amazing one step solution for leather. Cleans, lightly conditions, and UV protects!
  • Restores and leaves behind a pleasant leather scent
  • Easy to apply and remove, while leaving behind a like new matte finish
  • Also works well on vinyl and rubber surfaces throughout the vehicle and home
  • Best applied with a terry cloth applicator and wiped to desired finish with a microfiber towel
Old Jan 16, 2010 | 07:50 AM
  #566
Detailed Image
Detailed Image
Today's Daily special (January 16, 2010) is Lake Country Snappy Clean Pad Cleaner.
Regular Price is $1.49. Today's price is $1.07!
  • A citrus degreaser designed to help release product and contamination from foam pads
  • Simply pour into a 5 gallon bucket of water and allow your foam pads and applicators to soak
  • To further the cleaning, massage the pads while soaking, rinse with pressured water, repeat
Old Jan 17, 2010 | 06:52 AM
  #567
Detailed Image
Detailed Image
Today's Daily special (January 17, 2010) is Dodo Juice Born to be Mild Shampoo.
Regular Price for 250 ml is $16.99. Today's price is $14.67!
Regular Price for 500 ml is $32.99. Today's price is $27.84!
  • One of the best shampoos we've tested in terms of lubricity and maximizing your coats of protection
  • Highly concentrated formula means only a little bit of product is needed to achieve great results
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Old Jan 18, 2010 | 12:32 PM
  #568
Detailed Image
Detailed Image
Today's Daily special (January 18, 2010) is DI Microfiber All Purpose Towel.
Regular Price for 16" x 16" is $3.99. Today's price is $2.95!
  • Our most versatile microfiber towel, most commonly used to apply and remove a variety of products
  • Easily remove polish residue, glazes, sealants and waxes with the medium nap microfiber towel
  • Works great for applying interior care products, specifically interior protectants
  • Remove the tag to minimize adding any imperfections to your paint
Old Jan 19, 2010 | 07:19 AM
  #569
Detailed Image
Detailed Image
Today's Daily special (January 19, 2010) is DI Accessories Gentle Fine Grade Clay.
Regular Price for 180 g is $17.99. Today's price is $13.13!
  • Safely and effectively remove tar, sap, paint over spray and more
  • Fine grade clay bars will not mar your finish when used properly
Old Jan 20, 2010 | 06:56 AM
  #570
Detailed Image
Detailed Image
Today's Daily special (January 20, 2010) is Chemical Guys Hose Free Eco Wash.
Regular Price for 16 oz is $12.99. Today's price is $9.61!
  • Perfect for mobile detailers, enthusiasts without access to a hose or washing in a garage
  • All you need is to fill up 2 buckets of water and you can wash your car, no water source needed
  • Best applied with a plush microfiber towel, grout sponge or sheepskin wash mitt
  • Environmentally friendly
Old Jan 21, 2010 | 07:12 AM
  #571
Detailed Image
Detailed Image
Today's Daily special (January 21, 2010) is Chemical Guys Extreme Offensive Odor Eliminator - Concentrated.
Regular Price for 16 oz is $9.99. Today's price is $7.39!
  • Remove odors from your interior by killing the bacteria causing the foul smell
  • Powerful concentrated solution can be diluted down 2:1 with water and still maintain effectiveness
  • Leaves behind a fresh apple scent that lingers for days
  • To maximize your product, we recommend using a 4oz pump spray bottle to dispense
Old Jan 22, 2010 | 09:08 AM
  #572
Detailed Image
Detailed Image
Today's Daily special (January 22, 2010) is Poorboy's World Quick Wax Plus (QW+).
Regular Price for 16 oz is $12.99. Today's price is $9.22!
  • Best applied just after washing to enhance the depth and gloss and protect the paint
  • Very easy to apply and remove when applied correctly
  • Applies in both the sun or the shade without difficult removal
  • Also works well on chrome, polished aluminum and wheels
  • Best applied with a plush microfiber towel to minimize any micro-marring in the paint
Old Jan 23, 2010 | 07:37 AM
  #573
Detailed Image
Detailed Image
Today's Daily special (January 23, 2010) is Poorboy's World Spray & Wipe (S&W).
Regular Price for 16 oz is $8.99. Today's price is $6.78!
Regular Price for 32 oz is $14.99. Today's price is $10.79!
Regular Price for 128 oz is $32.99. Today's price is $26.96!
  • Extremely versatile product that is a favorite amongst professional detailers
  • Quick and easy waterless wash product for lightly contaminated vehicles
  • Excellent clay bar lubricant, even diluted at a 1:1 ratio with distilled water
  • Perfect product to keep in your glove compartment to clean up emergency bird bombs, sap, tar, etc.
  • For maximum efficiency and convenient storage use in a 4oz pump spray bottle
Old Jan 24, 2010 | 12:02 PM
  #574
Detailed Image
Detailed Image
Today's Daily special (January 24, 2010) is Meguiar's Vinyl and Rubber Cleaner and Conditioner M40.
Regular Price for 16 oz is $11.99. Today's price is $8.93!
  • Clean, condition and UV protect in one step
  • Perfect for dash boards, consoles, doors, exterior trim, arm rests, door and window seals and more
  • Apply with a microfiber towel or applicator pad
Old Jan 25, 2010 | 10:32 AM
  #575
Detailed Image
Detailed Image
Today's Daily special (January 25, 2010) is Meguiar's Speed-Cut Compound M95.
Regular Price for 32 oz is $17.99. Today's price is $13.31!
  • Very effective at cutting through deeper imperfections
  • Follow up with a finer polish and pad combo, such as Meguiar's 205
  • Commonly used with an orange light cutting pad, yellow cutting pad or purple foamed wool pad
Old Jan 26, 2010 | 07:26 AM
  #576
Detailed Image
Detailed Image
Today's Daily special (January 26, 2010) is Dodo Juice Red Mist Tropical Protection Detailer.
Regular Price for 250 ml is $16.99. Today's price is $12.57!
  • Extend the protection of any sealant or wax
  • Increase gloss and depth of your paint, perfect for after a wash
  • Promotes tight water beading which helps minimize water spots
  • Applies and removes easy with a plush microfiber towel
Old Jan 27, 2010 | 07:43 AM
  #577
Detailed Image
Detailed Image
Today's Daily special (January 27, 2010) is Poorboy's World Natural Look.
Regular Price for 16 oz is $10.99. Today's price is $7.91!
  • An outstanding 1 step product that cleans, restores and UV protects
  • Works best on leather, vinyl, rubber, plastic, tires and more
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Best applied with a foam applicator pad and removed with a microfiber towel
Old Jan 28, 2010 | 08:13 AM
  #578
Detailed Image
Detailed Image
Today's Daily special (January 28, 2010) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.25!
  • One of the most popular used wash mediums by professional detailers
  • Very soft and durable, while being able to hold tons of suds and water helps reduce imperfections
  • One of the best features of the grout sponge is that it releases contamination very easily
  • For maximum results, use in combination with a Grit Guard bucket insert
Old Jan 29, 2010 | 09:49 AM
  #579
Detailed Image
Detailed Image
Today's Daily special (January 29, 2010) is Lake Country Rotary Hook & Loop 5" Backing Plate.
Regular Price for 125 mm is $16.99. Today's price is $12.23!
  • Use with virtually any rotary buffer and 5.5" Hook and Loop Pads or larger
  • Get optimal results with the 5.5" Lake Country foam and wool pads
  • Allows you to easily put on new pads and pull of the old ones in just seconds
Old Jan 30, 2010 | 08:30 AM
  #580
Detailed Image
Detailed Image
Today's Daily special (January 30, 2010) is Poorboy's World Trim Restorer.
Regular Price for 16 oz is $15.99. Today's price is $11.91!
  • Restores neglected rubber, vinyl and plastic trim that has faded over time
  • For maximum results, prep the trim you plan on restoring with a degreaser and apply multiple thin coats
