NEW!!!! Daily Specials at Detailed Image
Old Feb 14, 2010 | 07:17 AM
  #601
Detailed Image's Avatar
Detailed Image
Detailed Image
Originally Posted by maXmood
@ Greg, 1 more question... does the porter cable comes with 220-240v or is it 110v?
cuz we run 220-240v here.
It is the 110v model here.
Greg @ DI
Old Feb 16, 2010 | 08:43 AM
  #602
Detailed Image
Detailed Image
Today's Daily special (February 16, 2010) is Lake Country Hydro Tech Cyan Light Cutting and Polishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.29!
Regular Price for 5.5 inch is $8.99. Today's price is $6.56!
Regular Price for 4 inch is $4.99. Today's price is $3.54!
  • Powerful cutting action but the ability to finish down haze free
  • Hydro Tech foam keeps more polish on the surface of the pad for long work time
  • Experience less dusting than traditional foam pads due to less product buildup
  • Save time and improve your results!
Old Feb 16, 2010 | 11:21 AM
  #603
maXmood's Avatar
maXmood
Under Boost!
Bongous don't ship flammables ....
left with no choice.
Old Feb 17, 2010 | 09:09 AM
  #604
Detailed Image
Detailed Image
You probably won't be able to ship any aerosol containers across the border with any company but the rest of the products shouldn't be a problem. Let me know if you have any other questions.
Greg @ DI
Old Feb 17, 2010 | 09:25 AM
  #605
Detailed Image
Detailed Image
Today's Daily special (February 17, 2010) is Lake Country & Backing Plate for Porter Cable 7424.
Regular Price for 125 mm is $16.99. Today's price is $12.57!
  • Use with Porter Cable 7424 XP and 5.5" Hook and Loop Pads or larger
  • Get optimal results with the 5.5" Lake Country foam and wool pads
  • Allows you to easily put on new pads and pull of the old ones in just seconds
Old Feb 18, 2010 | 12:15 AM
  #606
maXmood's Avatar
maXmood
Under Boost!
Greg @ DI
I actually did ship couple of air filter recharge kits from K&N, and both bottles are liquid. but they were shipped through USPS. and i think that's the only way of doing it..
Old Feb 18, 2010 | 07:45 AM
  #607
Detailed Image
Detailed Image
Today's Daily special (February 18, 2010) is DI Accessories Sheepskin Wash Mitt.
Regular Price is $9.99. Today's price is $7.39!
  • Perfect wash medium to help minimize adding swirls and other imperfections to the paint
  • The natural fibers help pull contamination away from the surface without grinding them in
  • When done using, rinse any contamination using free flowing water than hang dry with leather hoop
  • For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
Old Feb 19, 2010 | 07:43 AM
  #608
Detailed Image
Detailed Image
Today's Daily special (February 19, 2010) is Meguiar's Professional DA Polisher Backing Plate W67DA.
Regular Price for 5" is $19.99. Today's price is $14.89!
  • Soft core foam allows for easier maneuverability compared to stiffer backing plates
  • Works with any polisher with a 5/16th shaft (such as the Porter Cable 7424XP)
  • Durable one piece construction ensures a long life
  • Works best with 5.5" pads or larger
Old Feb 20, 2010 | 10:21 AM
  #609
Detailed Image
Detailed Image
Today's Daily special (February 20, 2010) is 303 High Tech Fabric Guard.
Regular Price for 16 oz is $14.99. Today's price is $11.17!
Regular Price for 32 oz is $26.99. Today's price is $19.43!
Regular Price for 128 oz is $99.99. Today's price is $74.49!
  • Protects carpet, canvas and upholstery from staining by repelling liquids
  • Makes maintaining interior carpets, floor mats and canvas seats significantly easier when protected
  • Works great on canvas convertible tops and outdoor patio furniture
  • For maximum efficiency use in a 4oz pump spray bottle
Old Feb 21, 2010 | 05:24 PM
  #610
Detailed Image
Detailed Image
sorry for the late post Today's Daily special (February 21, 2010) is Meguiar's Ultra Finishing Polish M205.
Regular Price for 32 oz is $27.99. Today's price is $20.15!
Regular Price for 128 oz is $84.99. Today's price is $61.19!
  • Removes swirls and light imperfections on any type of paint
  • Finishes down haze, hologram and marring free
  • Perfect follow up to Meguiar's Ultra Cut Compound 105
  • Commonly used with a white polishing pad or a black finishing pad
Old Feb 23, 2010 | 07:39 AM
  #611
Detailed Image
Detailed Image
Today's Daily special (February 23, 2010) is Poorboy's World Quick Wax Plus (QW+).
Regular Price for 16 oz is $12.99. Today's price is $9.22!
  • Best applied just after washing to enhance the depth and gloss as well as add protection to the paint
  • Very easy to apply and remove when applied correctly, either in the shade or sun
  • Also works well on chrome, polished aluminum and wheels
  • Best applied with a plush microfiber towel to minimize any micro-marring in the paint
Old Feb 24, 2010 | 10:55 AM
  #612
Detailed Image
Detailed Image
Today's Daily special (February 24, 2010) is P21S Finish Restorer.
Regular Price for 75 ml is $9.99. Today's price is $8.27!
  • Clean, restore and polish your wheels and metal trim in one easy step
  • A little goes a long way, work a small amount of product into the metal with light pressure
  • We recommend using a foam applicator pad for application
  • Use a two sided metal polishing towel to remove excess product and to buff to desired finish
Old Feb 25, 2010 | 06:53 AM
  #613
Detailed Image
Detailed Image
Today's Daily special (February 25, 2010) is Lake Country Blue Fine Finishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.44!
Regular Price for 4 inch is $4.99. Today's price is $3.59!
  • Our softest foam pad, the blue fine finishing pad, designed to apply sealants and liquid waxes
  • Also commonly used to burnish the paint to a high gloss with a gloss enhancing polish
  • Jet Seal 109 is one of the most popular sealants to apply with a blue pad
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old Feb 26, 2010 | 11:38 AM
  #614
Detailed Image
Detailed Image
Today's Daily special (February 26, 2010) is Chemical Guys Leather Scent.
Regular Price for 16 oz is $8.99. Today's price is $6.47!
  • Fresh leather smell
  • Spray on fabrics or wipe on interior
  • Eliminates bad smells by breaking down odor causing bacteria
Old Feb 28, 2010 | 08:19 AM
  #615
Detailed Image
Detailed Image
Today's Daily special (February 28, 2010) is Dodo Juice Red Mist Tropical Protection Detailer.
Regular Price for 250 ml is $16.99. Today's price is $12.57!
  • Extend the protection of any sealant or wax
  • Increase gloss and depth of your paint, perfect for after a wash
  • Promotes tight water beading which helps minimize water spots
  • Applies and removes easy with a plush microfiber towel
Old Mar 1, 2010 | 03:29 PM
  #616
Detailed Image
Detailed Image
Today's Daily special (March 1, 2010) is Lake Country Hydro Tech Tangerine Ultra Fine Polishing Pad.
Regular Price for 5.5 inch is $8.99. Today's price is $6.65!
Regular Price for 4 inch is $4.99. Today's price is $3.69!
  • Great polishing power with the ability to finish down haze and marring free
Old Mar 2, 2010 | 07:00 AM
  #617
Detailed Image
Detailed Image
Today's Daily special (March 2, 2010) is DI Microfiber All Purpose Towel.
Regular Price for 16" x 16" is $3.99. Today's price is $2.91!
  • Our most versatile microfiber towel, most commonly used to apply and remove a variety of products
  • Easily remove polish residue, glazes, sealants and waxes with the medium nap microfiber towel
  • Works great for applying interior care products, specifically interior protectants
  • Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent
  • Remove the tag to minimize adding any imperfections to your paint
Old Mar 3, 2010 | 12:30 PM
  #618
Detailed Image
Detailed Image
Today's Daily special (March 3, 2010) is Leatherique Rejuvenator Oil.
Regular Price for 16 oz is $29.99. Today's price is $22.34!
Regular Price for 32 oz is $49.99. Today's price is $35.49!
  • Detailed Image's best leather care product to restore neglected, faded, hardened leather
  • Restores oils and proteins that are naturally found in leather for a soft and supple feel
  • Works best when allowed to penetrate leather for up to 48 hours, ideally in the heat
  • Using a hair drier to heat up the leather surface allows for maximum penetration and best results
  • Apply Rejuvenator Oil by massaging the product into the leather with your bare hands
  • Must be removed by following up with Leatherique Prestine Clean
Old Mar 3, 2010 | 12:34 PM
  #619
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Do you have anything to "enrich" or brighten up carbon fiber parts?
Old Mar 4, 2010 | 08:45 AM
  #620
Detailed Image
Detailed Image
I'm not sure if it's really possible to brighten or enrich carbon fiber. However if it's coated like most carbon fiber is you can polish it just like your paint. By removing ultra fine scratches, oxidation, etc. the surface is more optically clear and thus more light can pass through. This gives you a better reflection and the original shine back. I would suggest starting off with a light polish like Menzerna PO106FA Nano Polish (Super Finish) and use more aggressive ones as needed assuming your carbon fiber is clear coated. Let me know if you have any other questions.
Greg @ DI
