NEW!!!! Daily Specials at Detailed Image
Old May 6, 2010 | 06:13 AM
  #661
Detailed Image's Avatar
Detailed Image
Detailed Image
Today's Daily special (May 6, 2010) is Meguiar's PlastX Clear Plastic Cleaner and Polish.
Regular Price for 10 oz is $7.99. Today's price is $5.75!
  • Ideal for use on headlights, tail lights, motorcycle windshields, convertible windows and much more
  • Restore clarity to clear plastics by removing stains and imperfections
  • Leaves behind a polymer protection for easier maintenance
Old May 7, 2010 | 05:34 AM
  #662
Detailed Image
Detailed Image
Today's Daily special (May 7, 2010) is Poorboy's World Trim Restorer.
Regular Price for 16 oz is $15.99. Today's price is $11.35!
  • Restores neglected rubber, vinyl and plastic trim that has faded over time
  • For maximum results, prep the trim you plan on restoring with a degreaser and apply multiple thin coats
  • Best applied with a foam applicator pad and removed with a microfiber towel
Old May 11, 2010 | 11:44 AM
  #663
Detailed Image
Detailed Image
Today's Daily special (May 11, 2010) is Lake Country & Backing Plate for Porter Cable 7424.
Regular Price for 125 mm is $16.99. Today's price is $12.57!
  • Use with Porter Cable 7424 XP and 5.5" Hook and Loop Pads or larger
  • Get optimal results with the 5.5" Lake Country foam and wool pads
  • Allows you to easily put on new pads and pull of the old ones in just seconds
Old May 12, 2010 | 07:35 AM
  #664
Detailed Image
Detailed Image
Today's Daily special (May 12, 2010) is Chemical Guys Pete's 53 Black Pearl Signature Paste Wax.
Regular Price for 8 oz is $53.99. Today's price is $38.33!
  • A hidden gem of carnauba waxes, offering excellent depth and gloss and easy application
  • Excels on darker colored vehicles, but works well on any color, metallic and non-metallic
  • Easy to apply and remove when applied properly, which is as thin as possible
Old May 13, 2010 | 10:59 AM
  #665
Detailed Image
Detailed Image
Today's Daily special (May 13, 2010) is Lake Country Orange Light Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.39!
Regular Price for 5.5 inch is $8.99. Today's price is $6.47!
Regular Price for 4 inch is $4.99. Today's price is $3.54!
  • A light cutting pad designed to remove moderate swirls and scratches with an abrasive polish
  • Menzerna Super Intensive Polish (SIP) is one of the most popular products to use with an orange pad
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old May 14, 2010 | 10:54 AM
  #666
Detailed Image
Detailed Image
Today's Daily special (May 14, 2010) is DI Accessories Gentle Fine Grade Clay.
Regular Price for 200 g is $21.99. Today's price is $16.38!
  • Safely and effectively remove tar, sap, paint over spray and more
  • Fine grade clay bars will not mar your finish when used properly
  • We recommend using Dodo Juice Born Slippy as your clay lube
Old May 16, 2010 | 09:51 AM
  #667
Detailed Image
Detailed Image
Today's Daily special (May 16, 2010) is Dodo Juice Banana Armour Hard Wax.
Regular Price for 250 ml is $69.99. Today's price is $54.72!
Regular Price for 30 ml is $13.99. Today's price is $10.21!
  • A Dodo Juice hard carnauba wax designed to work exceptionally well on warmer colored vehicles
  • Extremely easy to apply and remove, especially when applied in thin layers
  • Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
  • Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
  • Apply with a foam applicator pad and remove with a plush microfiber towel
Old May 17, 2010 | 04:39 PM
  #668
Detailed Image
Detailed Image
Today's Daily special (May 17, 2010) is Lake Country Black Finishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.29!
Regular Price for 5.5 inch is $8.99. Today's price is $6.38!
Regular Price for 4 inch is $4.99. Today's price is $3.64!
  • A finishing pad, designed to bring the paint to its maximum depth and gloss with a finishing polish
  • Also can be used to apply a paint cleaner, glaze or sealant
  • Menzerna PO85RD is one of the most popular polishes to use with a black finishing pad
Old May 18, 2010 | 11:48 AM
  #669
Detailed Image
Detailed Image
Today's Daily special (May 18, 2010) is Lake Country Tire Dressing Applicator.
Regular Price is $1.99. Today's price is $1.47!
  • A perfect applicator pad to apply your favorite tire dressing
  • Firm foam design that will not shred like cheaper tire dressing applicator pads
  • Works excellent with Poorboy's Bold 'n Bright water based tire dressing
Old May 19, 2010 | 07:27 AM
  #670
Detailed Image
Detailed Image
Today's Daily special (May 19, 2010) is Chemical Guys Luber.
Regular Price for 16 oz is $9.99. Today's price is $7.39!
Regular Price for 128 oz is $26.99. Today's price is $20.73!
  • An outstanding clay bar lubricant formulated to work specifically with your clay bar
  • Can also be used as a quick detailer to remove a light dusting along
  • Works great with the Chemical Guys Fine Grade Clay Bar
Old May 20, 2010 | 06:01 AM
  #671
Detailed Image
Detailed Image
Today's Daily special (May 20, 2010) is Chemical Guys Water Spot Remover.
Regular Price for 16 oz is $19.99. Today's price is $14.39!
  • Easily remove water spots and mineral deposits from your paint, chrome and glass
  • We recommend using a foam applicator pad along with some elbow grease for application
Old May 21, 2010 | 08:05 AM
  #672
Detailed Image
Detailed Image
Today's Daily special (May 21, 2010) is Dodo Juice Sour Power Gloss Enhancing Shampoo.
Regular Price for 250 ml is $13.99. Today's price is $10.35!
  • Perfect maintenance shampoo that enhances gloss and depth
  • Lots of lubricity and slickness to help minimize adding imperfections
  • Concentrated formula means only a little product is needed per wash
  • Best used with a grout sponge or sheepskin wash mitt
Old May 22, 2010 | 10:22 AM
  #673
Detailed Image
Detailed Image
Today's Daily special (May 22, 2010) is Lake Country White Polishing Pad.
Regular Price for 5.5 inch is $8.99. Today's price is $6.65!
  • A polishing pad designed to remove minor surface imperfections with an abrasive polish on a buffer
  • Menzerna PO106FF polish is one of the most popular products to use with the white pad
Old May 23, 2010 | 11:19 AM
  #674
Detailed Image
Detailed Image
Today's Daily special (May 23, 2010) is Optimum (OPT) No Rinse Wash & Shine New Formula (ONR).
Regular Price for 32 oz is $15.99. Today's price is $12.83!
Regular Price for 128 oz is $39.99. Today's price is $33.23!
  • Improved formula released in Feb 2010, experience increased lubricity and a more pleasant smell
  • Properly wash your car without the need for a hose source
  • Can also be used as a quick detailer and clay bar lubricant
  • Go-to product for many professional detailers
Old May 25, 2010 | 11:00 AM
  #675
Detailed Image
Detailed Image
Today's Daily special (May 25, 2010) is Gilmour Brass Connector High Flow Shut-off Valve.
Regular Price is $6.99. Today's price is $5.17!
  • Easily kill water flow with a simple twist of a **** instead of walking back to the hose source
  • Perfect for removing your hose nozzle or foam gun to utilize the sheeting method
Old May 26, 2010 | 06:32 AM
  #676
Detailed Image
Detailed Image
Today's Daily special (May 26, 2010) is Chemical Guys Silk Shine Dressing & Protectant.
Regular Price for 16 oz is $8.99. Today's price is $6.47!
  • Very versatile dressing that restores vinyl, rubber and tires to a beautiful low gloss finish
  • Properly protect your vinyl and rubber surfaces from UV fading with CG Silk Shine Dressing
  • To avoid over spray, we recommend misting Silk Shine Dressing into a microfiber towel to apply
  • We recommend using a 4oz pump spray bottle to apply a thin, even layer of dressing
Old May 27, 2010 | 12:31 PM
  #677
Detailed Image
Detailed Image
Today's Daily special (May 27, 2010) is Black WOW Black WOW.
Regular Price for 4 oz is $24.99. Today's price is $19.50!
  • Restore faded and neglected trim pieces, while leaving behind a bold even finish
  • Removes product residue from trim and lasts through multiple washes
  • Only a tiny bit of product is needed, use sparingly
Old May 28, 2010 | 06:32 AM
  #678
Detailed Image
Detailed Image
Today's Daily special (May 28, 2010) is Chemical Guys Citrus Wash.
Regular Price for 16 oz is $9.99. Today's price is $7.09!
Regular Price for 128 oz is $32.99. Today's price is $24.41!
  • Ultra concentrated paintwork cleaning shampoo designed to strip off protection to start fresh
  • Powerful concentrated formula only requires 1oz of product per gallon of water to effectively remove layers of protection
  • Works well in a Gilmour Foam Gun
Old May 29, 2010 | 06:19 AM
  #679
Detailed Image
Detailed Image
Today's Daily special (May 29, 2010) is Chemical Guys M-Seal.
  • One of the best bang for the buck, pure sealants for under $20
  • M-Seal not only protects your paint, but leaves behind a great shine and sharp reflections
  • When using a buffer, best applied with a blue fine finishing pad
Old May 30, 2010 | 08:27 AM
  #680
Detailed Image
Detailed Image
Today's Daily special (May 30, 2010) is Chemical Guys Fade 2 Black.
Regular Price for 13 oz is $12.99. Today's price is $9.48!
  • One of the most unique trim restorers that turns faded trim back to a deep factory black finish
  • Perfect option for wheel wells, engine bay dressing, tire dressing and exterior trim pieces
