NEW!!!! Daily Specials at Detailed Image
Today's Daily special (September 21, 2011) is Chemical Guys HoneyDew Snow Foam.
Regular Price for 16 oz is $9.99. Today's price is $7.39!
Regular Price for 128 oz is $29.99. Today's price is $22.19!
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
- Extremely dense high foam shampoo that coats your entire vehicle in foam
- Utilizes a high tech PPM (Part Per Million) formula that produces millions of close grouping bubbles
- Works great in the Gilmour Foamaster II Foam Gun
- Universally pleasant smell guaranteed to put a smile on your face
- Suds.....Suds.....and more SUDS!!!!
Today's Daily special (September 22, 2011) is Dodo Juice Born Slippy Clay Lube Concentrate.
Regular Price for 250 ml is $12.99. Today's price is $9.22!
- Ultra concentrated solution makes for over 2.5 liters of clay lube
- Dilute up to a 10:1 ratio with water while remaining super slick
- Wipes away streak free and is safe for nearly any surface
- We recommend picking up a 22oz spray bottle for proper dilution
Today's Daily special (September 23, 2011) is DI Accessories Polishing Pal.
Regular Price is $12.99. Today's price is $9.48!
- Even distribution of any product and better results from hand applications
- Get the same variety in cutting and finishing pads as you would with a buffer using 4" pads!
Today's Daily special (September 26, 2011) is Meguiar's Quik Interior Detailer.
Regular Price for 16 oz is $6.99. Today's price is $5.10!
Regular Price for 128 oz is $21.99. Today's price is $16.05!
- Clean and protect plastics, vinyl, leather, rubber, metal, gauges, audio equipment and more
- The one interior quick detailer you'll need to keep your car looking and smelling fresh
- Best applied with a quality microfiber towel
- Pick up a 4 oz pump spray bottle to easily store this in your glove compartment for emergency clean ups
Today's Daily special (September 27, 2011) is 303 Fabric & Vinyl Cleaner.
Regular Price for 32 oz is $14.99. Today's price is $11.09!
Regular Price for 128 oz is $42.99. Today's price is $31.38!
- Concentrated all purpose cleaner for carpets, upholstery, vinyl, rubber, leather, plastic and much more
- Cleaning action increases with warm water, agitation, and longer dwell time
- Safely removes oil, grease, ink, coffee, tea, wine, juice, blood, and tons more
- Dilute into a 22oz empty spray bottle or a handy 4oz pump spray bottle
Today's Daily special (September 28, 2011) is Lake Country Tire Dressing Applicator.
Regular Price is $1.99. Today's price is $1.41!
- A perfect applicator pad to apply your favorite tire dressing
- Firm foam design that will not shred like cheaper tire dressing applicator pads
- Works excellent with Poorboy's Bold 'n Bright water based tire dressing
Today's Daily special (September 29, 2011) is DI Microfiber Waffle Weave Drying Towel.
Regular Price for 36" x 24" is $17.99. Today's price is $13.40!
- One of the best options for drying your vehicle and most commonly used by professional detailers
- The waffle weave texture helps pull contamination away from the surface compared to a flat chamois
- Our microfiber waffle weave towel has silk edging to minimize adding imperfections
- This towel can hold up to 5 times its weight with water
- We recommend using the sheeting method prior to drying with the towel for maximum efficiency
- Always wash your microfiber products prior to first use
Today's Daily special (September 30, 2011) is DI Accessories Disposable Floor Mat.
Regular Price for 10 pack is $5.99. Today's price is $4.46!
- Durable mats to help prevent adding stains to clean carpets during a detail
- Ensure your carpets look their best when you deliver the vehicle to your customer
Today's Daily special (October 3, 2011) is DI Accessories Reclosable Storage Bag.
Regular Price for 24" x 24" is $2.99. Today's price is $2.18!
- Simple solution for storing microfiber towels!
- The large 24" x 24" size offers flexibility to accommodate dozens of towels
- Thick reclosable bags make it a durable long term solution to storage needs
Today's Daily special (October 4, 2011) is Chemical Guys Polishing Pad Conditioner.
Regular Price for 16 oz is $9.99. Today's price is $7.44!
- Get the most out of polishing by keeping your pads fresh with the Foam Pad Conditioner
- Simply give a quick mist to your buffing pad prior to applying your polish to the pad
- Do not saturate your pad with product, only a mist is needed to prime the pad initially
Regular Price for 16 oz is $19.99. Today's price is $15.20!
Regular Price for 32 oz is $29.99. Today's price is $22.34!
- Detailed Image's best leather cleaner with light conditioners, perfect for maintaining leather
- Restores oils and proteins that are naturally found in leather for a soft and supple feel
- Cleans to a like new, matte finish that has no greasy or oily feel like other products
- Apply to your leather and let sit for 15 - 30 minutes, wipe with a warm damp towel and buff dry
- We recommend using a terry cloth application pad to help agitate the leather surface
- For maximum results, Prestine Clean is best used after Leatherique Rejuvenator Oil
Today's Daily special (October 6, 2011) is DI Accessories Sheepskin Wash Mitt.
Regular Price is $9.99. Today's price is $7.39!
- Perfect wash medium to help minimize adding swirls and other imperfections to the paint
- The natural fibers help pull contamination away from the surface without grinding them in
- When done using, rinse any contamination using free flowing water than hang dry with leather hoop
- For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
Today's Daily special (October 7, 2011) is DI Microfiber Mini-Towel.
Regular Price for 6" x 7" is $2.99. Today's price is $2.12!
- Works well at keeping glass and other surfaces clean and free of fingerprints and smudges
- Perfect for keeping your sunglasses clean and free of fingerprints
Today's Daily special (October 10, 2011) is Chemical Guys Citrus Wash.
Regular Price for 128 oz is $32.99. Today's price is $24.58!
- Ultra concentrated paintwork cleaning shampoo designed to strip off protection to start fresh
- Powerful concentrated formula only requires 1oz of product per gallon of water to effectively remove layers of protection
- Works well in a Gilmour Foam Gun
Today's Daily special (October 11, 2011) is Chemical Guys Citrus Wash Wheel & Rim Cleaner.
Regular Price for 16 oz is $8.99. Today's price is $6.94!
- Citrus based wheel cleaner that is safe to use on virtually any wheel surface
- Concentrated solution makes this a great value as you can dilute it down 7:1 with water
- Works best when an E-Z Detail Brush is used in conjunction with Wheel & Rim Citrus Cleaner
- Protect your just cleaned wheels with Poorboy's World Wheel Sealant for easy maintenance
Today's Daily special (October 12, 2011) is Poorboy's World Natty's Red Paste Wax.
Regular Price for 8 oz is $19.99. Today's price is $14.19!
- One of the top performing carnauba waxes for under $25 and looks outstanding on any color
- Leaves behind a ton of depth and gloss, especially when multiple coats have been applied
- Easy to apply and remove when applied properly with a foam applicator pad and removed with a microfiber towel
Today's Daily special (October 13, 2011) is DI Microfiber Black General Purpose Towel.
Regular Price for 16" x 16" is $3.99. Today's price is $2.83!
- Finally a great black microfiber towel is available to detailers!
- Paint safe and very effective towel inside and outside your vehicle
- Wash with the Chemical Guys Microfiber Wash Cleaning Detergent to help the towels last for years in great condition
- Store in a DI Accessories Reclosable Storage Bag to help prevent dust and dirt from collecting on the towel
Today's Daily special (October 14, 2011) is Meguiar's Ultra Finishing Polish M205.
Regular Price for 32 oz is $27.99. Today's price is $21.14!
Regular Price for 128 oz is $84.99. Today's price is $61.19!
Regular Price for 8 oz is $9.49. Today's price is $6.93!
- Removes swirls and light imperfections on any type of paint
- Finishes down haze, hologram and marring free
- Perfect follow up to Meguiar's Ultra Cut Compound 105
- Commonly used with a white polishing pad or a black finishing pad
Today's Daily special (October 17, 2011) is Chemical Guys HoneyDew Snow Foam.
Regular Price for 128 oz is $29.99. Today's price is $22.98!
Today's Daily special (October 18, 2011) is Chemical Guys Maxi Suds II.
Regular Price for 16 oz is $8.99. Today's price is $6.70!
Regular Price for 128 oz is $25.99. Today's price is $19.36!
- One of our best selling shampoos, lots of foam, great lubricity, and gentle cleaning power
- An addicting cherry scent that makes washing your car a pleasure
- Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
- High sudsing formula makes this a great option to use in foam guns
