NEW!!!! Daily Specials at Detailed Image
Today's Daily special (May 23, 2011) is Lake Country Hydro Tech Tangerine Ultra Fine Polishing Pad.
Regular Price for 6.5 inch is $11.99. Today's price is $8.75!
Regular Price for 5.5 inch is $9.99. Today's price is $7.44!
Regular Price for 4 inch is $5.99. Today's price is $4.31!
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
- Great polishing power with the ability to finish down haze and marring free
- Hydro Tech foam keeps more polish on the surface of the pad for long work time
- Experience less dusting than traditional foam pads due to less product buildup
- Save time and improve your results!
Today's Daily special (May 24, 2011) is Chemical Guys Maxi Suds II.
Regular Price for 16 oz is $8.99. Today's price is $6.56!
Regular Price for 128 oz is $25.99. Today's price is $19.36!
- One of our best selling shampoos, lots of foam, great lubricity, and gentle cleaning power
- An addicting cherry scent that makes washing your car a pleasure
- Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
- High sudsing formula makes this a great option to use in foam guns
Today's Daily special (May 25, 2011) is Lake Country Tire Dressing Applicator.
Regular Price is $1.99. Today's price is $1.48!
- A perfect applicator pad to apply your favorite tire dressing
- Firm foam design that will not shred like cheaper tire dressing applicator pads
- Works excellent with Poorboy's Bold 'n Bright water based tire dressing
Today's Daily special (May 26, 2011) is Meguiar's All Purpose Cleaner Plus D103.
Regular Price for 128 oz is $13.99. Today's price is $9.93!
- Best used to degrease engine bays, wheel wells, tires, interior clean ups, and much more
- Effective even at a 10:1 dilution ratio making this an extremely good value
- Works well in carpet extractors due to the low sudsing formula
- Dilute and dispense using a 22 oz trigger spray bottle
Today's Daily special (May 27, 2011) is DI Accessories Gentle Fine Grade Clay.
Regular Price for 200 g is $18.99. Today's price is $13.86!
Regular Price for 100 g is $10.99. Today's price is $8.02!
- Safely and effectively remove tar, sap, paint over spray and more
- Fine grade clay bars will not mar your finish when used properly
- We recommend using Dodo Juice Born Slippy as your clay lube
Today's Daily special (May 31, 2011) is Lake Country Hydro Tech Crimson Ultra Fine Finishing Pad.
Regular Price for 6.5 inch is $11.99. Today's price is $8.87!
Regular Price for 5.5 inch is $8.99. Today's price is $6.70!
Regular Price for 4 inch is $5.99. Today's price is $4.46!
- Bring out the maximum depth and gloss of any polish
- Use the Hydro Tech Crimson pads to apply finishing polishes, glazes or even sealants and waxes
- Experience longer work time and less dusting with less product absorption
Today's Daily special (June 1, 2011) is Optimum Car Wash.
Regular Price for 32 oz is $11.99. Today's price is $8.75!
Regular Price for 128 oz is $29.99. Today's price is $21.59!
- An outstanding shampoo that has great lubricity, plenty of suds, and gentle cleaners
- Works great as a maintenance shampoo to maximize the life of your sealant or wax
Today's Daily special (June 2, 2011) is Chemical Guys Jetseal 109.
Regular Price for 16 oz is $29.99. Today's price is $22.87!
- One of our best selling sealants due to how well rounded of a product Jet Seal 109 is
- Offers wax like depth and gloss, strong protection, ease of use, slick surface, and good durability
- Works great on any colored vehicle, light, dark, metallic or non-metallic
- Easy to apply and remove when applied properly, which is as thin as possible
- For maximum durability, allow the sealant to cure for 24 hours prior to applying another coat
- Best applied with a foam applicator pad and removed with a microfiber towel
- When using a buffer, best applied with a blue fine finishing pad
Today's Daily special (June 3, 2011) is P21S Gel Wheel Cleaner.
Regular Price for 500 ml Kit is $17.99. Today's price is $14.21!
Regular Price for 1000 ml is $22.99. Today's price is $18.16!
Regular Price for 5000 ml is $99.99. Today's price is $80.16!
- One of the safest, most effective, pH balanced wheel cleaners on the market
- Gel based formula allows the product to penetrate vertical surfaces for a more effective cleaning
- Perfect option for after market wheels as it is safe for virtually any wheel surface
- Works best when an E-Z Detail Brush is used in conjunction with P21S Gel Wheel Cleaner
- Follow up with Poorboy's World Wheel Sealant for wheels that are easier to maintain
Today's Daily special (June 6, 2011) is DI Microfiber Mini-Towel.
Regular Price for 6" x 7" is $2.99. Today's price is $2.15!
- Works well at keeping glass and other surfaces clean and free of fingerprints and smudges
- Perfect for keeping your sunglasses clean and free of fingerprints
Today's Daily special (June 7, 2011) is Chemical Guys Citrus Wash and Clear.
Regular Price for 16 oz is $8.99. Today's price is $6.38!
Regular Price for 128 oz is $24.99. Today's price is $20.34!
- One of our most versatile shampoos that can strip off previous coats of protection or maintain it depending on dilution
- A great sudsing shampoo makes it a hit in foam guns, lots of lubricity and powerful cleaners, makes it very effective
Today's Daily special (June 8, 2011) is TUF SHINE Tire Cleaner.
Regular Price for 22 oz is $9.99. Today's price is $7.29!
- Excellent tire cleaner that releases road grime and old tire dressing residue
- Use it with the TUF SHINE Tire Brush for optimal results
- Make sure you use this cleaner before applying the TUF SHINE Tire Clearcoat
Today's Daily special (June 9, 2011) is Chemical Guys GlossWorkz Paintwork Cleanser.
Regular Price for 16 oz is $12.99. Today's price is $10.21!
Regular Price for 128 oz is $42.99. Today's price is $32.84!
- Extends the protection of your sealant or wax while enhancing the gloss and depth of your paint
- Used like a shampoo, GlossWorkz is a pH balanced, biodegradable, detergent free and non-toxic paintwork cleanser
- Use 1 oz per 4 to 5 gallons of water
Today's Daily special (June 10, 2011) is Stoner Tarminator.
Regular Price for 10 oz is $5.99. Today's price is $4.37!
- Safely and effectively remove tar, grease and sap from painted surfaces
- Simply spray Tarminator onto the effected area, let dwell for a minute or two, then wipe clean
- Remember to protect the areas you use Tarminator on with a sealant or wax
Today's Daily special (June 12, 2011) is 303 High Tech Fabric Guard.
Regular Price for 16 oz is $12.99. Today's price is $9.68!
Regular Price for 32 oz is $22.99. Today's price is $16.55!
Regular Price for 128 oz is $79.99. Today's price is $60.00!
- Protects carpet, canvas and upholstery from staining by repelling liquids
- Makes maintaining interior carpets, floor mats and canvas seats significantly easier when protected
- Works great on canvas convertible tops and outdoor patio furniture
- For maximum efficiency use in a 4oz pump spray bottle
Today's Daily special (June 13, 2011) is Lake Country Orange Light Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.09!
Regular Price for 5.5 inch is $8.99. Today's price is $6.65!
Regular Price for 4 inch is $4.99. Today's price is $3.54!
- A light cutting pad designed to remove moderate swirls and scratches with an abrasive polish
- Menzerna Super Intensive Polish (SIP) is one of the most popular products to use with an orange pad
- We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (June 15, 2011) is DI Accessories Sheepskin Wash Mitt w/no thumb.
Regular Price is $8.99. Today's price is $6.47!
- Perfect wash medium to help minimize adding swirls and other imperfections to the paint
- The natural fibers help pull contamination away from the surface without grinding them in
- When done using, rinse any contamination using free flowing water than hang dry with leather hoop
- For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
Today's Daily special (June 16, 2011) is TUF SHINE Tire Brush.
Regular Price is $4.99. Today's price is $3.59!
- Great for deep cleaning the tires
- Use with the TUF SHINE Tire Cleaner or your favorite degreaser
- Strong yet gentle bristles
- Cleaning your tires is critical before applying any tire dressing, especially the TUF SHINE Tire Clearcoat
Today's Daily special (June 17, 2011) is DI Microfiber Great White Towel.
Regular Price for 16" x 24" is $6.99. Today's price is $5.21!
- The perfect work horse towel, that can remove product residue, as well as apply liquid products
- Larger 24" x 16" towel provides more surface area to collect and trap product, dust, dirt and more
- Silk edging helps minimize adding imperfections to delicate surfaces
- Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent
Today's Daily special (June 20, 2011) is TUF SHINE Applicator Sponge.
Regular Price is $1.99. Today's price is $1.45!
- Use this applicator to apply the TUF SHINE Tire Clearcoat
- Very soft and reusable, just rinse under water!
