NEW!!!! Daily Specials at Detailed Image
Today's Daily special (October 19, 2011) is Lake Country Hydro Tech Crimson Ultra Fine Finishing Pad.
Regular Price for 6.5 inch is $11.99. Today's price is $8.75!
Regular Price for 5.5 inch is $8.99. Today's price is $6.47!
Regular Price for 4 inch is $5.99. Today's price is $4.43!
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
- Bring out the maximum depth and gloss of any polish
- Use the Hydro Tech Crimson pads to apply finishing polishes, glazes or even sealants and waxes
- Experience longer work time and less dusting with less product absorption
Today's Daily special (October 20, 2011) is DI Brushes Horse's Hair Upholstery Brush.
Regular Price is $14.99. Today's price is $10.64!
- Soft and safe horse hair fibers make this a great tool for cleaning
- Very durable materials and design, makes a great investment
- Easy to use and highly effective cleaning tool
- Helps thoroughly clean mats, carpets, seats (leather and fabric), convertible tops, trim, etc.
Today's Daily special (October 21, 2011) is DI Accessories DetailedImage.com T-Shirt.
Regular Price for Large is $9.99. Today's price is $8.28!
Regular Price for X-Large is $9.99. Today's price is $8.28!
Regular Price for Medium is $9.99. Today's price is $8.14!
- The official Detailed Image T-Shirt
- Made from 100% Cotton
Today's Daily special (October 24, 2011) is Gilmour Brass Connector High Flow Shut-off Valve.
Regular Price is $7.99. Today's price is $5.83!
- Easily kill water flow with a simple twist of a **** instead of walking back to the hose source
- Perfect for removing your hose nozzle or foam gun to utilize the sheeting method
Today's Daily special (October 25, 2011) is DI Brushes Foam Brush.
Regular Price for 2" is $1.49. Today's price is $1.07!
- Highest quality foam brush made proudly in the USA
- Helps spread any detailing product uniformly
- Very soft and gentle yet durable and strong
Today's Daily special (October 26, 2011) is 303 Fabric & Vinyl Cleaner.
Regular Price for 32 oz is $14.99. Today's price is $11.09!
Regular Price for 128 oz is $42.99. Today's price is $30.52!
- Concentrated all purpose cleaner for carpets, upholstery, vinyl, rubber, leather, plastic and much more
- Cleaning action increases with warm water, agitation, and longer dwell time
- Safely removes oil, grease, ink, coffee, tea, wine, juice, blood, and tons more
- Dilute into a 22oz empty spray bottle or a handy 4oz pump spray bottle
Today's Daily special (October 27, 2011) is DI Accessories Sheepskin Wash Mitt w/no thumb.
Regular Price is $8.99. Today's price is $6.56!
- Perfect wash medium to help minimize adding swirls and other imperfections to the paint
- The natural fibers help pull contamination away from the surface without grinding them in
- When done using, rinse any contamination using free flowing water than hang dry with leather hoop
- For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
Today's Daily special (October 28, 2011) is Chemical Guys Silk Shine Dressing & Protectant.
Regular Price for 16 oz is $8.99. Today's price is $6.56!
- Very versatile dressing that restores vinyl, rubber and tires to a beautiful low gloss finish
- Properly protect your vinyl and rubber surfaces from UV fading with CG Silk Shine Dressing
- To avoid over spray, we recommend misting Silk Shine Dressing into a microfiber towel to apply
- We recommend using a 4oz pump spray bottle to apply a thin, even layer of dressing
Today's Daily special (October 31, 2011) is DI Accessories Polishing Pal.
Regular Price is $12.99. Today's price is $9.68!
- Even distribution of any product and better results from hand applications
- Get the same variety in cutting and finishing pads as you would with a buffer using 4" pads!
Today's Daily special (November 1, 2011) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.31!
- One of the most popular used wash mediums by professional detailers
- Very soft and durable, while being able to hold tons of suds and water helps reduce imperfections
- One of the best features of the grout sponge is that it releases contamination very easily
- For maximum results, use in combination with a Grit Guard bucket insert
Today's Daily special (November 2, 2011) is TUF SHINE Spray & Shine Detailer.
Regular Price for 22 oz is $9.99. Today's price is $7.29!
- Clean, shine and protect in one step!
- Looks great on all colors and leaves a high luster shine
- Durable polymers rapidly bond with the paint and hide imperfections
Today's Daily special (November 3, 2011) is TUF SHINE Scrub-All No Scratch Sponge.
Regular Price is $1.99. Today's price is $1.45!
- Quickly and safely remove bug smear, road grime, tar and more!
- A durable and reusable sponge that will last
- Extra strong and very gentle
Today's Daily special (November 4, 2011) is Dodo Juice Born to be Mild Shampoo.
Regular Price for 250 ml is $16.99. Today's price is $12.57!
- One of the best shampoos we've tested in terms of lubricity and maximizing your coats of protection
- Highly concentrated formula means only a little bit of product is needed to achieve great results
- Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Today's Daily special (November 7, 2011) is Menzerna Top Inspection Spray.
Regular Price for 500 ml is $19.99. Today's price is $14.79!
- Remove excess polish and polishing oils with Menzerna Top Inspection Spray
- Use like you would a quick detailer, typically misting into a quality microfiber towel then wiping
Today's Daily special (November 8, 2011) is DI Brushes Lambs Wool Premium Wheel Brush.
Regular Price for 1" is $11.99. Today's price is $10.43!
Regular Price for 2" is $17.99. Today's price is $12.77!
Regular Price for 3" is $28.99. Today's price is $21.60!
- Extremely soft and plush wheel brush that is safe on all wheels
- Three different diameter's are available - 1", 2" & 3"
- Safe on wheels that are painted, chrome, aluminum, clear coated, alloy, bare metals, matte, etc.
- Also use it on your front bumper, grill, spoiler, handles, trim pieces and more
- Metal free wheel brush that is safe and effective
Today's Daily special (November 9, 2011) is Menzerna Power Gloss Compound PG 1000.
Regular Price for 16 oz is $18.99. Today's price is $14.63!
- One of our most aggressive polishes and compounds we offer for serious paint correction
- Commonly used with a Yellow Cutting Pad or a Purple Foamed Wool Pad from Lake Country
- We recommend following up with a lighter pad and polish combination to restore a glossy finish
- Power Gloss Compound PG 1000 quickly removes noticeable surface imperfections
Today's Daily special (November 10, 2011) is TUF SHINE Applicator Sponge.
Regular Price is $1.99. Today's price is $1.43!
- Use this applicator to apply the TUF SHINE Tire Clearcoat
- Very soft and reusable, just rinse under water!
Today's Daily special (November 11, 2011) is Lake Country Tire Dressing Applicator.
- A perfect applicator pad to apply your favorite tire dressing
- Firm foam design that will not shred like cheaper tire dressing applicator pads
- Works excellent with Poorboy's Bold 'n Bright water based tire dressing
Today's Daily special (November 13, 2011) is DI Microfiber Mini-Towel.
Regular Price for 6" x 7" is $2.99. Today's price is $2.15!
- Works well at keeping glass and other surfaces clean and free of fingerprints and smudges
- Perfect for keeping your sunglasses clean and free of fingerprints
