NEW!!!! Daily Specials at Detailed Image
Today's Daily special (October 21, 2014) is Stoner Tarminator.
Regular Price for 10 oz is $5.99. Today's price is $4.25!
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
- Safely and effectively remove tar, grease and sap from painted surfaces
- Simply spray Tarminator onto the effected area, let dwell for a minute or two, then wipe clean
- Remember to protect the areas you use Tarminator on with a sealant or wax
Today's Daily special (October 22, 2014) is Meguiar's Ultra-Cut Compound M105.
Regular Price for 32 oz is $25.99. Today's price is $22.20!
Regular Price for 128 oz is $79.99. Today's price is $67.41!
Regular Price for 8 oz is $9.99. Today's price is $7.57!
- Very effective at cutting through deeper imperfections
- Finishes down nicely, but we still recommend a finishing polish after 105
- Commonly used with an orange light cutting pad, yellow cutting pad or purple foamed wool pad
Today's Daily special (October 23, 2014) is DI Accessories Razor Blade and Mini Plastic Holder.
Regular Price is $1.99. Today's price is $1.47!
- Pocket size plastic scraper with one single edge razor blade
- Quickly remove inspection stickers and registration stickers
- Use for virtually any scraping, trimming, or cutting
- Open or close with easy push button lock system
Today's Daily special (October 24, 2014) is DI Brushes Heavy Duty Wheel Brush.
Regular Price is $4.99. Today's price is $3.72!
- Clean even the heaviest of build ups off your wheels quickly and easily
- The stiff blue polypropylene bristles provide extra scrubbing action
- With a simple rinse this brush is clean for future uses
Today's Daily special (October 27, 2014) is Lake Country Tire Dressing Applicator.
Regular Price is $2.99. Today's price is $2.15!
- A perfect applicator pad to apply your favorite tire dressing
- Firm foam design that will not shred like cheaper tire dressing applicator pads
- Works excellent with Poorboy's Bold 'n Bright water based tire dressing
Today's Daily special (October 28, 2014) is Tuf Shine Applicator Sponge.
Regular Price is $2.49. Today's price is $1.77!
- Use this applicator to apply the TUF SHINE Tire Clearcoat
- Very soft and reusable, just rinse under water!
Today's Daily special (October 29, 2014) is Lake Country Blue Fine Finishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.19!
Regular Price for 5.5 inch is $7.99. Today's price is $5.91!
Regular Price for 4 inch is $4.99. Today's price is $3.64!
Regular Price for 3 inch is $3.99. Today's price is $2.83!
- Our softest foam pad, the blue fine finishing pad, designed to apply ultra fine polishes, sealants and liquid waxes
- Also commonly used to burnish the paint to a high gloss with a gloss enhancing polish
- Blackfire Wet Diamond All Finish Paint Protection is one of the most popular sealants to apply with a blue pad
- We recommend caring for your pads with Lake Country Snappy Clean Pad Cleaner
- If you want to jewel or burnish the paint for some extra shine combine with the Menzerna Micro Polish SF 4500 (PO85RD)
Today's Daily special (October 30, 2014) is Lake Country Blue Hybrid Foamed Wool Pad.
Regular Price for 6" is $11.99. Today's price is $8.87!
Today's Daily special (October 31, 2014) is DI Accessories Medium Grade Clay Bar.
Regular Price for 100 g is $10.99. Today's price is $8.02!
- Use to remove stubborn contamination such as tree sap, tar, rail dust and paint overspray
- Large enough to break into several pieces for multiple uses
- We recommend Dodo Juice Born Slippy as a clay lube
- If you drop a piece of clay, throw it away!
Today's Daily special (November 3, 2014) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.37!
- One of the most popular used wash mediums by professional detailers
- Very soft and durable, while being able to hold tons of suds and water helps reduce imperfections
- One of the best features of the grout sponge is that it releases contamination very easily
- For maximum results, use in combination with a Grit Guard bucket insert
Today's Daily special (November 4, 2014) is DI Accessories Foam Lance.
Regular Price is $89.99. Today's price is $64.79!
- Spray tons of suds all over your exterior quickly and easily
- Pre-soaking the paint helps make washing safer and more effective
- Can be used with most pressure washers from 700 - 3000 PSI
- Adjustable nozzle for various spray patterns
Today's Daily special (November 5, 2014) is Meguiar's DA Microfiber Cutting Disc Buffing Pad - 2 pack.
Regular Price for 5.5" is $21.99. Today's price is $16.05!
Regular Price for 6.25" is $23.99. Today's price is $17.03!
Regular Price for 3" is $13.99. Today's price is $9.93!
- Combine this pad with the Meguiar's DA Microfiber Correction Compound for best results
- Includes 2 Pads
- Exceptional cutting power that removes swirls while finishing down crystal clear
- A brand new technology that is changing the detailing world
- Use a Porter Cable 7424 XP and the Meguiar's Professional Backing Plate
Today's Daily special (November 6, 2014) is DI Accessories Fine Grade Clay.
Regular Price for 200 g is $18.99. Today's price is $13.67!
Regular Price for 100 g is $10.99. Today's price is $7.91!
- Safely remove road grime, brake dust, tar, sap, paint over spray and more
- Fine grade clay bars are gentle on your exterior paint
- We recommend using Dodo Juice Born Slippy or Poorboy's World Spray & Wipe as your clay lube
- Can be used on brand new cars to older vehicles with light to medium build ups
Today's Daily special (November 7, 2014) is Meguiar's All Purpose Cleaner Bottle (D101).
Regular Price for 32 oz is $2.99. Today's price is $2.23!
- Dilute the powerful Meguiar's All Purpose Cleaner D101 in this bottle for maximum value
- Chemical resistant bottle is OSHA compliant
- Pick up this bottle and a DI Accessories Chemical Resistant Spray Trigger
- Bottle is color coded and pre-labeled as the All Purpose Cleaner
Today's Daily special (November 11, 2014) is DI Accessories DetailedImage.com License Plate Frame.
Regular Price is $5.99. Today's price is $4.43!
- Black DetailedImage.com license plate frame with white lettering
- "Clean Shine Protect" tag line
- Thank you for your support!
Today's Daily special (November 12, 2014) is Menzerna Micro Polish SF 4500.
Regular Price for 32 oz is $34.99. Today's price is $24.84!
- When you want the absolute maximum depth and gloss, finish your polishing with SF 4500
- Works great alone or after correcting paint imperfections with more aggressive polishes
- Easy to work with, with long work time and easy removal
- Most commonly applied with a crimson, black or blue finishing pad
Today's Daily special (November 13, 2014) is DI Accessories Chemical Resistant Spray Trigger.
Regular Price is $2.99. Today's price is $2.23!
- A high quality trigger meant to withstand strong cleaning agents
- Can spray a fine mist or a direct stream
- Works great with virtually any bottle including the DI Accessories Trigger Spray Bottle
Today's Daily special (November 14, 2014) is DI Brushes Vent and Dash Boar's Hair Detailing Brush.
Regular Price is $9.99. Today's price is $7.19!
- Perfect brush to clean around hard to reach interior surfaces
- 2.5" long bristles made of soft natural Boar's Hair
- Handle made of high quality durable ferrule
- Easily clean buttons, ****, vents, radios, speakers, seams, crevices and more!
Today's Daily special (November 16, 2014) is Meguiar's Ultimate Wipe Detailing Cloth.
Regular Price is $3.99. Today's price is $2.91!
- High quality microfiber towel that is safe on all automotive surfaces
- Edgeless design enhances safety of this towel
- Features three times the absorbency of traditional terry cloth towels
- Individually wrapped for added safety
- 16" x 16" for good control when detailing
Today's Daily special (November 17, 2014) is DI Accessories Razor Blade and Mini Plastic Holder.
Regular Price is $1.99. Today's price is $1.41!
