NEW!!!! Daily Specials at Detailed Image
Old Oct 12, 2010 | 09:14 AM
  #761
Detailed Image's Avatar
Detailed Image
Detailed Image
Today's Daily special (October 12, 2010) is Poorboy's World Leather Stuff.
Regular Price for 16 oz is $17.99. Today's price is $13.40!
  • An amazing one step solution for leather. Cleans, lightly conditions, and UV protects!
  • Restores and leaves behind a pleasant leather scent
  • Easy to apply and remove, while leaving behind a like new matte finish
  • Also works well on vinyl and rubber surfaces throughout the vehicle and home
  • Best applied with a terry cloth applicator and wiped to desired finish with a microfiber towel
Old Oct 13, 2010 | 09:59 AM
  #762
Detailed Image
Detailed Image
Today's Daily special (October 13, 2010) is Optimum (OPT) Car Wash.
Regular Price for 32 oz is $11.99. Today's price is $8.63!
Regular Price for 128 oz is $29.99. Today's price is $22.77!
  • An outstanding shampoo that has great lubricity, plenty of suds, and gentle cleaners
  • Works great as a maintenance shampoo to maximize the life of your sealant or wax
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Old Oct 14, 2010 | 05:26 AM
  #763
Detailed Image
Detailed Image
Today's Daily special (October 14, 2010) is Chemical Guys XXX Hard Core Paste Wax.
Regular Price for 8 oz is $24.99. Today's price is $17.99!
  • Perfect mix of gloss and depth, durability and ease of use
  • Looks great on light or dark colors and is one of our best bang for the buck waxes
  • Best applied with a foam applicator pad and removed with a quality microfiber towel
Old Oct 14, 2010 | 06:20 PM
  #764
johnp69's Avatar
johnp69
I just found this...awesome!
Old Oct 14, 2010 | 06:23 PM
  #765
tquill's Avatar
tquill
I wish I had seen this thread earlier... subscribed!
Old Oct 14, 2010 | 06:26 PM
  #766
tquill's Avatar
tquill
I have my fingers crossed for optimum opti-seal soon... I know I already missed it... but hopefully another time.
Old Oct 14, 2010 | 06:34 PM
  #767
Alang35's Avatar
Alang35
sorry, posted my comment in the wrong thread.
Last edited by Alang35; Oct 14, 2010 at 06:51 PM. Reason: sorry, posted my comment in the wrong thread.
Old Oct 15, 2010 | 07:14 AM
  #768
Detailed Image
Detailed Image
Today's Daily special (October 15, 2010) is Clay Magic Fine Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $21.34!
  • Fine grade clay bar that is one of the standards in the industry for enthusiasts and professionals
  • Remove embedded surface contamination that does not come off during the washing process
  • Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
  • Helps you get the most out of any step you perform after using the clay bar
  • Use with plenty of clay bar lubricant to minimize any micro-marring that may occur
  • We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
Old Oct 16, 2010 | 10:15 AM
  #769
Detailed Image
Detailed Image
Today's Daily special (October 16, 2010) is Chemical Guys Bug Bugger & Tar Remover.
Regular Price for 16 oz is $9.99. Today's price is $7.19!
  • Remove tar, bug splatter, sap, and other stubborn forms of contamination with ease
  • Simply spray the product onto the paint, allow Bug Bugger to dwell for a bit, agitate and rinse away contamination
  • For maximum efficiency and easy storage use in a 4oz pump spray bottle
Old Oct 17, 2010 | 10:15 AM
  #770
Detailed Image
Detailed Image
Today's Daily special (October 17, 2010) is Optimum (OPT) Hyper Spray Compound.
Regular Price for 18 oz is $29.99. Today's price is $21.89!
  • Innovative compound that will remove moderate to deep imperfections in an easy to apply solution
  • Work inside or outside with long work times and minimal dusting
  • Typically used with cyan, orange, yellow, cyan or purple foamed wool pads
Old Oct 19, 2010 | 07:11 AM
  #771
Detailed Image
Detailed Image
Today's Daily special (October 19, 2010) is Lake Country Ulti-Mit.
Regular Price is $15.99. Today's price is $11.35!
  • A paint safe foam wash mitt that has two different surfaces to tackle various areas of your vehicle
  • Holds large amounts of suds and water which helps minimize marring the paints finish
  • Use the red cubed side to wash your paint, as it is the softer of the two sides
  • Use the black side to clean stubborn contamination off of lower panels, tires, wheel wells and more
  • Highly recommended to be used with a Grit Guard insert to easily release contamination
  • Will outlast natural fiber mitts due to the durable foam design
Old Oct 20, 2010 | 07:06 AM
  #772
Detailed Image
Detailed Image
Today's Daily special (October 20, 2010) is Gilmour Brass Connector High Flow Shut-off Valve.
Regular Price is $6.99. Today's price is $5.17!
  • Easily kill water flow with a simple twist of a **** instead of walking back to the hose source
  • Perfect for removing your hose nozzle or foam gun to utilize the sheeting method
Old Oct 21, 2010 | 11:48 AM
  #773
Detailed Image
Detailed Image
Today's Daily special (October 21, 2010) is Poorboy's World Liquid Natty's Blue Wax.
Regular Price for 16 oz is $18.99. Today's price is $14.15!
  • Finally, a great carnauba wax you can apply by hand or with a buffer!
  • Applies and removes easily while leaving behind a deep wet gloss
  • If you've enjoyed previous Natty's waxes, give this a shot!
Old Oct 22, 2010 | 10:57 AM
  #774
Detailed Image
Detailed Image
Today's Daily special (October 22, 2010) is Optimum (OPT) Opti-Clean.
Regular Price for 18 oz is $8.99. Today's price is $6.38!
Regular Price for 32 oz is $15.99. Today's price is $11.67!
  • True waterless wash product that can be used to clean and protect nearly every surface your car has in one simple step
  • The 32 oz version is concentrated and recommends a 3:1 dilution ratio, meaning you get a gallon of product out of it
Old Oct 23, 2010 | 05:43 AM
  #775
Detailed Image
Detailed Image
Today's Daily special (October 23, 2010) is Chemical Guys Clear Seal.
Regular Price for 16 oz is $9.99. Today's price is $8.68!
  • Clean, polish and protect all of your plastic surfaces, in one easy to use step
  • Leave plastic surfaces with a slick layer of protection to help minimize dust from building up
  • For accurate product dispensing, we recommend using a 4oz dispenser bottle and applying with a microfiber towel
Old Oct 24, 2010 | 11:08 AM
  #776
Detailed Image
Detailed Image
Today's Daily special (October 24, 2010) is Leatherique Prestine Clean.
Regular Price for 16 oz is $19.99. Today's price is $16.18!
Regular Price for 32 oz is $29.99. Today's price is $22.90!
  • Detailed Image's best leather cleaner with light conditioners, perfect for maintaining leather
  • Restores oils and proteins that are naturally found in leather for a soft and supple feel
  • Cleans to a like new, matte finish that has no greasy or oily feel like other products
  • Apply to your leather and let sit for 15 - 30 minutes, wipe with a warm damp towel and buff dry
  • We recommend using a terry cloth application pad to help agitate the leather surface
  • For maximum results, Prestine Clean is best used after Leatherique Rejuvenator Oil
Old Oct 25, 2010 | 01:53 PM
  #777
Detailed Image
Detailed Image
Today's Daily special (October 25, 2010) is Lake Country Black Finishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.29!
Regular Price for 5.5 inch is $8.99. Today's price is $6.65!
Regular Price for 4 inch is $4.99. Today's price is $3.64!
  • A finishing pad, designed to bring the paint to its maximum depth and gloss with a finishing polish
  • Also can be used to apply a paint cleaner, glaze or sealant
  • Menzerna PO85RD is one of the most popular polishes to use with a black finishing pad
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old Oct 26, 2010 | 07:50 AM
  #778
Detailed Image
Detailed Image
Today's Daily special (October 26, 2010) is Brinkmann Maxfire Dual Xenon Swirl Finder Spotlight.
Regular Price is $26.99. Today's price is $19.97!
  • Easily reveal swirls, scratches and other imperfections with this lightweight rechargeable hand held spotlight
  • Avoid having to use bulky, corded, and hot halogen light stands!
  • Get the best polishing results with the proper lighting, no guess work if imperfections have been removed effectively
Old Oct 27, 2010 | 07:39 AM
  #779
Detailed Image
Detailed Image
Today's Daily special (October 27, 2010) is Meguiar's Ultra-Cut Compound M105.
Regular Price for 32 oz is $26.99. Today's price is $21.06!
Regular Price for 128 oz is $74.99. Today's price is $59.70!
Regular Price for 8 oz is $9.49. Today's price is $7.07!
  • Very effective at cutting through deeper imperfections
  • Finishes down nicely, but we still recommend a finishing polish after 105
  • Commonly used with an orange light cutting pad, yellow cutting pad or purple foamed wool pad
Old Oct 28, 2010 | 10:51 AM
  #780
Detailed Image
Detailed Image
Today's Daily special (October 28, 2010) is Optimum (OPT) Power Clean.
Regular Price for 17 oz is $11.99. Today's price is $8.87!
Regular Price for 128 oz is $35.99. Today's price is $27.47!
  • A versatile degreaser that can be used on a wide variety of surfaces
  • Powerful concentrated formula can be diluted up to a 3:1 ratio for even more value
  • Perfect for degreasing tires, wheel wells, engine bays, stubborn contamination and to clean carpets
