NEW!!!! Daily Specials at Detailed Image
Today's Daily special (February 28, 2017) is Meguiar's Ultra-Cut Compound M105.
Regular Price for 32 oz is $27.99. Today's price is $23.17!
Regular Price for 128 oz is $84.99. Today's price is $69.88!
Regular Price for 8 oz is $10.99. Today's price is $7.92!
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
- Very effective polish at cutting through deeper imperfections
- Finishes down nicely, but we still recommend a finishing polish after 105
- Commonly used with an orange light cutting pad, yellow cutting pad or purple foamed wool pad
Today's Daily special (March 1, 2017) is Gyeon Smoothie.
Regular Price is $24.99. Today's price is $18.24!
- Reduce the risk of washing induced marring with this mitt!
- Thousands of soft fibers trap dirt and grime for easy removal
- Elastic cuff helps mitt stay in place during the wash process
- Works great with the Gyeon Bathe shampoo
Today's Daily special (March 2, 2017) is DI Brushes Paint Brush Style Detail Brush.
Regular Price is $3.99. Today's price is $2.76!
- Easily remove wax and polish residue from from trim and tight spaces
- 7" long brush allows you to access hard to reach areas
- Soft and gentle horse hair bristles makes it a safe brush too!
Today's Daily special (March 3, 2017) is DI Accessories Bug Sponge.
Regular Price is $2.99. Today's price is $1.81!
- Remove dirt, grime, bug splatter, and more
- High quality, soft, durable foam
- Easily rinses clean
Today's Daily special (March 6, 2017) is DI Accessories Funnel.
Regular Price is $3.99. Today's price is $2.55!
- Reduces spills when pouring
- Wash and reuse! Extremely durable material
- Makes it easy to dilute concentrated products
- Strong polypropylene stands up to strong detailing chemicals
- Concentrated products are the best value, use the funnel to help dilute them in to smaller bottles
Today's Daily special (March 7, 2017) is DI Microfiber Glass Polishing Towel (Blue).
Regular Price for 16" x 16" is $5.99. Today's price is $3.24!
- The ideal solution for achieving that streak free finish when caring for glass
- Use a slow wiping motion, while applying some pressure to the glass polishing towel
- The low, ultra thin nap ensures that there is no lint left behind on glass
- Ideally, use a separate towel to apply your favorite glass cleaner and initially wipe dry
- Always wash your microfiber products prior to first use and remove tags to ensure paint safe
- 240 GSM
Today's Daily special (March 8, 2017) is Meguiar's Unigrit 3000 Foam Finishing Disc.
Regular Price for 6" is $8.99. Today's price is $6.08!
- Safely and easily remove deeper scratches and imperfections from your paint
- Spray the surface with water for lubrication
- Clean the pad frequently with water while sanding
- Start with the less aggressive pads and move up as needed
Today's Daily special (March 9, 2017) is DI Brushes Pet Hair Removal Brush.
Regular Price is $4.99. Today's price is $3.20!
- Easily remove pesky pet hair from your interior carpets and upholstery
- Rubber bristles use static electricity to attract and collect pet hair
- Great for removing hair from furniture and carpets in your home too!
- Handle can be used as a squeegee to remove water from windows
Today's Daily special (March 10, 2017) is DI Accessories Razor Blade.
Regular Price for 100 pack is $6.99. Today's price is $4.55!
- 100 pack is an awesome value!
- Fits all standard razor blade holders
- Made in USA high carbon steel
- Quickly remove contamination, stickers, etc.
- Single edged design
Today's Daily special (March 13, 2017) is Dodo Juice Born Slippy Clay Lube Concentrate.
Regular Price for 250 ml is $15.99. Today's price is $8.93!
- Ultra concentrated solution makes for over 2.5 liters of clay lube
- Dilute up to a 10:1 ratio with water while remaining super slick
- Wipes away streak free and is safe for nearly any surface
- We recommend picking up a 22oz spray bottle for proper dilution
Today's Daily special (March 14, 2017) is Lake Country Glass Polishing Disc.
Regular Price for 2.25" is $3.99. Today's price is $2.39!
Regular Price for 3" is $4.99. Today's price is $2.84!
Regular Price for 5" is $5.99. Today's price is $3.66!
Regular Price for 6" is $6.99. Today's price is $4.24!
- Polishing away ultra fine scratches, watermarks and other imperfections in your glass
- Can be used on rotary or dual action polishers
- Produces low heat for better results and durability
- Hook and loop backing for easy fastening
- Pair with the CarPro Ceriglass Glass Polish
Today's Daily special (March 15, 2017) is 303 Aerospace Protectant.
Regular Price for 16 oz is $12.99. Today's price is $9.08!
Regular Price for 32 oz is $19.99. Today's price is $13.99!
Regular Price for 128 oz is $57.99. Today's price is $41.01!
Regular Price for 10 oz is $7.99. Today's price is $5.74!
- An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
- Leaves behind a beautiful matte finish that is not greasy, shiny or oily
- Treated surfaces resist dust, soiling, staining and also repel water
- Most commonly used on interior dashboards, center consoles, door trim, leather seats, and in the engine bay
- Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
- For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
Today's Daily special (March 16, 2017) is DI Accessories The Ice Master.
Regular Price is $19.99. Today's price is $14.60!
- Remove ice from your windshield safely and easily
- Polycarbonate resin build for maxim durability
- Annealed brass blade removes ice without scratching
- 2 sturdy deployable arms add 4 scraping options
- Also available in the DI Accessories Ice Master Jr.
Today's Daily special (March 17, 2017) is DI Accessories Under Armour Detailer Hoodie.
Regular Price for Small is $49.99. Today's price is $40.03!
Regular Price for Medium is $49.99. Today's price is $42.73!
Regular Price for Large is $49.99. Today's price is $42.78!
Regular Price for X-Large is $49.99. Today's price is $42.84!
Regular Price for XX-Large is $49.99. Today's price is $42.87!
Regular Price for XXX-Large is $49.99. Today's price is $45.54!
- Represent yourself as a DETAILER everywhere you go!
- Stay warm and detail in style during colder months
- Loose fit style for comfort
- Under Armour 80/20 cotton polyester blend
- Also available as a t-shirt!
Today's Daily special (March 20, 2017) is Lake Country Orange Light Cutting Pad.
Regular Price for 6.5" is $9.99. Today's price is $6.01!
Regular Price for 5.5" is $7.99. Today's price is $4.77!
Regular Price for 4" is $4.99. Today's price is $3.29!
Regular Price for 3" is $3.99. Today's price is $2.70!
- A light cutting pad designed to remove moderate swirls and scratches with a medium polish
- Works great with the Meguiar's Ultra-Cut Compound M105 and the Menzerna Super Intensive Polish SI 1500 (PO83)
- We recommend caring for your pads with Lake Country Snappy Clean Pad Cleaner
- Generally we recommend following up with a lighter pad and polish after
Today's Daily special (March 21, 2017) is Lake Country HDO Blue Cutting Pad.
Regular Price for 5.5" is $13.99. Today's price is $9.24!
Regular Price for 6.5" is $15.99. Today's price is $10.60!
Regular Price for 3.5" is $8.99. Today's price is $6.12!
- The most aggressive LC HD Pad, designed to remove heavy scratches, swirls, and defects.
- Runs 10% cooler than traditional Lake Country pads
- Perfectly balanced, cushioned, and features thinner foam
- Removes imperfections easily while reducing hazing and marring from heavier polishing compounds
Today's Daily special (March 22, 2017) is Lake Country Tire Dressing Applicator.
Regular Price is $2.99. Today's price is $1.79!
- A perfect applicator pad to apply your favorite tire dressing
- Firm foam design that will not shred like cheaper tire dressing applicator pads
- Works excellent with Poorboy's Bold 'n Bright water based tire dressing
Today's Daily special (March 24, 2017) is Tuf Shine Tire Brush.
Regular Price is $4.99. Today's price is $3.36!
- Great for deep cleaning the tires
- Use with the TUF SHINE Tire Cleaner or your favorite degreaser
- Strong yet gentle bristles
- Cleaning your tires is critical before applying any tire dressing, especially the TUF SHINE Tire Clearcoat
Today's Daily special (March 27, 2017) is Tuf Shine Applicator Sponge.
Regular Price is $2.49. Today's price is $1.59!
- Use this applicator to apply the TUF SHINE Tire Clearcoat
- Very soft and reusable, just rinse under water!
Today's Daily special (March 28, 2017) is Lake Country Microfiber Cutting Pad.
Regular Price for 1.5" is $5.99. Today's price is $3.80!
Regular Price for 2.25" is $6.99. Today's price is $4.34!
Regular Price for 3.25" is $8.99. Today's price is $5.84!
Regular Price for 5.25" is $10.99. Today's price is $7.63!
Regular Price for 6.25" is $11.99. Today's price is $8.31!
- Remove medium to heavy imperfections with ease
- Foam backed and 11mm thick design
- Unique microfiber material mats down less frequently
- Have light imperfections, the Lake Country Microfiber Polishing Pads are also available!
- Finishes down very well!
