Zaino Question!!
Old Jul 24, 2003 | 05:24 PM
K.G's Avatar
K.G
Default Zaino Question!!
Hi!!!
It is the first time to use Zaino for me.
Is it O.k if I apply Zaino with zaino applicator pad
and remove them with microfiber towle??
and should I apply Z5 immediately after apply Z1??
also one more, after I apply Z5 over Z1
How long do I have to wait to remove it?
I would be appriciate for any information.
Thanks!!
Old Jul 24, 2003 | 06:05 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Yes, it is safe to use the applicator and take it off with the MF towel.
Yes, you put the Z-1 on first and then put the Z-5 on top of that without wiping off the Z-1.
Since you are going with the Z-1 then the Z-5 combo instead of using the ZFX "flashcure", you will need to leave the Z-5 on for anywhere between 4-12 hours depending on the temperature, the humidity and if the car is out in the sun or not.
The easier way to go, would be to add the ZFX to your Z-5 and skip the Z-1 step altogether. In this case, you can take off the Z-5 with ZFX in an hour or so.
Old Jul 24, 2003 | 07:07 PM
cheeves's Avatar
cheeves
Pop for the ZFX..from one who's done it both ways. 1st time went the Z-1 route and ended up sitting around all day waiting for the Z-5 to dry.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
