Have CG now, want to Zaino. How should I prep??
Even though I've had the Z only a couple of months, I've tried Gold Class and CrystalGuard Quick already. Now I'm ready to give Zaino a try. I guess DrBonz has finally convinced me!
I've only got one coat of CG on the car, but I know that Dawn won't remove it. Is there anything special I need to do to get ready for the Zaino, or should I just wash with Dawn, claybar and then do Zaino? I've read about using 3M adhesive remover to get rid of CG, but I'm not too sure I want to put that on my finish!
Thanks!
Thanks!
If you have an orbital polisher, the safest way is to use some 3M Perfect -it swirl remover. That will remove CG as well as really get your paint in top notch condition for Zaino.
It is worth the time and expense to get/use this safe method.
Unless you are VERY experienced in using solvents on paint, please don't try 3M adhesive remover. You can damage your paint SOOOO fast.
