quick detail question
Old Sep 7, 2008 | 07:42 PM
polish pete's Avatar
polish pete
Default quick detail question
hey guys, is it normal for chrome silver to get dirty so fast? i mean its like a white car instead. how do you guys keep water spots from forming on the car. i keep the car wet constantly then dry off fast. but it still seems to occur.
and one last question, how do you get waterspots off glass easily? my side mirrors really covered in it and its affecting how well i can see in the mirror.
Old Sep 8, 2008 | 04:47 PM
Detailed Image's Avatar
Detailed Image
Detailed Image
I keep the vehicle in the shade as much as possible before washing. Get absolutely everything ready before backing the car out for the wash. Rinse the paint frequently and pull it back in the garage immediately after finishing.
For very light etchings and build ups you can use the Chemical Guys Water Spot Remover. This is a strong chemical that can help clean the surface. If you have light etchings or deeper you'll probably need to polish them out. This step is ideally done with a buffer and at least a light polish, but generally a medium is needed as well. For the glass the Glass Science Glass Scrub is a great option for deep cleaning the glass and removing water marks. Just use a damp applicator and buff it on the glass and you should be able to remove them no problem. You can also protect the glass with the Glass Science Rain Clear Gel if interested.
Greg @ Detailed Image
Old Sep 10, 2008 | 08:19 AM
Water spots can be removed from glass with a glass polish. Generic glass cleaners such as Windex are not strong enough.
Old Sep 10, 2008 | 08:27 AM
BlueBoxer's Avatar
BlueBoxer
+1 on the chemical guys water spot remover. Make sure your paint and car surfaces are cool to the touch before washing, if they are warm the water will dry on the parts quicker and cause more water spots. Also keep a good layer of wax or sealant to help keep the water spots from etching onto the surface.
Old Sep 10, 2008 | 10:22 AM
ZSpectrum's Avatar
ZSpectrum
If there minor and occur often i tend to add a little bit of chemical guys watersport remover to whatever soap im using at the time. Assuming its a detail and not a maintenance wash.
Old Sep 12, 2008 | 11:44 AM
PWSHHOCKEY44's Avatar
PWSHHOCKEY44
^^he just used it on my Chrome Silver Z and it look incredible
Old Sep 12, 2008 | 11:53 AM
TheOtherRob's Avatar
TheOtherRob
Try owning a black car, its dirty by the time you get out of the driveway.
OP, try using white vinegar to remove the water spots.
Old Sep 12, 2008 | 02:31 PM
ZSpectrum's Avatar
ZSpectrum
thanks boy!
Old Sep 12, 2008 | 10:16 PM
PWSHHOCKEY44
Originally Posted by ZSpectrum
thanks boy!
Anytime brotha, i went ahead and clayed the z shes lookin purrrrty
Old Sep 15, 2008 | 04:52 PM
polish pete
thanks guys some good info here, i just got the car so it wasnt kept too clean really. i mean the jams were filled with dirt it sucked.
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
