Scuffs, How to get them out.
Old Dec 7, 2008 | 10:51 PM
chopperman's Avatar
chopperman
Default Scuffs, How to get them out.
Sold a CF hood to a member on here and he said that there are scuffs on the clear coat. He said that he used 3m fine compound and meguires scratch X by hand but that didnt really do anything. I told him that he should use a buffer to try to get them out because it generates more heat to activate the chemicals. What do you guy recommend on going? Here are some pics.
Old Dec 7, 2008 | 11:16 PM
ATX350's Avatar
ATX350
Heat is your worse enemy it has nothing to do with "activating chemicals". Buffing at extreme speeds causes friction heat thus swirling the paint or burning the clear coat. However a rotary buffer at around 1800rpm's and constant moving with a mild compound would definitely do the trick. I can't see all the scratches but from the ones I can see in the pic above a quick buff and polish should eliminate those abrasions.
/end
Old Dec 7, 2008 | 11:56 PM
chopperman's Avatar
chopperman
/end
Perfect thanks....Anyone else. More opinons are welcomed.
Old Dec 8, 2008 | 12:17 PM
ATX350's Avatar
ATX350
But to be honest, if you've never used a buffer before DON'T try it on this hood. I would suggest meguiars scratch-x with a microfiber cloth. You can buy it from autozone, walmart etc.. and it does a pretty good job at getting rid of scratches.
http://meguiarsdirect.com/detail/MEG+G10307
Beware, however the look may not stay forever since all products like this have some filler in it. I'm also a member of www.meguiarsonline.com forums so I would post up there for help. They have unbiased opinions on products besides the admins so you can find alot of help there.
http://meguiarsonline.com/forums/member.php?u=18166
Old Dec 10, 2008 | 07:06 PM
1cleanz's Avatar
1cleanz
like said above using a rotary at about 1800 with a decent polish would do the trick. but if you have no experiance with a rotary dont even try it. expically on that carbon hood because it is hard to say how much clear that hood has. it could have a lot or very little and the rotary could burn threw the clear quick. a porter cable with a good polish woud most lilkey do the trick.
Old Dec 10, 2008 | 07:44 PM
ATX350's Avatar
ATX350
Good point 1cleanz, a DA (aka dual action polisher) would definitely make an impact. I would suggest the porter cable or the meguiars G110
Old Dec 11, 2008 | 01:12 AM
chopperman's Avatar
chopperman
Thanks guys
sherm
Apr 11, 2020 05:21 PM
ablaine
Nov 29, 2016 10:13 AM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
