Removing Zaino
Old Sep 28, 2003 | 04:15 PM
dutchZ's Avatar
dutchZ
Default Removing Zaino
I need to remove the Zaino on the hood of my wife's black RAV4 because it was not completely clean when I applied the Zaino.
Anybody knows how to do this...
BTW: I think it's really great stuff.
Old Sep 28, 2003 | 05:32 PM
dutchZ's Avatar
dutchZ
I thought Dawn would only remove wax, not polymer.
But I can try it anyway, thanks.
Old Sep 28, 2003 | 06:46 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Dawn alone will not remove Zaino effectively. You'll have to wash with Dawn, then clay the car with Dawn as your lube for the claybar. This should do it.
Old Sep 28, 2003 | 08:10 PM
Dissolved's Avatar
Dissolved
i emailed sal because i had black specs in my paint. He said to use 3M swirl remover, then wash with Dawn. Then reapply Z5 and Z2. So I'm guessing dawn does remove zaino
Old Sep 28, 2003 | 08:30 PM
dutchZ's Avatar
dutchZ
Thanks for the info guys.
Old Sep 29, 2003 | 03:41 AM
mrice's Avatar
mrice
Default Re: Removing Zaino
Meguiars paint cleaner takes it right off, no effort.
Old Sep 29, 2003 | 07:07 AM
Kevin Overall's Avatar
Kevin Overall
Dawn is not very effective at removing Zaino, if you plan on using an abrasive it of course will remove the Zaino.
Old Sep 29, 2003 | 08:17 AM
DUKE's Avatar
DUKE
I just sent an email to the Zaino website asking about Dawn and received a message from Sal to call him or send my phone number and he would call me. I sent him my number and he called back in less than 2 minutes.
He said Dawn will not remove Zaino, but it would remove any wax. He recommends using Dawn before the initial application of Zaino to make sure the car is clean and wax free. He thinks that is the reason many people think it will remove Zaino. I suggested that he might want to add this to his FAQ page.
He seems like a nice man and said he answers all his email. He said if you needed to talk to him call and if he was unavailable just leave a number where you could be reached.
BTW Bonz, I told him in my email I started using Zaino last year based on your recommendations. Maybe that’s why he called me so quickly.
One other thing he had told me some time back was that I could use the ClayBar and Z-7 with very light pressure whenever I thought it was needed. He said this would only remove a very slight amount of Zaino and help keep the car contaminant free.
Post Reply
Old Sep 29, 2003 | 10:28 AM
dutchZ's Avatar
dutchZ
Well he is a very nice man. Called me back in 2 minutes. He told me to use Z5 with a little pressure, that would remove the spot. If not, use 3M swirlremover and, of course, reapply Z5/Z2.
Thanks for your help, guys.
BTW: What do you think of this picture???
Old Sep 29, 2003 | 11:03 AM
BillR's Avatar
BillR
Isopropil (sp?) alcohol will remove Zaino.
Old Sep 29, 2003 | 09:02 PM
tcfool's Avatar
tcfool
FYI, in case you need to remove zaino to apply some type of addhesive material to the surface (ie. clear bra or body moldings).
Per Sal, "dawn will not remove zaino". He also stated that "A light or simple Claying will not remove Zaino, [however], repeated Claying of the paint surface will eventually remove Zaino".
In regards to attaching addhessive materials, Sal stated the following, "remove zaino prior to applying body side moldings" and that "there are many commercial body shop products that are specifically designed to remove polish/wax to prep a surface prior to painting. Isopropyl Alcohol will also remove Zaino".
Hopefully this clears up some questions about zaino removal
Old Sep 30, 2003 | 03:43 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I believe this is exactly what I said in my post above.
Old Sep 30, 2003 | 07:08 AM
DUKE's Avatar
DUKE
So we all agree - Dawn alone will not remove Zaino.
Old Sep 30, 2003 | 08:48 AM
dutchZ's Avatar
dutchZ
I tried to remove the blemishes with Z5, as Sal told me, did not work.
Meguiars paint cleaner definitely worked. The hood is clean now. Thanks mrice.
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
