Which one is better?
Old Jun 25, 2010 | 03:23 PM
aRYip's Avatar
aRYip
Default Which one is better?
I am confusing which one go first or is every step I list is necessary
1. Clay --> Opti-Seal --> Wax it Zymol Glasur Glaze
Or Opti-Seal is not necessary since I plan to use Zymol GG?
2. Clay --> HD Cleanes like Autoglym Super Resin Polish --> Wax it
Old Jun 25, 2010 | 06:11 PM
aRYip's Avatar
aRYip
And seem the Autoglym SRP is not remove the swirls, but hide it
so should I change to use like OPT Poli-seal?
Old Jun 26, 2010 | 10:40 AM
HOMiEZ's Avatar
HOMiEZ
you can do it all if you want
clay->polish->seal->glaze
clay is first
polish right after that
you can seal or glaze, but since u have both u should seal then glaze.
Old Jun 27, 2010 | 08:54 AM
Detailed Image's Avatar
Detailed Image
Detailed Image
My suggestion would be to do a clay, polish, sealant and then a wax. If you can skip any step I would easily pick the wax because the sealant will provide more durable protection.
For the clay bar I would suggest the:
Clay Bar
DI Packages DI Clay Bar and Clay Lube Combo
Polish
Meguiar's Ultra Finishing Polish M205 or Menzerna PO106FA Nano Polish (Super Finish)
Sealant
Optimum (OPT) Opti-Seal or Blackfire Wet Diamond with Polycharger
Wax of your choice
The polishes I listed will provide significantly better results and really make the surface shine, then the sealant will enhance that.
Old Jun 27, 2010 | 08:12 PM
aRYip's Avatar
aRYip
The reason I pick SRP or Poli-Seal is I do not have PC, everything by hand only
So I think M205 is not fit my need...
