Roadster Top Protection?
Old Dec 13, 2003 | 10:09 AM
slappyclaus's Avatar
slappyclaus
Default Roadster Top Protection?
I was wondering what people are using to protect their ragtop from the elements especially UV damage. I haven't read anything about it although I have looked. I may use Scotchgaurd but it has no UV protection. How do you keep the top from fading?
Old Dec 13, 2003 | 11:26 AM
Kevin Overall's Avatar
Kevin Overall
Raggtopp is the product you will want to use on your cloth top, it comes with a cleaner and a sealant. www.haartz.com makes just about all cloth auto makers and Haartz recommends using Raggtopp on the cloth.
Here is the procedure:
Although the fabric does not promote mildew growth by itself, mildew may develop on dirt and other foreign substances that are not removed. This is especially true in warm, humid, dark environments. A program of keeping the fabric clean through regular washings, BEFORE it gets dirty, will enhance the life and beauty of the acrylic and make successive cleaning easier.
Most automatic car washes will not harm cloth top fabrics. Washes with water jets and hanging cloths provide a more gentle cleaning action. Those using heavy barrel brushes
could damage the top material. Haartz recommends hand washing. The Haartz Corporation recommends using RAGGTOPP™ Cleaner and RAGGTOPP™ Protectant
Hand washing in shade or partial shade, not direct sunlight, is best. DO NOT USE DETERGENT. Bird and tree droppings, as well as other loose particle soils, should be removed immediately. Vacuum with a brush attachment and rinse thoroughly with water
to remove loose particle soils. This will also prevent the soils from being redeposited during the cleaning process. Once the fabric has been rinsed thoroughly, spray RAGGTOPP™ Cleaner evenly over the entire surface while still wet. Allow the cleaner
to soak for 10 to 20 minutes and then scrub lightly with a soft nylon brush or terry cloth rag. Rinse thoroughly, preferably until no remaining soap foam is observed. Additional cleanings may be required. It is best to determine the need for additional cleanings after the fabric has dried completely. For more stubborn cases, mix a solution of no more than 1/2 cup (4oz.) bleach and 1/4
cup (2oz.) RAGGTOPP™ Cleaner per gallon of water, soak for approximately 20 minutes and scrub lightly as indicated above. (Excessive soaking with the bleach solution can deteriorate seam threads.) Rinse thoroughly to prevent streaking on painted and
chrome surfaces. Several cleanings may be necessary.
Once dry, cleaning must be followed by re-water repelling with RAGGTOPP™ Protectant. (This product does not contain CFC's and therefore, is not harmful to the environment.) Failure to apply will result in rapid resoiling of the unprotected fabric.
Old Dec 14, 2003 | 04:37 PM
slappyclaus
Thank you very much!
MAsSIVrOOM
Oct 20, 2023 10:50 AM
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Depravity
Oct 1, 2015 04:49 PM
