Mr Clean
Old Jan 1, 2004 | 01:27 PM
willpower's Avatar
willpower
Default Mr Clean
Hi guyzzzzzzzzzzzzzz......anyone bought that Mr clean washer advertised on tv ???? ya now the one that supposed to be spot free.....just wondered if it WAS spot free.
ZZZZZZZZZZZZZZyalater
Old Jan 1, 2004 | 01:46 PM
zand02max's Avatar
zand02max
Use the search tool, there is a post about this already. Not worth it too me though.
I heard some good things out of the product, but it seems a little pricey. I also heard the soap also leaves streak marks.
Here's the post and below it the search page
https://my350z.com/forum/showthread....hlight=MrClean
https://my350z.com/forum/search.php
Old Jan 1, 2004 | 02:07 PM
ares's Avatar
ares
Veteran
seems to compromise the wax's ability to bead also. either its leaving a residue of its sheeting agent or its stripping the wax. pick your poison.
Old Jan 1, 2004 | 03:31 PM
willpower's Avatar
willpower
Thanks for the link zand02max.....hmmmm the guy who tested it loved it .....now hes not to sure....or am I reading it wrong so I guess the jury's still out.
ZZZZZZZZZZZZyalater
Old Jan 1, 2004 | 04:27 PM
MSOsr's Avatar
MSOsr
I initially was impressed that the car "dried itself" without spotting. However, it became apparent that the soap required by the system was leaving a film which affected the surface of the Zaino layers.
I've decided I would rather have a slick, shiny paint surface, even if I have to dry my car with a towel. [I am considering buying an RV deionizing filter to put on the hose to accomplish the same "no touch, no spotting" drying, however.]
Old Jan 1, 2004 | 09:34 PM
ares's Avatar
ares
Veteran
I think a deionizer is the way to go. at very least; you can dry it quickly with a simple towel. my problem isnt drying the car; its the little spots that dry before I get to them... if it was deionized that should be reduced to almost nothing.
you could use the unit as a deionizer and not load the soap. but even so; youd have to wash the whole car with it; as soon as any regular water hits it and possibly dries; you got a spot.
Old Jan 2, 2004 | 06:42 AM
willpower's Avatar
willpower
Well I guess for what mr clean costs I'll have to try it for my self....Are they in the shops yet?????
Old Jan 2, 2004 | 07:00 AM
zand02max's Avatar
zand02max
Spring of 2004
Old Jan 2, 2004 | 07:34 AM
Kevin Overall's Avatar
Kevin Overall
Others have posted that WalMart already has it on the shelf right now for 19.99...
But I do not care for it myself, here are the short comings others have listed:
1. You seem to have to use the Mr. Clean wash that cotains some sort of dry rinse chemical that one detailer enthusiast said left a film on his paint work. Have to keep buying this special car wash to get it to work the way the unit is designed which leaves you hung out not being able to use your favorite car wash you are using now.
2. The filter gets dirty quickly and is only good for a few washings.
3. The actual final rinse using the purified water (you DO NOT use the purified water until the very end of the washing cycle, to rinse off the majority of the soap you use unfiltered water running thru the unit) comes out in a very weak stream that takes longer to run over the entire surface of the car compared to the time it takes to dry it the normal way by hand.
4. Leaving the water beads on the car to dry with out spots prevents you from using your detailer spray after the wash for quite a while why the car drys on its own....
issyz
Jul 2, 2017 03:04 PM
Stevo Z
Oct 3, 2015 09:14 PM
nanotech
Oct 2, 2015 05:02 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
