Window water spots
Old Sep 11, 2002 | 04:36 PM
zzzyaaa's Avatar
zzzyaaa
Default Window water spots
I hate em. They're not there until the sun hits the window just right. I think I washed the windows perfectly and they always seem to show up. What is the best way to get rid of them and what should I use to prevent them from happening again?
Old Sep 11, 2002 | 05:08 PM
2003z's Avatar
2003z
ONLY FOR GLASS (I guess that could go without saying), but I use fine steel wool and car wax.
Old Sep 11, 2002 | 05:13 PM
SandMan's Avatar
SandMan
Ever try Stoner Invisible Glass? Works wonders, make the windows look.. well.. invisible.. You can buy it at any car store. Like Pep Boys or Autozone.
Old Sep 11, 2002 | 07:06 PM
rouxeny's Avatar
rouxeny
This may sound odd, but I've used car wax too on my windows. It keeps them clear, and you get a Rain-X kind of effect.
Old Sep 11, 2002 | 07:43 PM
Driven's Avatar
Driven
Guess I've never been that **** about my windows, but I know what you're talking about. Believe it or not, plain vinager dissolves hard water spots real well and is a heck of a lot cheaper than many products marketed for that purpose. However it is somewhat acidic, and I don't believe it will do you any favors on your paint if you were to get it on there concentrated and didn't clean it off shortly thereafter. Otherwise a product called CLR (most hardware stores have it) does the job real well too...again...be careful near painted surfaces.
Old Sep 11, 2002 | 08:37 PM
nosuchsol's Avatar
nosuchsol
Purchase some glass polish. It's fairly cheap and will definitely make a difference. You can also use rainX over the glass polish. If the waterspots etch I recommend getting 3m scratch remover. My 85 Z had awful waterspots on the ttops from being parked outside(before I bought it). Using that fine grade remover I was able to remove all the water etching without scratching or otherwise hurting the glass.
Old Sep 12, 2002 | 04:57 AM
zzzyaaa's Avatar
zzzyaaa
Thanks for the tips. I'll try them all.
Old Sep 12, 2002 | 12:32 PM
FlaPhil's Avatar
FlaPhil
If you have a PC properautocare.com has a glass polishing kit. Works fantistic. Glass Polishing Kit
Old Sep 12, 2002 | 04:10 PM
Brad4rdHay's Avatar
Brad4rdHay
NEVER use steel wool on glass. That being said, most water spots are merely mineral deposits and can be removed with a mixture of water and white vinagar. If they have indeed etched into the glass, simple polishing with some chrome polsh will work wonders.
Old Sep 13, 2002 | 12:22 PM
ezchief's Avatar
ezchief
Talking
Another tip for windows is use your newspaper instead of paper towels (don't us the auto section/too much color can bleed but will not stain since it is soy based ink)
Newspaper is cheaper if you get it delevered and you do not get the white fuzzies left behind.
I too wax my windows. Same as the glass polish but it is sitting in my garage anyway and I do not any more stuff in their.
Old Sep 16, 2002 | 06:44 PM
highz's Avatar
highz
It seems most likely that those stains are caused by hard water. You are probably using the hose by your garage, right? Well, let me give you some advice. Use vinegar and paper towels. Seriously. It works wonders. Good luck.
Old Sep 17, 2002 | 05:06 AM
zzzyaaa's Avatar
zzzyaaa
All clean. Had some Turtle Wax chrome polish in the garage. Worked great. Thanks everyone.
ablaine
Nov 29, 2016 10:13 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
kyin
Oct 15, 2015 05:54 AM
