Any consensus on a high quality interior cleaner/restorer
Old Mar 7, 2015 | 05:18 PM
CWDings's Avatar
CWDings
Default Any consensus on a high quality interior cleaner/restorer
I'm trying to get some suggestions on what you consider a high quality cleaner/restorer for the car interior, mostly the door panels, console, dash, etc. I'm familar with the normally recommended products, but I figured I'd ask other Z owners and make it more "car specific". I'd like to find something that I don't have to apply every other day if you know what I mean. So help me out if you can and let me know what you use to keep your interior looking good. I don't have a leather interior so we can eliminate suggestions for that.
Thanks for your help!
Old Jun 15, 2015 | 07:53 AM
Detailed Image's Avatar
Detailed Image
Detailed Image
If you're looking for a good dressing for vinyl/plastic interior pieces, I would highly recommend 303 Aerospace Protectant. This water based dressing leaves a darker finish, and slight sheen that will make your dash, door panels, console, etc look great. Since it is water based, and not a silicone base like many consumer products, it does not leave a greasy feeling behind.
The product is simple to use - just spray some onto a clean microfiber towel and spread evenly onto the desired panel, applying more product to the towel as needed. Then flip the towel over and lightly wipe the surface to level out any areas that were oversaturated.
This product can be used as often as you like, but I have found that I only need to use it on my DD every couple of months to keep it looking perfect.
Hope that helps.
Zach McGovern
Detailed Image Ask-A-Pro Blog Author
www.AttentiontoDetailingPeoria.com
burglapfd
Dec 6, 2020 01:04 PM
Tochigi_236
Sep 27, 2015 03:40 PM
