Water spots
Old Mar 19, 2004 | 10:56 PM
Dittybopdiva's Avatar
Dittybopdiva
Talking Water spots
Hi, I just wash my 350Z and i notice that I have water spot, so I was wondering if anyone knows how to remove it. Thank you
Old Mar 20, 2004 | 02:04 AM
XtaZee's Avatar
XtaZee
Lightbulb
Zaino Z6 should help.
Old Mar 20, 2004 | 06:36 AM
Keo's Avatar
Keo
Man, you Zaino guys are killin' me. Meguiar's Final Inspection #34 is less expensive and can be found almost anywhere for $5.95: Napa, Autozone, etc.
Old Mar 20, 2004 | 09:12 AM
Kevin Overall's Avatar
Kevin Overall
A detailer spray is best to use right after you wash to remove a fresh water spot if you have created one in the washing process, if you are a Zaino user this is the Z-6, if you use another brand of car wax or polish buy the kind of detailer spray that is made to work with the given wax or polish.
Old Mar 20, 2004 | 09:36 AM
Reggi914's Avatar
Reggi914
A toyota camry can be found everywhere and is cheaper, why did you buy the 350Z?
Old Mar 20, 2004 | 10:17 AM
Keo's Avatar
Keo
We're talking about a waterspot right after washing a car. It makes no sense to spend $10 and WAIT for delivery when he can save $5 and get it off immediately with a well respected product. Your analogy of Meguiars to a toyota camry is ridiculous.
Old Mar 20, 2004 | 10:23 AM
ranger5oh's Avatar
ranger5oh
I have never tried to remove a water spot with a toyota camry, does this work. I imagine the camry is too heavy to lift onto my water spot, is there a certain part of the camry you reccommend using for removing waterspots from my Z?
Old Mar 20, 2004 | 10:28 AM
mofoz's Avatar
mofoz
alot of members simply have used everything else and feel zaino is the best, therefore always recommending zaino. I also recommed it, and if you dont have it, finish using whatever else you have and then order the starter kit. You will no regret it.
Old Mar 21, 2004 | 02:07 AM
Dittybopdiva
Thanks guys! Beside purchasing Zaino online, is there any retail store, where i can get it from?
Old Mar 21, 2004 | 07:24 AM
gooters's Avatar
gooters
ROFL!!!!
I think you gotta get it online. I just gave in...yesterday I did two coats of Z5...goin outside right now to start 2 coats of Z2. But gotta Z6 in-between...got a couple water spots overnight
Old Mar 21, 2004 | 09:44 AM
Kevin Overall
Zaino is not sold in any retail stores, only from the home office and from distributors like myself all over the country.
Do you have any kind of detailer spray right now? what I was saying is that any kind of detailer spray would remove a fresh water spot.............
Old Mar 22, 2004 | 10:25 AM
Taya's Avatar
Taya
Default A word of advise - Zaino and Hard water spots
I first saw Zaino on this site and gave it a try, yes I am sold on this product as well. However, if you have water spots risk in your area, I would highly suggest you to stay away from Zaino. You will not be able to remove water spots once you have zaino on your car. Period. Z6 does nothing and will not remove any HARD water spots. Do a litle search and you will find some other discussions about hard water spots... Drive safely.
Old Mar 22, 2004 | 10:37 AM
afr0puff's Avatar
afr0puff
Zaino HQ is just an hour drive for me. I've always wondered if shipping would be cheaper than the tolls/gas to take the drive over.
Old Mar 22, 2004 | 12:17 PM
Kevin Overall
Default Re: A word of advise - Zaino and Hard water spots
I think he was referring to some fresh water spots that popped up a a result of his last wash job. If so the detaile spray can gid rid of those.
Hard water spots can happen no matter what kind of wax or polish you use as I used many different kinds of waxes and polishes over the years before I ever heard of Zaino and sometimes had these spots, it depends on the contaminants in rain water and the area of the country you live in.
But most of the time you can remove hard water spots easily with some white vinegar, just rub it on and off the surface and it will take the water spots with it, if this does not work the spots are more than likely actual acid rain damage and has etched the clear coat and in that case you will need to use an abrasive on the surface....
Old Mar 22, 2004 | 01:22 PM
DavesZ#3's Avatar
DavesZ#3
What about using a claybar to remove hard water spots??
My wife's car was loaded with them and I got rid of them with a claybar prior to applying Zaino.
Old Mar 22, 2004 | 01:42 PM
Kevin Overall
Sometimes a clay bar will work on surface spots, but not etching...
Old Mar 22, 2004 | 05:07 PM
DavesZ#3's Avatar
DavesZ#3
True. I guess I was lucky enough that hers were all on the surface even after years of abuse.
Chris350z03
Oct 8, 2023 07:19 PM
ablaine
Nov 29, 2016 10:13 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
