How to remove Zaino build-up on edge of clear bra?
Old Oct 14, 2004 | 02:27 PM
mwaller's Avatar
mwaller
Default How to remove Zaino build-up on edge of clear bra?
What is the best way to remove the white polish residue that gets caught around the edges of a clear bra? I'm hesitant to use a toothpick etc for fear of scratching the paint. Any thoughts?
Will a clay bar do the trick?
Mika
Old Oct 14, 2004 | 04:03 PM
DavesZ#3's Avatar
DavesZ#3
I doubt you'd get the claybar into the small groove along the edge. If you do the toothpick carefully enough scratching shouldn't be a problem.
Old Oct 14, 2004 | 05:05 PM
spaceman's Avatar
spaceman
I have the same problem with my clear bra but I use NXT. I have not found any good way to remove it,
Old Oct 14, 2004 | 05:58 PM
Rahtok's Avatar
Rahtok
I use a toothpick... just be gentle, and use the edge almost parallel to the metal.
Old Oct 14, 2004 | 07:01 PM
SungNamZ's Avatar
SungNamZ
With a little luck, DOC will jump in. I know this, if you want to remove Zaino you use alcohol. Can you do it with a "Q" tip and then re-Zaino. I might suggest you call Sal @ Zaino!
Old Oct 15, 2004 | 07:38 PM
HotRodGuy's Avatar
HotRodGuy
50/50 alcohol and water. Rub it on a cloth and then rap the cloth around a popsicle stick shaped object.
Or put the alcohol/water mix on a qtip
Old Oct 15, 2004 | 10:10 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I wholeheartedly argree!
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
