350ZTT 1/4 mile times
To all 350Z owners with Forced Induction
There are some pretty potent Z’s emerging across the country 400+whp… Are any of you guy’s taking them to the track, Besides MRC Racing or Performance Motorsports?
I'm not putting out no 400 hp. Don't want to blow the engine. Waiting for more mods before I boost higher.
Oh yeh, go easy on the et's, I'm still learning how to drag and tune the car for racing.
Wow..... I know there are a strong number TT Z's out there... From CA to CO to NY... It seems like the only guys that are representing are MRC and Performance... I'm not a big drag guy... But when I get my TT installed... I'll go to E Town to see what my trap speed is...
first time with the 400+rwhp and I hit a 13.1 @ 119. The track was poorly conditioned 50 degrees as well as my 0-60' being 2.4 not helping.
Just got new treads and suspension so I should be perfect for upcoming summer. I should be in the 11's.
The Greddy e-manage only has one set of mapings. I have the profec-b boost controller, but I'm waiting for the Walboro Fuel Pump to run higher boost. At 5.4 psi I'm getting 362 whp. I like it. I'm still fighting gasgette leaks between my down pipes and waste gates.
I'm also getting 13.5 a/f at 6000 rpms. Not good.
Let me know. Thanks,
Originally posted by igottaz2003
440 whp. Wow. What are you...using for fuel management?
Originally posted by FairladyZ
IgottaZ,
Very nice set-up. Off topic but does your tv tuner work? Where did you place your antenna, and what kind did you get.
IgottaZ,
The biggest problem is with interference. Just driving down the road I get lots of rips in the picture. If I'm on a hill with nothing around me and Iim at a stop, I get perfect reception.
I had a this set up as list
and I'm ran 12.400s on 1/4 with out nitrous
(cause my goal is mid 11s so I just mount Nitrous wet system) My Boost was 65kpa
we don't have track on my Island so this time is base on GTech
But we have some event on Guam Drag so yesterday I'm shipping my car to Guam so after next I can post some my Time from the track
My pland is 75kps (around 11psi) + 50 ~ 75 Nitrous
My Turtle
1> Nismo Cam
2> Racing Edge Converter
3> B&B Exhaust for 03 - On Nissan 350Z w/ 4" Elliptical tips
4> Cat Delete pipes for the Nissan 350Z
5> 50 Shot of Nitrous Wet
6> Valve Body Upgrade
7> UR Pulley kit
8> 9.5:1 CP Piston
9> Pauter PRO Rod
10> Sard 255 Fuel Pump
11> Technosquare ECU reflash = " L " Spect
12> APS TT Kit 8 ~ 10 psi Boost so far now
13> ADR M Sport 18” ( fornt = 245 Kumho Rear = 275 BF Goodrich Drag ..)
14> Nismo Wing
15> Apexi Fuel , Oil , EGT , Boost , Trans. Oil Tem Gauges
16> Greddy A/F Gauge
17> Nissan 6MT 3.58 F/D Gearing
18> HKS EVC II ( Boost Controller)
19> DVD player
20> HKS The Twin Power ignition amplifier
21> SGP Racing SST Brake Line Kit 03 - On Nissan 350Z
22> Progressive Nitrous Control System
23> JDM 350Z Clear Side Markers with Home made LED light
24> Willwood 14" Front Break kit
25> Innovate LM-1 + LMA2
26> Trans. Oil Cooler
27> Little more......
My Turtle
1> Nismo Cam
7> UR Pulley kit
8> 9.5:1 CP Piston
9> Pauter PRO Rod
14> Nismo Wing
19> DVD player
My Turtle
1> Nismo Cam
7> UR Pulley kit
8> 9.5:1 CP Piston
9> Pauter PRO Rod
14> Nismo Wing
19> DVD player
My Turtle
1> Nismo Cam
7> UR Pulley kit
8> 9.5:1 CP Piston
9> Pauter PRO Rod
14> Nismo Wing
19> DVD player
Thanks, FairladyZ. About the TV antenna...Believe it or not the stock antenna works the best. I also have a 4 inch show antenna and I can't even get radio stations much less tv stations with that.
cool, how did you do that (make it work). Splice the wires? I have a dvd player with a tv tuner. It has a spot to plug the antenna in. I would like to make it work.
