Drag NHRA, IDRC, IHRA, NDRA
T-netics 1/4 time!
Old Aug 17, 2005 | 10:42 PM
Z PHAT Z's Avatar
Z PHAT Z
Default T-netics 1/4 time!
Did 4 runs tonight at the 1/4 track. This is on Toyo tires. Also a video that i ran 13.07, My friend went home early so did not record the 12.88 run.
http://www.viper966.com/TrackVids/ZPhatZ130at108.MPG
Car #154
Old Aug 18, 2005 | 04:06 AM
Miraclekidjr's Avatar
Miraclekidjr
I was confused for a second, because I thought that the car next to you (in the slip) was the same car in the video. Isn't that a 4 door VW in the video? because if it was running 14.2 i would be very surprised.
Old Aug 18, 2005 | 04:32 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Damn your trap is low as $hit man. Is your track at altitude? Im trapping 107 with bolt-ons. Have you dyno'd it? Lowest I have heard from a Turboentics trapping before you was 110mph. Fastest trap Ive heard of was 114.9 in 93 degree heat. Is your car running right? Work on your launch some even on street tires 2.0's shouldnt be a problem for you.
Old Aug 18, 2005 | 07:15 AM
Z PHAT Z's Avatar
Z PHAT Z
Last time I dynoed with 358 whp/358 wtq at 7.5 psi. I don't know why my trap is so slow I will check out the altitude of the track. Thanks.
Old Aug 18, 2005 | 07:33 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Why are you not getting the full 8psi? What where your A/F ratios like? I know your not a drag racer, but Im still very shocked you didnt trap much higher....where you shifting at redline?
Old Aug 18, 2005 | 11:45 AM
mojo powered's Avatar
mojo powered
I would also have expected a higher ET than that.. subscribing to hear more about this
Old Aug 18, 2005 | 12:05 PM
Z PHAT Z's Avatar
Z PHAT Z
I don't know why I didn't get the full 8 psi when I dynoed my car. I had the Stillen headers when I dynoed it. There seems to be no leak or any sort of problem that can be found. The number put out is like other T-netics car put out at 8 psi. This runs is with the stock headers on. I will re-dyno to see what's going.I shift at redline in every gear. Here is the A/F and dyno graph.
Old Aug 18, 2005 | 12:27 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Oh ok, I remember seeing your dyno. I asked why the one a/f graph was so different from the other one. Your very safe/rich. Have you thought about an exhaust? How do the numbers from the dynamometer compare to dynojet numbers do they read lower or higher? Im curious to see if putting your stock manifold back on will yield quicker spool.
Old Aug 18, 2005 | 12:40 PM
Z PHAT Z's Avatar
Z PHAT Z
That's also why i'm swapping back to the stock manifold in hoping that it would spool quicker. I have a Borla TD exhaust but need to do a reverse y-pipe to connect it to the down-pipe. The Dynamometer reads average about 13% to 15% lower than the Dynojet machines. The dyno shop is on vacation until end of August, then I can do a dyno comparison.
Old Aug 18, 2005 | 01:18 PM
Integrity's Avatar
Integrity
Isn't the Borla TD from the cats back? Will you be getting rid of the Borla?
Old Aug 18, 2005 | 01:33 PM
charlie_rdstr_Z's Avatar
charlie_rdstr_Z
Why don't you even list your headers in your mods?
Old Aug 18, 2005 | 05:17 PM
Z PHAT Z's Avatar
Z PHAT Z
I took the Stillen headers out before I did the runs. The headers is now for sell in the classified forum.
Integrity:
Yes Borla is a catback that's why i'm fabricating a reverse y-pipe from the down-pipe to the Borla. I'm keeping the Borla though.
Old Aug 18, 2005 | 06:45 PM
Madelinot's Avatar
Madelinot
Hey, I had the same problem some weeks ago. The car was only boosting 6.9psi while I see 8.0 on the streets. The results was only 342whp (Mustang Dyno). Yet, I ran a 12.7@114.2 last weekend in my G35. Something doesn't add up for sure...
Old Aug 19, 2005 | 04:13 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Wow thats more like it. 115 mph out of the box tune T-netics?? What other mods do you have?
Edit-just saw you have a G35 with an APS TT kit. Your post is worthless here when we are speaking of Turbonetics times....
Old Aug 19, 2005 | 04:28 AM
95snoozer's Avatar
95snoozer
it is the load that the dyno places. it means it wasnt placing a true street lad on your car.
but on the otherhand, if they increased the load you would probably make lower numbers and the extra ps would even it out or just edge it out
nyways, the ca in this tread should trap 110+
y car can with less than 300 hp
Old Aug 20, 2005 | 05:37 PM
odarabla's Avatar
odarabla
Default Stillen Headers on a turbo engine. YA RIGHT
I am surprised that no one picked up on this before. This guy must not know what he was talking about. You cannot install any kind of performance headers on a turbo powered car. If you install headers, how could you install the turbo manifold. Then how would you boost/spool up the turbo. Please you are not impressing anyone with your crap. This is an impossible task, it cannot be done. I am appauled at the fact that I come on this site to get info about my car from know nothings like you.
Old Aug 20, 2005 | 06:02 PM
charlie_rdstr_Z
Ignorance is bliss. Please read up that the turbo feeds off the downpipe and not the manifolds.
Yes you're a retard with an APC type R badge.
Old Aug 20, 2005 | 10:32 PM
Integrity's Avatar
Integrity
Do some research on the Turbonetics single turbo kit. You just owned yourself.
Old Aug 20, 2005 | 10:53 PM
odarabla's Avatar
odarabla
Default Turbo setup
Is everyone on this site retarded?? When installing a turbo setup on any car. you must change the exhaust headers to to fit the turbo manifold. The down pipe is the part of the exhaust from which the exhaust flows down through the turbo manifold.through the turbo, out through the catback system. So please before you even begin to Criticize someone for being ignorant, read up on this stuff your self. http://www.turbo-kits.com/350Z_turbo_kits.html Here is the link make sure you read up on it. Can you see the parts that look like headers? That is the turbo manifold, not the down pipe. STUPID!!!!!!!!!!!!!!!
Old Aug 20, 2005 | 11:09 PM
Z PHAT Z's Avatar
Z PHAT Z
This is so funny! Pleaseeeeeee......I'm the one with the turbo kit installed on my car and many other people on this forum. Listen and do some research on the Turbonetics Single Turbo kit. Call the company if you want. I don't know why I even response to you.
Here is the site....call them up yourself. http://www.turboneticsinc.com/
