Drag NHRA, IDRC, IHRA, NDRA
Tire pressure
Old Nov 8, 2005 | 08:55 PM
PTOWN's Avatar
PTOWN
Default Tire pressure
what is a good tire pressure for droping the clutch when drag raceing?
Old Nov 9, 2005 | 07:05 PM
silverTA 2002's Avatar
silverTA 2002
You shouldn't be dropping the clutch (I'm assuming you're on street tires). You should slip it slightly. If you drop the clutch, you'll either bog or spin.
In my car, anything below 28 lbs just slows you down. 28 is kinda a happy medium.
Old Nov 10, 2005 | 10:35 AM
barthelb's Avatar
barthelb
Master
For Streets i ran mine at 20 when NA and got a 1.9 60ft.
With DR's I 16psi and I slip/drop the clutch at 5000 and it grabs.
Old Nov 10, 2005 | 01:27 PM
Vamos_Rafael's Avatar
Vamos_Rafael
16 psi??
that is pretty flat
Old Nov 10, 2005 | 01:59 PM
barthelb's Avatar
barthelb
Master
It sure does sound like it but if you look at the tire its not that bad.
Originally Posted by jvanquish
16 psi??
that is pretty flat
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
