Drag NHRA, IDRC, IHRA, NDRA
Best Drag Setting for Tein Flex
Old Mar 20, 2006 | 10:21 AM
mrtomcat's Avatar
mrtomcat
Default Best Drag Setting for Tein Flex
Anyone have the Tein Flex and drags heavily? If so what's your preferred setting?
Old Mar 20, 2006 | 01:21 PM
Alberto's Avatar
Alberto
Cranky FI Owner
softer the better, more weight transfer to the rear = more traction....
Old Mar 20, 2006 | 02:43 PM
mrtomcat's Avatar
mrtomcat
softer all around or is it ok to go soft in the rear and stiffer in the front?
I loooove the stiffer handling from having it stiff in the front, much more control on the steering
Old Mar 20, 2006 | 03:07 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
id like to see your 60 foots after you take it to the track and try the different settings
i personally dont like the back too soft cause i feel like the car dips way too much
Old Mar 20, 2006 | 07:13 PM
Alberto's Avatar
Alberto
Cranky FI Owner
If you feel much more control with a stiffer front, then Id take that over a .1 reduction in 60ft at your power level. I turn my fronts to full soft, and my rear is permanent at 6/15-Im on JIC's not Teins but same concept....
Old Mar 20, 2006 | 07:41 PM
mrtomcat's Avatar
mrtomcat
it'll be interesting to see. I hope I get a few test runs in next week before IDRC on April 8th
Old Mar 28, 2006 | 09:58 AM
dirtroad's Avatar
dirtroad
i noticed some wheel hop when i dropped my settings to 5 and 5. better results with it set to 16 and 16. i'm also considering raising my ride height in the rear - too much neg camber right now with it lowered basically as far as the tein's allow. any tests yet, tomcat?
Old Mar 28, 2006 | 11:50 AM
mrtomcat's Avatar
mrtomcat
interesting, so you got better results with the spring at the stiffer setting...just from street driving the stiffer settings seem to be better for me as well
My car is at brainstorm for the next 2 days to get the racelogic traction control installed and to tune the water/methanol injection.
scarily I won't be able to do any test runs prior to IDRC on the 8th...
nanotech
Oct 2, 2015 05:02 AM
