Drag NHRA, IDRC, IHRA, NDRA
Inexpensive drag wheel and radial set up.
Old Sep 3, 2006 | 12:41 PM
  #41
corsair's Avatar
corsair
http://cgi.ebay.com/ebaymotors/1993-...ayphotohosting
Old Sep 27, 2006 | 10:14 AM
  #42
DSport G35's Avatar
DSport G35
Will any of these setups fit with the OEM Brembos?
Old Oct 24, 2006 | 10:07 AM
  #43
doc10374's Avatar
doc10374
What about putting 17" DR's on the 17" stock rims? What size tire would you use? I've never inquired about DR's so I have no clue about sizes. Thanks for the help in advance!
Old Oct 24, 2006 | 12:30 PM
  #44
BluZee's Avatar
BluZee
Some 245/45-17 Nitto DRs would fit.
Ive considered doing that myself.
Old Oct 25, 2006 | 08:57 AM
  #46
dlt1cy's Avatar
dlt1cy
Originally Posted by 98MODMTR
No ****, Mustang wheels have the same lug pattern?
If that's the case, I have a set from my 89 w/ ET streets already mounted.
94< match. The 89s are 4 lug.
Old Oct 27, 2006 | 09:32 AM
  #47
scotts300's Avatar
scotts300
16x8.5" 300ZX TT wheels do not fit over the rear brembos (unless you shave the splines on the Z32 wheel).
Old Apr 30, 2008 | 04:28 PM
  #48
Kingofvacuity's Avatar
Kingofvacuity
http://boise.craigslist.org/pts/660095502.html
Would these work fine?
Old May 1, 2008 | 05:57 AM
  #49
NA&CH's Avatar
NA&CH
This is a good thread. Possible sticky?
Someone posted it a few up which of these will work with oem brembos? Or should we get stock 17s for DRs?
Thanks
Chris
Old May 1, 2008 | 06:23 AM
  #50
tywinter's Avatar
tywinter
Thanks
Chris
+1
It would be nice to have a compiled list of set ups with weights, sizes, offsets/backspacing, cost, ect.
Old May 1, 2008 | 06:38 AM
  #51
Gooey's Avatar
Gooey
I use 15x8 Jegs wheels. They are superlight and sexy! I havent really weighed them but it felt like nothing when I lifted them
275/50/15 BFG DR's cut couple of 1.7-1.8
Old May 2, 2008 | 06:17 AM
  #52
gotime242's Avatar
gotime242
yeah id love to put some MT ET's on the stock 17's but it doesnt look like the tire sizes are going to be ther for it....the only one that will really do the trick is the 275/40/17, but thats prob too wide with not enough sidewall...
has anyone mounted MT ET's on the stock 17's?
Old May 2, 2008 | 06:44 AM
  #53
95snoozer's Avatar
95snoozer
thats enough sidewall, but you may need to roll fenders
my friends camaro hooked up on the 17x275 et streets and he made 540 at the wheels and trapped high 120s
Old Sep 13, 2008 | 05:45 PM
  #54
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
What 15" wheels are there that are lightweight, cheap, and 8" in width? I'm about to get a 26"x8.5" slicks, so I'd need 2 lightweight and cheap wheels. And no, I don't want to get Jegs or Welds or other racing wheels at the moment.
Old Sep 15, 2008 | 05:18 PM
  #55
skaterbasist's Avatar
skaterbasist
I bought the same setup used. (MT ET's & the same rims).
Is it normal for these to feel unstable at high speeds? Just before finishing the 1/4 mile, I can feel the car float around, which definately scared me the first time.
Old Sep 15, 2008 | 05:28 PM
  #56
3hree5ive0ero
Retired Admin
I doubt you're going down the track at 150. Which means your tire pressure is too low.
There's a saying in drag racing. I think it goes something like "you haven't drag raced until you do the slick dance going down buck fifty."
Old Sep 18, 2008 | 09:14 AM
  #57
Nealoc187's Avatar
Nealoc187
Rota produced 15x8" Slipstreams in 5x114.3 bolt pattern for a while. They no longer produce them but if you look hard enough you might be able to find some. I bought a set of 4 this spring because they are becoming so hard find and I sold two of the 4 (bought them for drag slick duty).
I am not sure how the offset would work on a 350z though, I bought them for use on my front driver. I can look at the box later and let you know the offset. I know they'd fit for you but they might be tucked way inside the fender, not sure.
Old Sep 18, 2008 | 09:21 AM
  #58
3hree5ive0ero
Retired Admin
Thank you, sir, for your help. If you don't mind, though, I'd like to know the offset.
https://my350z.com/forum/wheels-tire...ls-offset.html
^ In that thread, I posted a link (and 2 other members also) to a wheel that I'm currently leaning towards. Do you think you can give me your opinion on them? I think it was post 12.
Old Sep 18, 2008 | 10:54 AM
  #59
WheelDude.com's Avatar
WheelDude.com
Vendor - Former Vendor
Rota still produces this size and we have it available. The exact wheel specs are as follows
SLIPSTREAM 1580 e40 5X114.3 73 FBLK
These wheels are very light and the 15x8 model is only 14 lbs The wheels will be pretty tucked on a Z though.
-Dan
Old Sep 18, 2008 | 11:06 AM
  #60
Nexx's Avatar
Nexx
-Dan
how much for 2?
