Drag NHRA, IDRC, IHRA, NDRA
drag racing.. rims, weight vs size
Old Jun 11, 2006 | 02:49 AM
Z ELIMINATOR's Avatar
Z ELIMINATOR
Default 1.895 ft times
307 RWHP. stage 3 stillen at that time. The stock factory converter. The car ran 13.0 at I- 41 speedway. The trackion was great off the line, the best I have ever seen. I now have a Pro Torque converter with a 3200 rpm stall and I will run my first 4 passes on the 19 inch set up and them switch my tires to the slicks and the skinney front tires. I got the weld 15 x 3.5 rims to fit the front by adding a 3 mm spacer. Total weight saving on the car for all 4 wheels is aproximently 62 lb. I have made a pulley change and now i should be at 317 RWHP. With this set up i am hoping to run 12.5's or better. I still have to install the line lock and then learn how to drive the car on slicks. The track we go to in Canada is not very good but i will post my times on June 25. I also have changed the gearing to 3.53 from the stock 3.3 gears. It gave me 2 tenths of a second diff, but does it ever pull hard in second gear. I had these gears in my 13.0 run.
Old Jun 11, 2006 | 04:41 AM
John@Victory's Avatar
John@Victory
you only needed 3mm spacers to fit 3.5 inch skinnies? what offset are the skinnies? i have been wanting to go with skinnies but i didnt want to experiment and find out i couldnt make them work either....
which welds are you using?
Old Jun 11, 2006 | 07:15 AM
BluZee's Avatar
BluZee
Originally Posted by Acree
Awesome. In that case, you know what to run.
-Acree
I didnt buy the drag radials for nothin'! I was just wondering since I wont be able to get out to the track for a few more weeks. Thanks for the input.
Old Jun 29, 2006 | 01:19 PM
MySunset350Z's Avatar
MySunset350Z
Originally Posted by audiblemayhem
see if you can beat my 1.63 with the same setup and let me know....
damn thats nice. nice job.
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
