Drag NHRA, IDRC, IHRA, NDRA
Drag Guru's-Help me choose my next Slicks/Race Tires
Old Jun 29, 2006 | 08:31 PM
jackie chan's Avatar
jackie chan
all out track performance?
1get et drags
2then et steets ( not the drag radials)
3m&h's, hoosiers and so on
4drag radials
Old Jul 4, 2006 | 08:36 PM
Ozzie@Hppracing's Avatar
Ozzie@Hppracing
I like overall st and strip the mickey drag radial. That is what we run on our race car. It needs a good burn out. Not to much or they get to hot and become slick. We usually do about 3 or 4 second burnout and let it roll out. We are always in the 1.29 or 1.30 60ft everytime. Also on alot of 350hp to 500hp cars 1.5 and 1.49's are not uncommon. just my.02
Old Jul 7, 2006 | 04:20 PM
Smooshie Butt's Avatar
Smooshie Butt
Dont forget that a larger overall diameter will give you a larger sidewall, thus allowing more sidewall flex, thus allowing you to grip better. It will also give you a slightly larger footprint.
And I've heard nothing but good things about the M/T DR's. I cant recall if it was Hot Rod or Car Craft who tested them, but they actually hooked better than the ET Street's they were previously using on the vehicle.
Old Jul 7, 2006 | 04:30 PM
DomZ's Avatar
DomZ
MT Street Radials, I have many-a-LS1 friend who swear by them. Most guys with over 400whp in my club use em'. They won't give you that "floaty" feeling at the track, which is the #1 thing people appreciate besides the gobs of traction on the street and at the track.
Old Jul 7, 2006 | 05:14 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by JG 350Z
One thing I've also read about drag radials is that its a little more likely to break something. The thought is that a lower profile sticky tire puts more "shock" on the drivetrain vs the bias-ply slicks. A little bit of wrinkle and sidewall helps.
I'd go with a DR over a bias ply slick any day of the week.
I broke an axle running a bias ply ET Street, and I haven't broken an axle running my BFG DRs.
Furthermore I've pulled better 60's with the DRs than the ET streets.
Bias ply tires are old news. The new DRs (BFG, MT) have taken plenty of cars WELL into the single digit E.Ts, so I really see no reason why anyone would buy a bias ply drag tire anymore. Not to mention how much more livable they are.
I'll be selling my ET streets soon for a set of ET street RADIALS for my 15in weld drag wheels.
Old Jul 7, 2006 | 05:30 PM
jackie chan
i personally think a dead hooking dr is worse on a drivetrain than a dead hooking bias ply tire. here is what a 26x11.5x17 et streets do on my stocker cobras my suspension is anything but drag friendly. eibach lowering springs, koni adjustables up front and stock replacement shocks out back. bias ply tires seem to be slightly more consistent as well. this was a 1.66/12.080 pass
Old Jul 7, 2006 | 05:36 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i want a picture of my car doing that..... wonder if i was close on my 1.63 on MT drags??
i need a new photographer!!!
hey jackie, i will be out at the track next time its not raining, look for the black Z with dark bronze rims, and way ahead of you!!
Old Jul 7, 2006 | 05:52 PM
jackie chan
haha, i ran an 11.93 wed. that should be closer to mid 11's in winter time(if my motor stays together). i have an s trim in the works. i need to do a little upkeep on my car and work on the susp. with 13-14psi and meth injection i should be in the low 11's come winter
Old Jul 7, 2006 | 06:57 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Wheel lifting bastard. My car will never do that, it doesn't have enough weight transfer.
Old Jul 7, 2006 | 10:07 PM
Nealoc187's Avatar
Nealoc187
Well I have some experience on the ET Streets now. I'm not a huge fan of them. 60 times seemed to vary by almost a tenth on both occasions at the track with them, though bear in mind this IS my first time on a sticky tire in over two years, and I've got well over 2x more HP than I've ever tried to launch on a sticky tire as well. They seemed inconsistent on the burnout too, sometimes I could burn them down while sitting in place, and other times I couldn't stay in place at all and they immediately dragged me forward. Pulled a best of 1.90 (twice) on them, no suspension mods except some weak lowering springs, front wheel drive. Didn't feel floaty on the big end of the track though which was rather suprising, even at 10.5psi hot, at 120+ through the traps. 12.18 @ 120.3 with the 1.90 was the best pass I made on them. I'll be purchasing a set of M&Hs when my buddy decides he needs these ET Streets back that I'm borrowing from him.
Old Jul 9, 2006 | 06:26 PM
Metal Heart's Avatar
Metal Heart
I'm gonna post as a free bump... mainly because you answered a question no one else did... you CAN fit 16s over the Brembos on a Track Z.
EnjukuRacing
Sep 30, 2015 06:55 AM
Tochigi_236
Sep 27, 2015 03:40 PM
