Drag NHRA, IDRC, IHRA, NDRA
Drag Setup for '07
Old Oct 21, 2006 | 05:10 PM
TheCajunStyle's Avatar
TheCajunStyle
Default Drag Setup for '07
Just wanted to share with you guys what I'm looking at for a drag setup for next season:
MT ET Street 28.00 x 12.50-15
http://store.summitracing.com/partde...5&autoview=sku
I currently have Nitto 555R (275/40-17) on Cobra-R rims...This effectively gave me a top of 4th gear speed of 109.48mph...
The MT ET streets that I linked to above are approximately (318/52-15)...This would effectively give me a top speed of 119.5mph in 4th gear. To put it all in perspective, this setup uses 8.9% less revs/mile than the Nittos.
The fact that I would no longer need to shift into 5th would definitely help my ET--since I was trapping at 111-113mph, a shift into 5th was required (which cost me 0.1s or 0.2s on my ET). This new setup, I believe, will save me a couple of valuable 0.1s on my launch as well... I believe it will also help improve my trap speed as well by 1 or 2 mph...
If you guys can poke any holes in my theory, I'd like to read what they might be... The only information I haven't been able to obtain are the weights of each tire for comparison....
Also a recommendation on very lightweight 15" rims would be appreciated. I don't know of any good brands that manufacture a lightweight 15x10 rim.
Old Oct 23, 2006 | 07:29 AM
Alberto's Avatar
Alberto
Cranky FI Owner
28" wont fit wthout extensive fender modification. Most guys have returned 28" slicks. Just go with a 27", or consider a 3.3FD and 26" slick...
Old Oct 23, 2006 | 03:56 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i am going to make my 28x9s fit after i roll my fenders, there is NO way 12.50s will work, the 28x9s will be just fine, no need for any larger...
Old Oct 23, 2006 | 04:33 PM
TheCajunStyle
I hope you really don't mean 28x9..............
These are all the MT ET Street options:
* 26.00 x 10.50-15
* 26.00 x 10.50-16
* 26.00 x 11.50-15
* 26.00 x 11.50-16
* 26.00 x 11.50-17
* 27.00 x 10.50-15
* 27.00 x 10.50-16
* 28.00 x 11.50-15
* 28.00 x 11.50-16
* 28.00 x 12.50-15
* 28.00 x 12.50-16
* 28.00 x 13.50-15
* 30.00 x 12.50-15
* 30.00 x 13.50-15
* 31.00 x 14.50-15
* 31.00 x 16.50-15
* 32.00 x 17.50-15
* 33.00 x 18.50-15
Old Oct 23, 2006 | 06:32 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Even an 8" wide wheel is enough for a 11.5" wide slick, everybody pudges these. I dont think Ive ever seen a wheel wider than 9" with a slick on it. Mine are 8-8.5" wide, 11.5" slicks and are fine...you dont need to follow the width specs as much like on a street tire, trust me
Old Oct 23, 2006 | 08:49 PM
TheCajunStyle
wow, very good information! the less rotational mass, the better...even if it means using a narrower rim.
Thanks alberto!
I'm very seriously considering a 3.3 FD swap at the moment....... i found someone local to me, but he's got 40k on his Z; I have 15k. It's something maybe worth looking into...I will get those 0.4s off of my ET!
Old Oct 24, 2006 | 03:01 AM
Audible Mayhem
My350z
well, i know julian couldnt fit 28 x12.50 on his car, i am putting et drags (slicks) on mine, i dont know if they are the same specs, but 28x9s is about all that would possibly fit.
good luck either way , always good to see people drag racing!!
350Z_Al
Oct 29, 2020 07:44 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
rizzla
Drag
Sep 17, 2015 08:44 AM
