Drag NHRA, IDRC, IHRA, NDRA
MT drag radials vs Nitto drag radials
Old Oct 31, 2006 | 09:57 PM
Zendem's Avatar
Zendem
What kind of wheels will you be mounting the nittos around if you dont mind me asking?
Old Nov 1, 2006 | 08:00 AM
BluZee's Avatar
BluZee
These were 50% off from tirerack.com. 17x8 Weds Sports. Weigh 15.5lbs each.
Old Nov 1, 2006 | 11:01 PM
GFrnk69's Avatar
GFrnk69
How much do the stock 17s weigh?
Old Nov 2, 2006 | 04:52 AM
BluZee's Avatar
BluZee
24lbs.
Old Nov 2, 2006 | 06:14 AM
Julian@MRC's Avatar
Julian@MRC
I pulled a 1.60 on my MT DR's....The MT's are 100000000 times better..
Old Nov 2, 2006 | 06:28 AM
BluZee's Avatar
BluZee
I think we're missing the point. For my car, street tires spin too much and a MT tire bogs. I need something in between.
Old Nov 2, 2006 | 07:27 PM
sfarrah's Avatar
sfarrah
What tire pressures are you running and at what rpm do you launch?
Either increase your launch rpm or increase your tire pressures on the MT's. No need to go get new tires.
Old Nov 2, 2006 | 09:32 PM
TheCajunStyle's Avatar
TheCajunStyle
I've had some pretty decent times on Nittos.............
Sweet DR and wheel setup located here!
https://my350z.com/forum/showthread.php?t=227993
Old Nov 2, 2006 | 09:42 PM
Zendem's Avatar
Zendem
Damn thats kind of what i'm looking for, are they still on special? Any links?
Old Nov 2, 2006 | 10:01 PM
GFrnk69's Avatar
GFrnk69
How much we're they? and where did u get em?
PM me if u want
-Frank
Old Nov 3, 2006 | 04:46 AM
BluZee's Avatar
BluZee
I have a 5AT so I can only launch as high as 2500 rpm. I had 35psi in the tires.
Old Nov 3, 2006 | 04:50 AM
BluZee's Avatar
BluZee
PM me if u want
-Frank
Tirerack.com. The 17x8s are $179 each right now.
Old Nov 3, 2006 | 08:42 AM
Julian@MRC's Avatar
Julian@MRC
My car IS a street car..MT Drag radials are DOT approved radial, same as Nitto, except they actually work..
Old Nov 3, 2006 | 09:43 AM
BluZee's Avatar
BluZee
OK, lets start over again. The tires that I use daily are regular Z rated street tires. When I use them at the track they spin too much. I then tried a Mickey Thompson drag radial and they were too sticky and my car bogged off the line. Im going to try a less sticky Nitto drag radial and see what happens.
I wasnt talking about different tires being DOT rated or not.
Old Nov 3, 2006 | 09:46 AM
Julian@MRC's Avatar
Julian@MRC
If you bogged off the line on MT Dr's then you were not launching hard enough..that means they actually got traction, unlike the Nittos will do..The Nittos will spin just like your street tires.
Old Nov 3, 2006 | 10:07 AM
BluZee's Avatar
BluZee
I launched as hard as you possibly can with a 5AT.
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
rizzla
Drag
Sep 17, 2015 08:44 AM
