MT drag radials vs Nitto drag radials
How do the MT drag radials compare to Nitto drag radials? I have some 255/50-16 MTs and they bogged me down off the line. Ive been told that the Nittos wouldnt be as sticky and be a better tire for my car. Something like a 245/45-17. Thoughts?
First off, when you say "nittos" do you mean the 555R ?
Care to elaborate on this?
Originally Posted by jackie chan
i would rather run street tires than nittos if i were at the track
For my car I just need something a little better than street tires.
the 555rs i had before have a 400 treadwear, they suck...
if you really want a nice street tire that hooks, look at the BFGs, if you want a tire on some rims just for the track, MT all the way..
I know a guy with an H/C full weight 6spd LS1 bird that cuts high 1.6s and low 1.7s all day long on his 555Rs - he said he thinks that they recently changed the rubber compound on the 555R because his latest set (that he just put on about a month ago) is quite a bit stickier than his previous two sets.
Anyways the 555R isn't the best but it's not a bad compromise between street tire wear and traction for the track. It definately ain't an MT on the track though. I have the 555Rs and they are worlds better than even high end Z rated tires on the track on my car - they are no problem in the rain and also wear well - I've got probably 40 passes and burnouts on them and about 8000 miles and they have about 3/32nd left - MOST of that wear occurred in a single 4 day span after I did suspenison changes on my car and didn't immediately get an alignment (1.7 and 1.9 deg toe out on either side). Were it not for those 4 days I am convinced I could get through this year and half of next year on the same set of tires (say 15000 miles and another 50 track passes).
Originally Posted by 98MODMTR
1.7 60fts on stock suspension, 17inch 555rs
IMO, they were a great set of DRs for my first season of track experience (my 555Rs have a treadwear rating of 250), I could easily do 50 more runs on them as well
I already tried that and I actually ran slower. If I remember right when I first got them you had told me that I would bog and you were right.
