Drag NHRA, IDRC, IHRA, NDRA
Wheel spacers and drag racing?
Old Nov 7, 2006 | 06:21 PM
dlt1cy's Avatar
dlt1cy
Default Wheel spacers and drag racing?
Who drag races with wheel spacers? I am talking about the ones that have studs pressed in the spacer. Does anyone not recommend this and why not? I use rx7 wheels and they have 40 offsets. I would like to move them out just a little.
Old Nov 7, 2006 | 07:02 PM
Zendem's Avatar
Zendem
I do without any problems...i dont know if i would recommend them, but they have been ok and i have gone to the strip plenty of times with street tires and also a handful of times with DR's without any issues
Old Nov 7, 2006 | 08:16 PM
The wheels take a lot of abuse from drag racing because of the sudden torque applied to the back wheels. The OEM lugs seem to be strong. I do not know about extended lugs with spacers.
From a performance perspective, spacers are OK. For safety I would check the lugs after each racing day to make sure that they are OK.
Old Nov 7, 2006 | 09:01 PM
VeeTec's Avatar
VeeTec
I would not use them with RX7 wheels. There is enough room without them.
Old Nov 8, 2006 | 05:00 AM
dlt1cy's Avatar
dlt1cy
I know there is room, but I leave my front streets on that are 19x9 with 20something offsets. This makes my fronts wider than the rears. I'm thinking I'll try the spacers if I can find a decent used set. I have an at5 with a vorthech, so this shouldn't be too hard on the spacers/lugs.
Old Nov 19, 2006 | 05:49 PM
raptorbh12's Avatar
raptorbh12
i broke six of my OEM lubs racing, they are certainly not strong. the spacers with the studs already pressed into them is a very good idea and will saved your oem lug bolts from snapping.
Obadabot
Jun 18, 2023 11:31 PM
