Tested the MD 5/16" spacer (G35s 5at) at the strip yesterday
I finally got out to the track to test out my 5/16" MD plenum spacer. My previous best with a Z-pipe and a slightly modified Power Duct was a 14.32@97.73mph with a 2.15 60' in density altitude (DA) conditions of around -30'. Today at the same track, the DA was 1,210' so unfortunately the conditions were far from ideal. The only changes to my car since last time out was:
1) MD spacer
2) Newer replacement Avon MS550 tires
The track setup was the same. No spare, everything out of the trunk, and a 1/4 tank of 92 octane.
Today my best run was a 14.42@99.87mph with a 2.21 60'. With a few other 14.4s@99.6+mph with low/mid 2.2 60 foots. So what I saw today tells me the DA definitely hurt my ET a bit, but my MPH was REALLY good. I almost cracked 100mph. I ran three 99.5mph+ traps. My prior best trap was 98.2mph. Unfortunately, it appears that the hacked Power Duct (cover that goes over the front of the airbox) teamed with the spacer, does impact sub 4000rpms performance. My car felt boggy as hell off the line and my 60 foots proved that. Sitting in long lines probably didn't help either. Regardless, the spacer did help and does work, but it does appear that at least with the auto cars, initial acceleration is hurt if you've modified the intake. I reinstalled my unhacked Power Duct cover and the lowend does feel better. I've known the throttle response was better the spacer and stock Power Duct cover, but I just love that sound of the hacked cover. I guess with the spacer and hacked cover, the MAF isn't very happy. I wish I had brought the stock cover with me to the track. Oh well.
Well there you have it. I wish the data was better and I wish I could say the spacer improved my ET, but the difference in conditions influenced the performance negatively. The good news is the spacer did improve topend acceleration by about 1.3mph to 1.6mph, even in worse conditions.
1) MD spacer
the z tube is not the hacked intake you speak of correct?
I am thinking of picking up an auto 2003 soon. and would like to do a few basic things. Possibly a test pipe/spacer/intake.
are you contemplating the 3.5 gearset?
Originally Posted by JonsilvZ
I was wondering what is your fuel cutoff in manual mode? Mine cuts off at 6900rpm in manual mode vs the 6600 in auto.
