Drag NHRA, IDRC, IHRA, NDRA
Will these wheels work for me??? PIC!
Old Dec 19, 2006 | 06:48 AM
95snoozer's Avatar
95snoozer
Originally Posted by davidv
You went to the dragstrip once now you are ready for slicks? Relax a minute John Force and listen. You asked for advice before racing, but not after.
The best mod that you can make now is you: your technique. Your ET is all over the place. 14.49 - 15.57. Skilled racers are not fast - they are consistent. Practice on street tires and run 2.0 seconds every run. Practice your game. You will be able to run 14.49 seconds every run. Street tires are forgiving of mistakes. Generally racers do not break the rear axle on street tiers. Once your skills are the best that they can be, and are consistent, then it is time to graduate to slicks.
I went to the drag strip once and then bought slicks, whats wrong with that?
I went 14.1 at 100 my first time out at the track on street tires.
Then I bought slicks. Ran 13.44 at 101 my first time out at the track. Had I known how to launch at the time I would have gone much faster. I was timid and only launched from 3k and bogged.
clicks are the best thing to practice on and get consistant on because their traction IS consistant and you can hone your skills and see what works for you as far as shift points and techniques because your launch is a constant.
Old Dec 19, 2006 | 08:12 AM
Kenk2's Avatar
Kenk2
Professional
My main issue is buying new tires every month.. If I go to the track here every weekend, I will be buying rear tires once a month..
After the new year I will be running a 150 shot so I will most likely NEED to go with DR's as I will NOT be getting the traction with street tires..
Old Dec 19, 2006 | 04:33 PM
95snoozer's Avatar
95snoozer
I dont see how you would go through a set of tires in a month?
I doubt you make as many passes as I used to and tires would last the whole season.
I have spent the years I have owned the car on nitto 555rs, et streets, et drags, and m&h cheater slicks.
Old Dec 19, 2006 | 05:24 PM
Kenk2's Avatar
Kenk2
Professional
I am talking about being on street tires.. My BFG KDW's are already wearing and I have had them 3 weeks.. One time at the track with 6 runs and I did 'heat' the tires up a little bit...
2 of the main reasons I am getting these wheels is
1 get better traction
2 save my street tires
Old Dec 19, 2006 | 05:35 PM
Nice numbers. Most likely you will want to post your times here: https://my350z.com/forum/drag/233840-top-25-1-4-mile-times-for-tt-st-supercharger-nitrous-bolt-ons-stock.html
Old Dec 20, 2006 | 06:11 AM
95snoozer's Avatar
95snoozer
there is no reason you shoud go through a set of those in a month. I couldnt even go through a set of nittos that quickly and i do a billowing smokey burnout in order to get those properly heated.
I am all for getting DR. Those however are heavy wheels to do so on. your best sucess will be at 15-18 psi hot on in those tires
Old Dec 20, 2006 | 06:42 AM
Kenk2's Avatar
Kenk2
Professional
Is that with the Nittos of MT's??
Thanks
Old Dec 22, 2006 | 10:10 AM
Sean_350z's Avatar
Sean_350z
I don't see an issue w/ moving right to an ET Street or DR at all but no need to heat the street tires. Quick turn to get the junk off 'em is all you need. "heating" them is just gonna make traction worse. 1.9 or better 60s are doable on street tires w/ no burnout if you pedal the car well.
Old Dec 22, 2006 | 11:46 AM
95snoozer's Avatar
95snoozer
Thanks
nittos
on a good track prep I pulled 1.76 and went 12.57 at 109.17
my MTs I would run 12
Old Dec 22, 2006 | 11:51 AM
Kenk2's Avatar
Kenk2
Professional
yea the wheels are coming with Nittos.. I will use them up then grab some MT's.. Not sure what kind to get tho..??
RiujinZero
Apr 16, 2021 11:31 AM
JjL
East Canada
Jun 12, 2019 03:04 AM
davidm350
Oct 31, 2015 02:28 PM
tkuntz
Wheels Tires
Oct 3, 2015 05:58 PM
Shane86
Sep 17, 2015 05:33 PM
