Drag NHRA, IDRC, IHRA, NDRA
Which 6MT gear????
Old Dec 24, 2006 | 07:31 PM
rlwjr1's Avatar
rlwjr1
Default Which 6MT gear????
You guys with stock to fairly stock 6MT 350Z/G35, no blowers or turbos, what gear are you in when crossing the line in a 1/4 mile???
Old Dec 24, 2006 | 07:57 PM
fastGkid's Avatar
fastGkid
Old Dec 24, 2006 | 08:04 PM
FastZ33's Avatar
FastZ33
just started 4
Old Dec 24, 2006 | 08:05 PM
UGOTZ'D's Avatar
UGOTZ'D
just into 4th about 97-98 mph
Old Dec 24, 2006 | 08:06 PM
350Z here. Top of fourth gear. I doubt if I can push fourth much more than 103.3 MPH.
Old Dec 24, 2006 | 08:16 PM
And how about you? Post some time slips.
Old Dec 24, 2006 | 08:20 PM
Originally Posted by FastZ33
just started 4
Thats a pretty impressive set-up. Most likely you will want to post your times here: https://my350z.com/forum/drag/233840-top-25-1-4-mile-times-for-tt-st-supercharger-nitrous-bolt-ons-stock.html.
Old Dec 24, 2006 | 08:21 PM
Thats a pretty impressive set-up. Most likely you will want to post your times here: https://my350z.com/forum/showthread.php?t=233840.
Old Dec 24, 2006 | 08:24 PM
Originally Posted by fastGkid
Z/G Owner:
Yes Location:
St. Louis, MO
Which do you drive? 350Z or G35?
Old Dec 25, 2006 | 03:29 AM
kleefton's Avatar
kleefton
Top of fourth gear?
Fourth should be good to about 112mph. So unless you've got a power adder like a turbo or NOS, you aren't in top of fourth gear at the end of the 1/4.
Beginning of fourth gear here too.
Old Dec 25, 2006 | 07:32 AM
Originally Posted by kleefton
Top of fourth gear?
I am not sure where the beginning of fourth gear is? 2,000, 3,000 or 4,000 RPM? So you cross the quarter mile line at about 100 MPH and 4,000 RPM in fourth gear. Which means that you have about 2,500 RPM left until redline.
I am near redline in fourth gear. Either my car is weird or you guys are pulling my leg.
Old Dec 25, 2006 | 09:42 AM
04treefiddy's Avatar
04treefiddy
4th gear around 103.69 best so far.... My 4th runs up to 112 or so also. I am soon to going into 5th though.
Old Dec 25, 2006 | 09:55 AM
Alberto's Avatar
Alberto
Cranky FI Owner
If your not into 4th your doing something wrong. If you know what most Z's trapped -->98-103mph, and you knew your owns cars max speed in each gear, you wouldnt have asked such a newb question. 88mph is max in 3rd, if you finish in 3rd you might have palsy.
Old Dec 25, 2006 | 10:00 AM
Mid117's Avatar
Mid117
my 4th gear goes to 120
Old Dec 25, 2006 | 10:14 AM
bacalhau16's Avatar
bacalhau16
How are you guys pulling such crazy mphs in 4th gear. I would give my 4th up to 110mph max. I dont think I could ever come close to 120mph. Is that in a 05+ perhaps!
Old Dec 25, 2006 | 10:21 AM
Kam350z's Avatar
Kam350z
I have an O3 and 4th reaches up to around 120 MPH.
Old Dec 25, 2006 | 11:03 AM
bacalhau16's Avatar
bacalhau16
I guess I will have to go for a ride later on. I always shifted before that I thought!
Old Dec 25, 2006 | 04:09 PM
Alberto's Avatar
Alberto
Cranky FI Owner
If you run a stock rear diameter tire of 25.8-26.2" you dont, its 112mph hitting limiter at stock redline, I see you have a UTEC, likely raised the limiter. If you didnt and you still claim 120mph in 4th, you may have some incorrectly sized rear wheels/tires and thats whats causing your BS numbers Revups reach around 120mph because of the extra 400rpm's...
Old Dec 25, 2006 | 05:19 PM
rlwjr1's Avatar
rlwjr1
So, 3.90's will actually increase the 1/4 mile speed by allowing the car to go farther into 4th or maybe even 5th....
Old Dec 25, 2006 | 05:36 PM
Steve-O Z33's Avatar
Steve-O Z33
I hit the limiter in 4th at around 120 on the dyno. Not sure if the dyno gives an accurate resistance for accurate speedometer readings or not.
