Drag NHRA, IDRC, IHRA, NDRA
Which 6MT gear????
Old Dec 25, 2006 | 06:05 PM
rlwjr1's Avatar
rlwjr1
The point of gearing is to keep the car in its powerband. All the drag cars I have built were geared to cross the line at or near it's peak horsepower rpm in a 1:1 gear. If the vehicle is only crossing the line in 4th you are all loosing time and speed.
My car is rated at 280HP @ 6200rpm. If we are crossing the line even 3/4 of the way through 4th this is only roughly 4500rpm. 3.90's would at least raise this closer to the HP peak in 4th or maybe even 3500-4000 in 5th.
Old Dec 25, 2006 | 06:09 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by Steve-O Z33
I hit the limiter in 4th at around 120 on the dyno. Not sure if the dyno gives an accurate resistance for accurate speedometer readings or not.
You have an 06' with a raised limiter!!
Old Dec 25, 2006 | 09:15 PM
kleefton's Avatar
kleefton
Originally Posted by davidv
I am not sure where the beginning of fourth gear is? 2,000, 3,000 or 4,000 RPM? So you cross the quarter mile line at about 100 MPH and 4,000 RPM in fourth gear. Which means that you have about 2,500 RPM left until redline.
I am near redline in fourth gear. Either my car is weird or you guys are pulling my leg.
You are near redline in fourth gear, what like 6000 rpms?
Hmm...that would mean that you're trapping 109-110mph. If you have a stock tranny, stock wheels and tires, it just doesn't make any sense. Either your tachometer is broken or there's something you didn't tell us.
PS: Unless you consider top of fourth gear to be 4000rpms and up then I understand, but really you shouldn't be too much past 5000rpms when you cross the line. At near stock power levels that is.
Old Dec 26, 2006 | 01:52 PM
And how about you? Post some time slips.
Then again maybe not.
Old Dec 26, 2006 | 01:55 PM
Originally Posted by FastZ33
just started 4
Well this is the drag racing forum. I though that an example would be appropriate.
Old Dec 26, 2006 | 01:56 PM
Originally Posted by UGOTZ'D
just into 4th about 97-98 mph
Old Dec 26, 2006 | 08:54 PM
bacalhau16's Avatar
bacalhau16
kleefton, not trying to sound like a jerk, but I really dont think Davidv needs any drivng/racing advice. He should be the one answering questions for you.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Stevo Z
Oct 3, 2015 09:14 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
