Drag NHRA, IDRC, IHRA, NDRA
The best way to launch a Z.
Old Apr 6, 2007 | 09:46 PM
PP White Z's Avatar
PP White Z
Default The best way to launch a Z.
I have an 07 6-speed Enthusiast, what is the best way to launch in a drag race?
Old Apr 6, 2007 | 10:38 PM
Armitage's Avatar
Armitage
Can't speak for a 2007, but I find on street tires, between 2000-3000 RPM's and feathering the clutch gives me the best launch. Also make sure you drop your tire pressure to like 30psi or so.
More experienced drag racers can chime in.
Old Apr 7, 2007 | 07:08 AM
Practice.
Vary the RPM from 2 to 4,000.
Vary the clutch technique from dumping to slipping the clutch.
Vary the tire pressure from 20 to 30 PSI.
Note the factors on your time slip. Repeat what works best. Discard what does not.
Old Apr 7, 2007 | 07:19 AM
techcontrol's Avatar
techcontrol
Strap two of these to the hatch. No loss of traction guaranteed to improve ET by 7 seconds if you can keep it on the track. J/K
Attached Thumbnails The best way to launch a Z.-450px-jato_bottle.jpg   The best way to launch a Z.-800px-c-130t_hercules_blue_angels.jpg
Old Apr 7, 2007 | 09:07 AM
PP White Z's Avatar
PP White Z
Originally Posted by davidv
Practice.
Is dumping or slipping a better way to launch? I mean is there like a definit dumping or slipping answer for 350z's? I mean WRX for example, the best way to launch is slipping the clutch always. I just really dont like the idea of slipping it, lol.
Old Apr 7, 2007 | 09:19 AM
You can generally gage traction on the staging pad after the first practice run. If traction is good, you can get more aggressive with the clutch. If traction is bad, go a bit easy. Of course you might be able to try the other lane.
bcoffee20
Nov 19, 2015 06:39 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
