Drag NHRA, IDRC, IHRA, NDRA
Congrats to AJ!!
Old Apr 29, 2007 | 08:15 PM
  #41
bacalhau16's Avatar
bacalhau16
I think it already may be an inside joke or phrase for them.
Cant wait to see how you do AJ. Good luck next time out!
Old Apr 29, 2007 | 08:18 PM
  #42
surfcity40's Avatar
surfcity40
Originally Posted by bacalhau16
I think it already may be an inside joke or phrase for them. Good luck next time out!
no question.
Old May 3, 2007 | 08:42 PM
  #43
aj_350z's Avatar
aj_350z
so new news..tuned my car a little and we turned up the boost and the out come was pretty good..408whp 431 ft/lbs torque. all on pump gas. headed out to the track tomorrow, ill let u guys know the good news and maybe jermey can get that dyno sheet up here..
Old May 3, 2007 | 09:17 PM
  #44
bacalhau16's Avatar
bacalhau16
Wow, thats pretty sweet. Nothing wrong with those numbers. Good luck at the track tomorrow.
Old May 3, 2007 | 09:25 PM
  #45
Audible Mayhem's Avatar
Audible Mayhem
My350z
its jeremy biatch!!!
can we say 120 plus on a stock car with TN at 9.9 psi...
Old May 3, 2007 | 09:35 PM
  #46
bacalhau16's Avatar
bacalhau16
Ya, that looks like its a pretty fun car.
I would hate to see you guys only trap like 118 though, because you are adimit with the 120 plus! Either way, we gonna get a video of this?
Old May 4, 2007 | 04:24 AM
  #47
Audible Mayhem
My350z
116 with 355 hp, so with 408 and 60 more foot pounds of tq, a couple few mph should be easy unless we run into the gearing issue with 4th and 5th gear. might have to short shift 4th and see if that works, i know alberto and i had issues with this same situation.
Old May 4, 2007 | 07:36 PM
  #48
Audible Mayhem
My350z
yeah guys, we couldnt figure out this issue that we were having on the dyno with it only allowing the utec boost control solenoid to make 9.9 psi no matter how much we turned it up. i wanted to get in the utec and turn the boost down to stay in the 80% column.
well on the street it makes 10.5 pounds in fourth and fifth gear so that throws it up in the 90 % load column and i have that set up very very rich cause i couldnt get there on the dyno yet.
sooooo went to the track tonight, car went 11.77 11.78 and 11.83 all around 115, it is trapping 93 at the 1/8th BUT in fourth gear, it is hitting that rich load site that i couldnt tune on the dyno so the car is running in the low 10s AFR and only picking up 21-22 in the top 1/8th where it normally picks up 25+. i tried to bring the laptop to tune it at the track but i forgot the usb cable damnit!!
next wed will be much much better!! i know we can run 11.4 on this stock motor here soon...
Old May 4, 2007 | 07:56 PM
  #49
jksstar's Avatar
jksstar
badass, can't wait to see it once you get it all worked out
Old May 4, 2007 | 08:02 PM
  #50
bacalhau16's Avatar
bacalhau16
Thats still pretty impressive ET's. I also cant wait to see how the car does once its worked out.
Old May 5, 2007 | 04:03 AM
  #51
Audible Mayhem
My350z
thanks guys, i was going all around at the track looking for a usb cable. i was soooo pissed, i couldnt data log anything OR turn down the boost/lean out the 90% column, i always set up the unreachable higher columns to a safe rich AFR in case of overboosting. sucks we couldnt get it to reach over 10 psi on the dyno.
he did pull a 1.63 and a 1.67 on two of the runs. we will get that issue worked out and get back there next wed with the exact same set up!!
time slips and video in a bit
Old May 5, 2007 | 05:20 AM
  #52
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Car weight please!
Old May 5, 2007 | 05:24 AM
  #53
eagletanggreen
Got Track!!!!!
Nice times, going to the track tomarrow, with this new rad I just put in 54mm Koyo. Car runs so cool now, so maybe a higher trap. Local temps look in the 60's so not bad as far as weather.
Old May 5, 2007 | 06:36 AM
  #54
Audible Mayhem
My350z
car is bone stock weight except the passenger seat out. plus we have my slicks on it. thats it, full AC, everything...
i cant wait to put some C16 and get the boost issue worked out plus some weight reductions!! i think the car could go tens with that done...
good luck luie!!
Old May 5, 2007 | 06:39 AM
  #55
eagletanggreen
Got Track!!!!!
I think it could too. Are there no tracks open this weekend around your location?
Old May 5, 2007 | 07:43 AM
  #56
Z-Gad's Avatar
Z-Gad
Nice job Jeremy and AJ!!
I was hoping to see you guys out Wednesday night, but I guess you didn't make it.
On a side note, I drove the car up to Jacksonville on Wednesday to get my chassis cert done, drove it home, swapped tires and fuel and did my 6 NHRA license runs Wednesday night (last qualifying run was 9.18 @ 147.9). I had to keep it under 150 since I don't have a chute...)
Anyway, good job again and I'll try to make it out next Wednesday to atleast spectate (I have cords showing on the ET Streets, so no racing until I buck up for new tires).
Regards, Mike
Old May 5, 2007 | 09:20 AM
  #57
Alberto's Avatar
Alberto
Cranky FI Owner
I have been dethrowned as TN king, oh well I'm surprised it lasted this long, I knew a 1.74 and 1.83 60ft while good enough to hit 11's for me, wasnt gonna cut it forever. BTW-are you guys spraying out of the hole?
Old May 5, 2007 | 09:32 AM
  #58
aj_350z's Avatar
aj_350z
no spray at all..we are trying to get as far as we can with this setup..thanks everyone ill have the video/timeslips up today at some point..
Old May 5, 2007 | 09:41 AM
  #59
jackie chan's Avatar
jackie chan
r u guys sure thats not a 95 cobra w/a 350z body kit?
Old May 5, 2007 | 02:58 PM
  #60
Audible Mayhem
My350z
we are pretty sure john, it actually runs!!
no spray , yet. i cant imagine it on spray , that would be nasty, also cant wait till C16 goes in and turn up the boost a bit.
