toyo proxes t1r on the drag strip
i am thinking of going to the race track on friday. never run it before, (07 enth) and i am pondering between using my stock rims and tires or just stick with the 19 inch rims and toyos 285/35 rear i have on it. do you think the toyos are good for drag racing , i ve heard that they get greasy, instead of sticky, i dont know if it is true, but anyways should i stay with them or the stock ones are better??
The best 60ft times i was able to reach with those tires was 2.0. After a few runs it got worse, 2.1, 2.2.etc...I regreted using them cause now their bald and now i have to spend $$$ on buying new tires..
If you are stock or lightly modded go with stock, the extra weight of the 19s will put a damper on any gains from wider/ grippier tires. If you are heavily modded and can't get traction on stock tires, go for the Toyos
Well i am going to carry the stock rims + tires with me , and i will give it a try, but i am definitely going to run both the 19"s and the 18"s (stock), i will post the time.
I wanna get some kdws but I'm set up to where my front tires wear out a few months before my rears so I need new rears now and i just think it would look wierd with toyos on the front and kdws on the back. but hey I've got to do it sometime
well , i did some practicing of the launch (still new though) , however, wednesday i ran it , don't have the time slip on my computer, but i had two (it took me couple of min to jack up the car and change them, but i am stubborn and wanted to see the difference.) runs i pulled 13.583 - 1/4 , and 60f 2.19 this is with the stocks. it traped at 102,64. well what confuses me is that with the 19's i ran 60f- 2.22 and 1/4 - 13.612, but it traped at 103.4, what the heck whay is the trap speed higher? i guess it takes more from the dig to spin these big tires , but afterwards they are little bit better , so with some practice i will be able to improve it.
I use my T1Rs at the track and they are 285s. They preform pretty good. I am able to get a 1.9 60'. The higher trap speed can be from many things. Is there a weight difference between your stock and 19s? You might have shifted better. Or the 19s might change you gearing due to being a different overall size diameter.
I trap better with a slightly warmed engine (too much cool down hurts my trap) and worse with a heat soaked engine (exactly as you would expect).
So it might have just been difference in engine temp, etc.
