Drag NHRA, IDRC, IHRA, NDRA
new personal best: 60ft, et, and trap
Old Oct 5, 2007 | 08:56 PM
warmmilk's Avatar
warmmilk
Default new personal best: 60ft, et, and trap
all of which occured on different runs
time slips below, # 2658
over all it was a good night, i got 6 runs in in about 2.5-3 hours. first one was a 13.5 and the rest were 13.4x
i'm able to now pull consistant 2.0x 60ft's, as all my runs today show, except for that one great 1.987. now to start pulling consistant 1.9x's
btw, this is still on a bone stock 07
best 60ft: 1.987
best et: 13.412
best trap: 104.34
Old Oct 5, 2007 | 09:22 PM
VeeTec's Avatar
VeeTec
Congrats, seems like all the broken in 07's are trapping over 104 now.
Old Oct 5, 2007 | 09:49 PM
warmmilk's Avatar
warmmilk
i think my trap was more do to the 50* temp the being broken in, but maybe not
Old Oct 5, 2007 | 10:14 PM
JunJTan's Avatar
JunJTan
nice number, I wanna see an 105 trap speed at an stock 07 350Z which can evenly match is350 and bmw 335i.
Old Oct 5, 2007 | 10:24 PM
lafabritto350z's Avatar
lafabritto350z
nice times man...
Old Oct 5, 2007 | 10:32 PM
VeeTec's Avatar
VeeTec
Mine was trapping just over 104 last Sunday with 86 degree temps.
The clutch wasn't having a good launch though.
Old Oct 5, 2007 | 11:08 PM
VitViper's Avatar
VitViper
Nice job.
I noticed my traps slowly increasing even with shoddy 2.1x 60ft's and a messed up clutch when I was stock. Couldn't resist the urge to mod tho.
Old Oct 5, 2007 | 11:47 PM
warmmilk's Avatar
warmmilk
or it can be the whole break in thing
Old Oct 6, 2007 | 03:29 AM
shifty711's Avatar
shifty711
Good job.
The 07's are pretty strong running cars. With all my mods your still trapping 1 mph higher and your still stock.
Well, time for more mods for me. :-)
Old Oct 6, 2007 | 03:31 AM
shifty711's Avatar
shifty711
Oh, its time for you to update your signature
Old Oct 6, 2007 | 06:10 AM
NA&CH's Avatar
NA&CH
nice job. 07's are looking promising
Chris
Old Oct 6, 2007 | 07:52 AM
Very consistent numbers. Impressive driving.
Old Oct 7, 2007 | 03:13 PM
Peak350's Avatar
Peak350
I want 50 degree temps
My traps haven't gone anywhere since 3,000 miles, The only changes have been 1/8th mile and I'm starting to think its part weather and part driver (dropped 10 degrees ambient and I've gotten a lot better).
I think with that kind of weather and the track being in good shape (usually is here) I could pull .15 off my time and run a borderline 13.2/13.19 run without too much trouble, possibly even better than that.
Old Oct 7, 2007 | 09:32 PM
warmmilk's Avatar
warmmilk
.15 sounds like so little, but its so hard to get that last tiny bit out!!!
right now i'm aiming at a 13.3xx, but unfortunately, i don't think i'm gonna make it out to the track any more this year
Old Oct 8, 2007 | 05:12 AM
Peak350's Avatar
Peak350
I hear that, but I was able to pull time off with a 3 degree temperature change (200 feet in DA) and 97% humidity, with no VHT to work with. The track had grip because of rubber that was getting put down, but not like I'm used to.
I think I can get a better time. A friend I was running with went on the saturday after the wednesday we ran and he pulled 3 tenths off his best time, all of it in the 1/8th because the track was so much stickier.
Its all in conditions and driving the **** out of the car.
Old Oct 8, 2007 | 12:53 PM
Skorch's Avatar
Skorch
Man, I can't wait to take mine to the track. Going on the 20th if everything works out.
BTW, what RPMs are you guys launching at? And do you reduce the tire pressure at all?
Old Oct 8, 2007 | 02:59 PM
Peak350's Avatar
Peak350
Leave the tire pressures at 35 psi cold.
I'm launching at 4,500-5,500 RPM's depending on what the track holds and how my clutch likes me that day.
4,500 has my best time, 5,500 has my best 60' and 330' time.
Old Oct 8, 2007 | 04:50 PM
warmmilk's Avatar
warmmilk
damn, any time i try launching anything higher than 4k my clutch pedal drops. my best run was about a 3700 rpm launch
Old Oct 8, 2007 | 05:46 PM
Peak350's Avatar
Peak350
Slip it less and don't let it get so hot. Its close for me and sometimes I have to put my foot under it and pull it off the floor, give it less throttle, and wait for it to grab.
Old Oct 8, 2007 | 06:54 PM
warmmilk's Avatar
warmmilk
i tried the whole put ur foot under it and pull it up, i can pull up the pedal, but the clutch doesn't grip still, only the pedal goes up, not what's attached to it. but i'll try less slipping, thanks for the tip
