Drag NHRA, IDRC, IHRA, NDRA
5k launches = broke axle
Old Oct 11, 2007 | 09:31 AM
350z_2NR's Avatar
350z_2NR
Default 5k launches = broke axle
Well I posted pix here https://my350z.com/forum/event-photos/306627-pix-from-the-track-today.html
Anyway some friends rented the track and I was launching around 5k to 5,500 I made about 9 passes then on the tenth I broke my driver side axle. Anyone else had this problem? Or upgraded their axles?
Old Oct 11, 2007 | 09:33 AM
iStan's Avatar
iStan
ZR
A few people have. I know one of my local guys did with his Vortech Z.
He upgraded his axles, but I can't remember to what.
Old Oct 11, 2007 | 09:34 AM
CEO350Z's Avatar
CEO350Z
That's bad juju
ouch
Old Oct 11, 2007 | 09:36 AM
Alberto's Avatar
Alberto
Cranky FI Owner
What tires? How much power? What were you running 60ft wise?
I broke the shaft on a stock one on the street. Ive also broken the inner CV joint on my 2nd pass with DSS Level 5 axles! I feel your pain...btw-how were you launching? Always PRELOAD the drivetrain!
Old Oct 11, 2007 | 10:49 AM
350z_2NR's Avatar
350z_2NR
I might not have been launching right? I have Mickey Thompson ET streets, I just have APS TTs exhaust test pipes and susp. it's at 9psi and spiking 11. I'm guessing I have 420-450ish hp. The best 60 I had right before it broke was a 1.7 I had 1.8s before that. I just started doing my burnouts in 2nd with the break fuse out, and I just pull up to the line hold it on 5,000 slip the clutch a tiny bit and it usually doesn't spin. How do I preload the drivetrain?
Old Oct 11, 2007 | 11:00 AM
first350's Avatar
first350
there's probably other companies that have them too, but I know AAM carries at least 2 different sets of axels:
http://www.alteredatmosphere.com/mm5...ode=350Z_TRANS
Old Oct 11, 2007 | 11:07 AM
350z_2NR's Avatar
350z_2NR
Thanks for the find. I will be ordering those soon.
Old Oct 11, 2007 | 11:30 AM
Sorry about the incident. That's a lot of power (and abuse) for the OEM rear end.
Old Oct 11, 2007 | 11:32 AM
Alberto's Avatar
Alberto
Cranky FI Owner
OP-hold the clutch just under engagement point and dont drop it.
Did you break an inner/outter joint or snap the shaft?
Old Oct 11, 2007 | 12:52 PM
Zridder19's Avatar
Zridder19
ouch, sorry to see that.
Old Oct 11, 2007 | 06:43 PM
350z_2NR's Avatar
350z_2NR
Not really sure yet, it's at the Nissan dealer right now, where it happen is an hour and half from where I live. The dealer isn't fixing it, just had to leave it there until I got a car hauler. I think that it broke the inner, it looks to still be in one piece. At first I thought it was the tranny, but it would still go into first and reverse, I backed up about 2 inches and it made a horrible noise.
Old Oct 15, 2007 | 08:03 PM
350z_2NR's Avatar
350z_2NR
Alberto, I just watched your videos you're an awesome driver mad props. It kind of sounds like you are feathering it right before you launch
Old Oct 16, 2007 | 10:02 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Thanks, I have yet to launch the car to what I feel is even 90% of its potential. Id rather go home at the end of the track session. Still I pulled a 1.6 60ft...
Old Oct 16, 2007 | 05:38 PM
350z_2NR's Avatar
350z_2NR
So are you kind of feathering it? Whatever you are doing it is working great! a 1.6 is superb!! the best I had was a 1.7, what was the best you ran with your motor stock and just the turbos on?
Old Oct 16, 2007 | 05:47 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Turbonetics was a mild 1.7 60ft, ran 11.98 and two 11.99's back to back at 114-116mph. That was under 400whp...
What I do is blip the gas usually from say 4000-4500rpm's watch the tree and when the light drops I go from blipping therottle to slowly applying it while letting out the clutch. It makes the transition very smooth for me, and has worked for my buddies as well. When I hold a set rpm @ the line I bog when launching. Aceman here in MD ran .1 faster 60ft's immediately after using this technique, he is now running 13.0 NA...
Old Oct 17, 2007 | 05:44 PM
GolfinZ's Avatar
GolfinZ
^ interesting bert...gonna try that next time I hit the strip.
Old Oct 17, 2007 | 05:53 PM
Julian@MRC's Avatar
Julian@MRC
That technique worked for me as well, cut 1.6's a few times, however I smoked the single plate clutch i was using after about 3-5 times doing it..
I can tell you from experience, this car does not like launch control to be used , and your method is best,and safest.
Old Oct 17, 2007 | 07:17 PM
350z_2NR's Avatar
350z_2NR
I will try it at least once. thanks for the help guys. keep in mind bristol where i go is the slowest track ever!!! lol i am planning on try some other tracks in the near future.
Old Oct 18, 2007 | 12:02 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
we have tons of 1.5s on stock axles. its all about that fine line of barely slipping the clutch and fully releasing it.
i am sure some axles are stronger for some different years, we both have 03s that are launching hard here...
good luck !!!
Old Oct 18, 2007 | 05:30 AM
ACEMAN's Avatar
ACEMAN
Master
Thumbs up
Since i have been using this technique and installed the 4.08 gears i have really improved my times at the strip.. I was running a best of 13.3 no matter what i tried. Now i am on the verge of hitting some 12's with a full interior car minus the passenger seat and spare.
Thanks again for the advise Bert.
I have snapped a axle aswell, but that was by not preloading the drivetrain. Keep the clutch right at the engagement point with out the car moving.
Todd
