Drag NHRA, IDRC, IHRA, NDRA
cant beat 14.8
Old Dec 23, 2007 | 05:34 PM
steppinrazor's Avatar
steppinrazor
Default cant beat 14.8
somehow this is what i keep getting, a 14.8
here is the one slip i dint throw away
<i dont know what it all means>
reaction .776
i1 2.412
i2 6.549
i3 9.774
mph (i3) 77.242
i4 12.445
E.T. 14.826
mph 97.913
any advice on how to improve this would be appreciated
Old Dec 23, 2007 | 05:43 PM
Frostydc4's Avatar
Frostydc4
What track are you running at? Speedworld or Firebird?
Old Dec 23, 2007 | 06:04 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
2.4 60ft is one of your problems
Old Dec 23, 2007 | 06:23 PM
da45king's Avatar
da45king
Ahhh don't worry about. Drag racing is not for everybody.
Old Dec 23, 2007 | 06:25 PM
2fast4ya's Avatar
2fast4ya
reaction .776
i1 2.412
i2 6.549
i3 9.774
mph (i3) 77.242
i4 12.445
E.T. 14.826
mph 97.913
sounds like you need to do a better burnout and lower your tire
pressures-this will help bring your 60ft time down, judging by your
trap speed your car should do low 14 sec. if you shift and launch
correctly
Old Dec 23, 2007 | 06:34 PM
Zridder19's Avatar
Zridder19
Definatly have a problem there, Practice makes perfect
Old Dec 23, 2007 | 06:35 PM
singh's Avatar
singh
_______________
Exclamation
Something is wrong.
Even with a bad 60' like that, you should at least be trapping much higher. I think there is something wrong mechanically??
Old Dec 23, 2007 | 07:34 PM
The difference between 1/4 and 1/8 mile trap is 20.7 MPH. The car is running OK. Your shifting is OK.
Look at #313 above. Difference between 1/4 and 1/8 mile trap is 20.6 MPH. Essentially the same. The key difference is 60 foot time: 2.41 vs 2.17 seconds. 0.24 seconds makes a big difference in 1/4 mile ET.
Work on your launch and you will be running better than 14.0 seconds.
Old Dec 23, 2007 | 08:11 PM
HDPDZO6's Avatar
HDPDZO6
Originally Posted by gsingh350Z
Something is wrong.
Study up on track conditions and DA (then pay attention to where the OP is posting from), then rethink your statement. Feel free to edit also.
Old Dec 24, 2007 | 08:25 AM
steppinrazor
that slip was from speedworld but its almost the same as my times from firebird
Old Dec 24, 2007 | 08:31 AM
steppinrazor
your a thinker! great advice buddy, thanks!
Old Dec 24, 2007 | 08:34 AM
steppinrazor
correctly
ill work on the burnouts, i havnt paid much attention to that.. around where should the tire pressure be?
Old Dec 24, 2007 | 08:37 AM
steppinrazor
i need alot of work on launch still, i have a problem with getting a little anxious and peelin out at the line... im doing better with it though
Old Dec 24, 2007 | 09:01 AM
first350's Avatar
first350
burnouts don't always help w/ OE/street tires...many times it hurts (street tires get greasy if they're too hot).
I do a small peel-out when I'm going to the line to scrub the tires and get rid of debris.
Once you're at the line, forget about your reaction times, and just work on the launch...I use the ebrake to hold the car steady, then get the clutch pedal to be just at the engagement point w/ around 3K rpms - from there, it's just about feeling how much traction you have; you want to find the area between bogging the engine down and spinning the tires.
Old Dec 24, 2007 | 10:15 AM
Forget a burn-out on street tires: they are designed not to get hot. Just spin the tires a little to throw off any water or dirt.
I run 30-34 PSI on street tires.
Old Dec 24, 2007 | 11:10 AM
HDPDZO6's Avatar
HDPDZO6
Old Dec 24, 2007 | 11:28 AM
singh's Avatar
singh
_______________
I did consider his location, and he still should be running better times regardless. Track conditions were not given, so I assume that they were not poor, hence why the OP did not give the track conditions. If they were a major contributing factor, I'm sure he would have stated the track conditions.
Old Dec 24, 2007 | 11:42 AM
HDPDZO6's Avatar
HDPDZO6
Sure, he can run a better time with practice, but you initially indicated he should be trapping alot higher and even suggested possible mechanical issues with his vehicle. His trap speeds are within normal for that part of Arizona.
Old Dec 24, 2007 | 12:07 PM
Skorch's Avatar
Skorch
ryano85, a bunch of friends and I are planning to go to Speedworld on the 12th given that it's a dry day. You're very welcome to come with us - perhaps we can give you some pointers on how to launch your car better. I'd love to see more Zs there - last time I went I was the only one.
Old Dec 24, 2007 | 12:28 PM
warmmilk's Avatar
warmmilk
www.rangeracceleration.com
read and do everything except for the burn out, just to a quick scrub to clean off ur tires like everyone on here said
