Drag NHRA, IDRC, IHRA, NDRA
stock '08 on 26x10.50/17 MT ETstreets??
Old Jan 3, 2008 | 05:35 AM
nlzmo400r's Avatar
nlzmo400r
Default stock '08 on 26x10.50/17 MT ETstreets??
I have a stock '08 base and will be bringing it to the track on the 9th to see what she'll do. The only thing I may have done to the car by then is VLSD swap. I have some MT ETstreets here at my shop off of a friends mustang and would like to put them on, but am worried about the stock clutch components taking it well.
Ive read threads about guys with '07s having problems, and Ive also heard from friends that the 08s have a different 'revised' clutch slave that is supposed to rid the problem the '07s had. Basically will I be safe running these aggressive of tires, or should I stick with the stockers?
Old Jan 3, 2008 | 05:37 AM
Gooey's Avatar
Gooey
I ran 26" drag radials with no problems on my 07. Tire size was 275/50/15 so I think its almost the same size as those slicks. I have at least 25-30 passes with them with no problem
Old Jan 3, 2008 | 05:40 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Some drivers have a tendency to slip/burn the clutch more than others. Ive never seen anybody snap an axle with a stock clutch, even dropping the clutch the stocker seems to soften up the launch and slip some on its own. Ive seen people try to feather the stocker on good tire and end up burning it. Slip it minimally (with MINOR preload not a whole lot) so you dont
burn it. Good luck.
Old Jan 3, 2008 | 06:22 AM
nlzmo400r's Avatar
nlzmo400r
sounds like I'll go ahead and throw em on. I'll probably do a couple of runs on the stock stuff too just for comparison.
Old Jan 3, 2008 | 06:43 AM
cosmec's Avatar
cosmec
post your results when you get back!
Old Jan 3, 2008 | 08:01 AM
jackie chan's Avatar
jackie chan
worst case start at 20psi and go, even spinning through 1st gear with those should get you 1.8s. i use them on my s/c 95 cobra
screenshot when i had them on stock wheels
Old Jan 3, 2008 | 08:47 AM
singh's Avatar
singh
_______________
I would run completely stock first. Just to put things into perspective. Then I would go from there.
Old Jan 3, 2008 | 09:36 AM
Alberto's Avatar
Alberto
Cranky FI Owner
30+psi on ET Streets is silly. Start at 20psi, adjust launch points, go down 1psi if more traction is needed per run. Keeping a log of launch rpm, psi, launch technique and results will do WONDERS for your improvements.
Old Jan 3, 2008 | 01:41 PM
scotts300's Avatar
scotts300
Agreed, especially the concrete facts like tire psi, burnout "length", and RPM at launch. And by the end of the day, you may find yourself down at 10-12psi like I have on those tires.
Old Jan 3, 2008 | 02:00 PM
I agree. Work on 60-foot time. When you get it down to 2.0 seconds add the competition tires.
Old Jan 3, 2008 | 07:48 PM
Gooey's Avatar
Gooey
Yea I agreewith davidv. I see people with et streets andfull slicks pulling 2.0 60's....I did that all day with my stock tires.
Old Jan 4, 2008 | 06:42 AM
nlzmo400r's Avatar
nlzmo400r
I honestly can't see myself pulling 2.0 60's on stock tires; not with an open differential anyway. Hopefully I'l have the vlsd in by then because now it'll roast 1st gear everytime and most of 2nd as well.
Old Jan 4, 2008 | 07:08 AM
Gooey's Avatar
Gooey
You can do it. A lot of the 07 owners have done it and even pulled some 1.9's on stock tires. Youll be surprised but the stock re050's arent that bad.
Old Jan 4, 2008 | 12:40 PM
ajcool2's Avatar
ajcool2
I did it on my stock tires with my auto.
Old Jan 4, 2008 | 01:58 PM
nlzmo400r's Avatar
nlzmo400r
lol.........so I can't drag race, I'll admit it. I'll post up results the following day when I get to my office.
Old Jan 6, 2008 | 02:36 PM
Nealoc187's Avatar
Nealoc187
people can pull 1.9s on stock open diff Z. it takes some good driving, a good track, etc. i've pulled 2.0s in an open diff FWD car on stock all season tires as have many others, so it's definitely possible. it's not easy, but it can be done.
Old Jan 6, 2008 | 11:35 PM
nlzmo400r's Avatar
nlzmo400r
well I got the vlsd in today. So now I'm all ready for the 9th. I'll post up results as soon as I get back.
Old Jan 7, 2008 | 04:13 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Ive seen 2 people pull 1/9's on a base Z and read of 2 doing it online-stock tires. It is not uncommon.
Old Jan 9, 2008 | 08:10 PM
nlzmo400r's Avatar
nlzmo400r
just got back from the track, not really ideal conditions.
85-ish degrees
95% + humidity (basically a mist)
bone stock (only 1400miles on it) -
60' - 2.12
1/4 - 13.81
mph - 102.5mph
I didnt get a chance to run the M/Ts because the track closed early. I did get about 6 runs in on the stockers though, and no matter how I tried to launch, I either spun and hopped, or bogged. 2.1 was the best I could manage.
Just as a comparison, a friend of mine with a stock '06 ran quite a few times as well. His best was
60' - 2.1x
1/4 - 14.18
mph - 99.9x
Old Jan 9, 2008 | 08:14 PM
singh's Avatar
singh
_______________
Thumbs up
Good job!
