Drag NHRA, IDRC, IHRA, NDRA
Spinning problem plz help.
Old Apr 23, 2008 | 06:23 AM
bovi's Avatar
bovi
Made a 14.4 at 106@ tomorow and a 14.2 at 103???????....Second run, i was getting a bit of traction. BTW, my vlsd is done, always spinning 1 side only. Guess its now open
Old Apr 23, 2008 | 11:54 AM
WalkerT's Avatar
WalkerT
Professional
I have a oem vlsd with 10k on it for sale .. I put a nismo in.
https://my350z.com/forum/texas-marketplace/340401-fs-07-open-diff-and-vlsd-and-one-half-shaft.html
Old Apr 23, 2008 | 01:44 PM
scotts300's Avatar
scotts300
Originally Posted by bovi
Sucks, gotta buy a new one . Got a supercharger on the way.
I have finally convinced Nissan to replace hurting VLSD under warranty.
Old Apr 24, 2008 | 06:33 AM
PFI350Z's Avatar
PFI350Z
How much do they run?
Old Apr 24, 2008 | 07:19 AM
bovi's Avatar
bovi
Theres 3 ATI procharged Z outta here , 2 in the high 12 and 1 in low/flat 13.
Old Apr 26, 2008 | 02:18 AM
Sylvan Lake V35's Avatar
Sylvan Lake V35
If you couldnt control your wheel spin before it will be twice as bad with a SC. The additional power may result in better times because you may make up for poor traction with a good top end....but I think you need to improve your launch skills not get more power. If you post your slip or show your 60' times it would help. I run a JWT TT kit with 285mm street tires and get poor traction as well my 60' is 2.09 and 1/4 was 12.7@112 to get that time I lunch/roll off the line at 2000rpm and feather the throttle first gear I might get 75% throttle. If I launch at 3000rpm and go full throttle I hit the rev limiter before I even start to move. Its more finesse that popping the clutch and mashing the gas. Practice your launching try a few different things and see what works best then try it at the track you may have to make adjustments to your launch there due to more traction with a prepped track. Good Luck.
Old Apr 26, 2008 | 05:47 AM
Thats a pretty impressive set-up. Most likely you will want to post your times here: https://my350z.com/forum/drag/233840-top-25-1-4-mile-times-for-tt-st-supercharger-nitrous-bolt-ons-stock.html
Old Apr 26, 2008 | 06:51 AM
bovi's Avatar
bovi
David, ill buy a lsd dont worry. As for the 60ft, its 2.4 flat. And im not 100% throtle, i can play with it. Im not gonna get on my supercharger before my lsd dont worry loll.... But now that i see im open diff i can understand why i cant make better than a 14.3
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
