New to the Z, questions about launching..
Hey everyone, didn't have much luck on searching for common launch RPM's
I have an 03' Touring 6MT, mods include Motordyne 5/16" spacer, JWT pop, and a Bassani true dual exhaust. I will most likey be running the stock rubber, Potenza SO3's. I am very familiar with the track, ran many cars there in the past. Going back with my new Z (haven't been to the track in 2 years) and I am curious what people are launching at.
I have ready 2000-3500rpm's, with my setup what would be a good starting point? Also, what are common shift points, tire pressure, and any suggestions on shifting from 1st to 2nd to prevent wheel spin.
I've been launching my car ~5,000-5,500 - but toasted the flywheel after 100 passes or so. Veetec said he launched around that same area in his 04, so you might use that as a reference.
There are too many track variances to give a steadfast rule though. Some nights I launch below 3000 to get the right 1/8th time. I watch my 330' and 1/8th time more carefully than anything else as they contain the launch and most important shifts.
No one runs consistent times reading.
Advice I forgot to give, a quick burnout (maybe 3-4 seconds) is a good helper, it gets all the dirt and gravel off your tires and gets a clean section of rubber. Just don't burn too much of the rubber will be hot and not sticky.
